Ticket Created
WERETECH-9679
SDK Manager fails in Fedora Linux
Split off from other bug report.
The SDK manager gives the following error on Fedora 32:
Unable to download the list of SDKs. Error code: 33554509
and
Unable to downloaded the device list. Error code: 33554509
The errors occur after successfully logging in.
using an ubuntu docker image, the sdkmanager does work.
Also tried to run sdkmanager via a proxy to see what it was doing. If I configure a system proxy then sdkmanager makes a few successful requests to cloudflare then crashes with a segmentation violation.
Parents Comment Children
  • yes Slight smile
    so the sdk manager, rely on the fact that mac os x is now shipped with open ssl at a specific location, which wasn't the case with mac os 10.11
    In order to make it starting :
    1 - install brew on your mac
    /bin/bash -c "$(curl -fsSL raw.githubusercontent.com/.../install.sh)"
    2 - install open ssl : brew install openssl
    Here, I had a few issues which I needed to solve, like permission, etc, sorry but I can't remember the details..... look at the messages it returns during install, if I remember, on package failed, and it was easy to miss it doing so.
    3 - run this :
         sudo mkdir /usr/local/etc/openssl
        sudo ln -s /usr/local/etc/[email protected]/cert.pem /usr/local/etc/openssl/cert.pem
    the sdk manager will then start immediately Slight smile
    Good luck.
