Acknowledged
sdkmanager.exe crashes on first launch after extracting from .zip
Hello,
Trying to install Connect IQ SDK on a clean Windows 10 LTSB -
  • Downloaded connectiq-sdk-manager-windows.zip
  • Extracted contents to C:\Temp\connectiq-sdk-manager-windows
  • Launched C:\Temp\connectiq-sdk-manager-windows\sdkmanager.exe
This shows an empty window with a "busy" mouse cursor -
After several seconds the following crash dialog pops up
Windows is up-to-date. There's literally nothing else on it, it's a fresh install.
In which direction do I have to dig?
Thanks
Parents
  • Alright, so I managed to work around this. For anyone running into this issue, the workaround is this:
    1. Find another machine where sdkmanager.exe does not crash
    2. Once launched, agree to the EULA, then cancel the Login dialog
    3. Copy %AppData%\Roaming\Garmin\sdkmanager-config.ini to the same location on LTSC 2016 box
    That's it. After that sdkmanager will launch and take you to the Login dialog for the account.
Comment
Children
  • > A month in and for whatever reason this workaround no longer works.
    It appears that it was caused by a new version EULA / T&C being shipped with updated SDK. The SDK updated itself automatically and then wanted to show new agreement for re-acknowledgment => ran into the same problem as in a fresh install and crashed.
  • A month in and for whatever reason this workaround no longer works.
    The sdkmanager-config.ini is in place, "agreement-hash" entry is in there, but launching sdkmanager.exe now pops up blanked-out EULA window and the whole thing crashes few seconds later.
