getHeight() reports wrong height values for ALL data field layouts in Venu Sq with new fw 4.7. E.g. 114 pixels (vs the correct 240) for 1-layout mode, which result in that I can only paint on half the screen. Which renders my data field App useless and actually cause it to crash. There is no way I can work around not having access to the full screen.
I have also been getting similar field reports for Venu Sq 2 v2.47 starting around the same time as they started for Venu Sq (19th May). So, not that I can confirm with own real device, but I'm pretty sure Venu Sq 2 is also messed up layout wise up since the crash reports are identical, i.e. happens in the same lines of code.
What is frankly very disappointing, is that I reported a similar defect, albeit only for a single data field mode, for the previous Venu Sq version: https://forums.garmin.com/developer/connect-iq/i/bug-reports/bug-venu-sq-reports-wrong-getheight-for-center-field-i-3-fields-mode-on-real-device-not-sim. Not only that, but also for Venu2 there are repeatedly issues in this area that are not being fixed but actually made worse: https://forums.garmin.com/developer/connect-iq/i/bug-reports/venu-2-bug-1st-onupdate-call-after-an-onshow-event-reports-getobscurityflags-for-the-previous-data-screen---now-much-worse
PLEASE fix these issues in the Venu series - and PLEASE test data field layouts BEFORE you make new releases!!!!
jim_m_58
Cancel
Vote Up
0
Vote Down
More
Cancel
Comment-
jim_m_58
Cancel
Vote Up
0
Vote Down
More
Cancel
Children
