It is a datafield to display op the device map view with navigation, I do not want to create an own map view In the sim there is no way to test it because you cannot load a simulated map in the sim. On the phisical device you see the map a bit with opacity See Transparent datafield on Map (dist, hr, rem.dist) | Connect IQ Store and install it on the 1 field view on a map
