Ticket Created
WERETECH-9679
SDK Manager fails in Fedora Linux
Split off from other bug report.
The SDK manager gives the following error on Fedora 32:
Unable to download the list of SDKs. Error code: 33554509
and
Unable to downloaded the device list. Error code: 33554509
The errors occur after successfully logging in.
using an ubuntu docker image, the sdkmanager does work.
Also tried to run sdkmanager via a proxy to see what it was doing. If I configure a system proxy then sdkmanager makes a few successful requests to cloudflare then crashes with a segmentation violation.
  • yes Slight smile
    so the sdk manager, rely on the fact that mac os x is now shipped with open ssl at a specific location, which wasn't the case with mac os 10.11
    In order to make it starting :
    1 - install brew on your mac
    /bin/bash -c "$(curl -fsSL raw.githubusercontent.com/.../install.sh)"
    2 - install open ssl : brew install openssl
    Here, I had a few issues which I needed to solve, like permission, etc, sorry but I can't remember the details..... look at the messages it returns during install, if I remember, on package failed, and it was easy to miss it doing so.
    3 - run this :
         sudo mkdir /usr/local/etc/openssl
        sudo ln -s /usr/local/etc/[email protected]/cert.pem /usr/local/etc/openssl/cert.pem
    the sdk manager will then start immediately Slight smile
    Good luck.
    Former Member in reply to Klick
    I get the same on Mac os X 10.11 - have you found a fix?
  • My account works with the following:
    $ cat Dockerfile
    FROM ubuntu:bionic
    RUN DEBIAN_FRONTEND=noninteractive apt-get -y update && DEBIAN_FRONTEND=noninteractive apt-get -y install software-properties-common && DEBIAN_FRONTEND=noninteractive apt-get -y update && DEBIAN_FRONTEND=noninteractive apt-get -y install git openjdk-8-jre-headless build-essential sudo wget unzip libxxf86vm1 libgtk2.0-0 openssh-server libusb-1.0-0 libsm6 libwebkitgtk-1.0-0 imagemagick imagemagick-common x11-apps nodejs && apt-get clean && rm -rf /var/lib/apt/lists/*
    RUN wget https://developer.garmin.com/downloads/connect-iq/sdk-manager/connectiq-sdk-manager-linux.zip && unzip connectiq-sdk-manager-linux.zip
    $ cat run
    #!/bin/sh
    docker build -t ub .
    docker run -e DISPLAY=$DISPLAY -v /tmp/.X11-unix:/tmp/.X11-unix -e XDG_RUNTIME_DIR=$T -e WAYLAND_DISPLAY=$WAYLAND_DISPLAY -v $XDG_RUNTIME_DIR/$WAYLAND_DISPLAY:/tmp/$WAYLAND_DISPLAY -it --rm ub bash
  • interestingly, I'm having the same exact problem on ... mac os x (10.11) on my 2 machines.
    I start to wonder if the problem is not linked to our garmin account, and not to the binaries themselves.
