Complete
There are already fixes in progress to address these issues. Apologies for the trouble!
Venu Sq v4.7 & Venu Sq 2 v2.47 messes up all data fields layouts, getHeight() values all wrong
getHeight() reports wrong height values for ALL data field layouts in Venu Sq with new fw 4.7. E.g. 114 pixels (vs the correct 240) for 1-layout mode, which result in that I can only paint on half the screen. Which renders my data field App useless and actually cause it to crash. There is no way I can work around not having access to the full screen.
I have also been getting similar field reports for Venu Sq 2 v2.47 starting around the same time as they started for Venu Sq (19th May). So, not that I can confirm with own real device, but I'm pretty sure Venu Sq 2 is also messed up layout wise up since the crash reports are identical, i.e. happens in the same lines of code.
What is frankly very disappointing, is that I reported a similar defect, albeit only for a single data field mode, for the previous Venu Sq version: https://forums.garmin.com/developer/connect-iq/i/bug-reports/bug-venu-sq-reports-wrong-getheight-for-center-field-i-3-fields-mode-on-real-device-not-sim. Not only that, but also for Venu2 there are repeatedly issues in this area that are not being fixed but actually made worse: https://forums.garmin.com/developer/connect-iq/i/bug-reports/venu-2-bug-1st-onupdate-call-after-an-onshow-event-reports-getobscurityflags-for-the-previous-data-screen---now-much-worse
PLEASE fix these issues in the Venu series - and PLEASE test data field layouts BEFORE you make new releases!!!!
