Ticket Created
WERETECH-11175
set/getProperty deprecate on sdk 4?
In current doc something has changed!!
Previous information: some function (e.g. deleteProperty) was planned to remove but not set/get.
My app run well and there are values in sim Application.AppBase.Data.
So, is documentation correct?
I have some strange app behaviour on sim:
- settings don't change
- memory peaks
- console  message "Unable to serialize app data"
- resetting settings to default
can be connected with any changes in sdk 4?
Parents
  • 1. I know that this is connected with low memory but I don't know why. This is for watch face.
    2. This happens when user change setting on watch and there is called app.onSettingsChanged so I can't close app because it's out of me. But not always, app run well I don't do anything and suddenly "Unable to serialize app data", what this error really mean, is connecting with settings?
    3. My onSettingsChanged
    - isn't big so  there should not be peak memory,
    - there is a lot getProperty call and I think it may be connected with it but why if this in app memory and it's loaded when app start:
Comment
Children
  • ok, my minimal is 2.3 and when I've changed to 2.4 none of device was removed (maybe some part numbers, I don't know).
    As I understand module Properties should be use to obtain application's settings (even save new data - but not by background) and Storage to save data for later usage and exchange data between background and app, correct?
    checking sdk level by e.g.
    if(Application has Storage)
     //access app's settings by Properties
     //access to storage by Storage
    }else
     //access app's settings by getProperties()
     //access to storage by set/getProperties()
  • "But what about with the subject of this topic, set/getProperty deprecation? On venu 2/2s sim everything run well it means not deprecated."
    Yeah, idk. The doc says not to use that API for CIQ 4 devices so maybe it won't work in the future.
    You could always switch to Application.Properties (getValue and setValue).
    I know it's a pain bc devices older than 2.4 don't support it. That's why I never use it, but I guess I'll have to if I ever want to support Venu 2.
    I don't think that SDK 4 itself can deprecate Applicatoin.AppBase.get/setProperty, bc as Brandon pointed out, it's supposed to work. Otherwise we won't be able to dev for old devices in SDK 4.
  • I know about properties name. But I think also name of id in in string (<string id="AppName">) and layout (<param name="locX">).
  • And due to the way properties are defined and accessed, the original name has to be preserved. (They're stored in a dictionary where the property name is the key.)
  • "oh no... I've asked about several time and I was almost sure that length of var name has influence of memory consumption even though I felt it shouldn't."
    It's only the length of *property* names that have an affect on memory consumption, because properties are always loaded into memory.
