Ticket Created
WERETECH-11175
set/getProperty deprecate on sdk 4?
In current doc something has changed!!
Previous information: some function (e.g. deleteProperty) was planned to remove but not set/get.
My app run well and there are values in sim Application.AppBase.Data.
So, is documentation correct?
I have some strange app behaviour on sim:
- settings don't change
- memory peaks
- console  message "Unable to serialize app data"
- resetting settings to default
can be connected with any changes in sdk 4?
Parents
  • "But what about with the subject of this topic, set/getProperty deprecation? On venu 2/2s sim everything run well it means not deprecated."
    Yeah, idk. The doc says not to use that API for CIQ 4 devices so maybe it won't work in the future.
    You could always switch to Application.Properties (getValue and setValue).
    I know it's a pain bc devices older than 2.4 don't support it. That's why I never use it, but I guess I'll have to if I ever want to support Venu 2.
    I don't think that SDK 4 itself can deprecate Applicatoin.AppBase.get/setProperty, bc as Brandon pointed out, it's supposed to work. Otherwise we won't be able to dev for old devices in SDK 4.
Comment
Children
  • ok, my minimal is 2.3 and when I've changed to 2.4 none of device was removed (maybe some part numbers, I don't know).
    As I understand module Properties should be use to obtain application's settings (even save new data - but not by background) and Storage to save data for later usage and exchange data between background and app, correct?
    checking sdk level by e.g.
    if(Application has Storage)
     //access app's settings by Properties
     //access to storage by Storage
    }else
     //access app's settings by getProperties()
     //access to storage by set/getProperties()
