Under Review
over 1 year ago
Third party watch faces that are downloaded from Connect IQ do not display HR graph correctly.
11.14 and 11.15 BETA - Venu 2
Phone: Google Pixel 6 Pro - Android 13
Current result: when using a third party watch face, and configuring it to display a HR graph, the graph does not update in real time and remains the same for 12 hours. It appears to update once after 12 hours has passed but then remains the same for another 12 hours. It also does not match the HR graph widget.
Expected result: when using a third party watch face, and configuring it to display a HR graph, the graph will update in real time at regular intervals and should match the HR graph widget.
Note that all other data, including the current HR value are updated correctly in real time.
Tested on the following watch faces:
Instinct Mission
Descent MK2 digital MB
Fenix 7 by ershovlad
SHN TACv2
Also note that the HR graph DOES update in real time on one of the Garmin default watch faces supplied with the Venu 2. It is the watch face that has digital numbers, a compass and a heart rate graph on the bottom.
Parents
    Former Member over 1 year ago in reply to TitanicTurtle
    Bonjour, effectivement je fais partie des 2 utilisateurs qui vous ont contacté. Et la réponse apporté de votre était que vous n'avez pas l'air de me croire ou de prendre au sérieux mon problème.
Comment
Children
No Data
