Acknowledged
SDK bug in loading properties
Hello,
I have a boolean-property which stopped working, i.e. its value upon invoking
Toybox.Application.Properties.getValue("somePropertyKey")
is 'true' regardless of whether it is set to true/false in properties.xml;
Since it used to work I have changed SDK and found out it worked properly with older SDKs,
i.e. leaving code+properties intact (w/ the prop set to 'false'),
and only changing the SDK being used to compile/run, then compiling+running yield the following results:
  • connectiq-sdk-mac-4.1.1-2022-03-14-18db583bc: Properties.getValue return false, i.e. as expected
  • connectiq-sdk-mac-4.1.2-2022-04-07-15e8df3ed: Properties.getValue return false, i.e. as expected
  • connectiq-sdk-mac-4.1.3-2022-05-10-b3aaee541: Properties.getValue return TRUE instead of false
  • connectiq-sdk-mac-4.1.4-2022-06-07-f86da2dee: Properties.getValue return TRUE instead of false
  • connectiq-sdk-mac-4.1.5-2022-08-03-6e17bf167: Properties.getValue return TRUE instead of false
  • connectiq-sdk-mac-4.2.0.beta1-2022-10-11-bff57b73c: 'make' fails w/ 'Error 100' and does not provide any further details
Unless I am missing something, this is a bug, which might also be related to:
- https://forums.garmin.com/developer/connect-iq/i/bug-reports/bug-boolean-properties-with-default-value-true-can-t-be-changed-in-simulator
- https://forums.garmin.com/developer/connect-iq/i/bug-reports/sdk-4-1-1-settings-issues
Parents
  • Where do you experience the problem? If it's in the simulator then it can also be another known issue (don't remember if there's a bug reported for that) but the workaround is that you need to clean all app data and apps (in the file menu) and then start your app in it.
Comment
Children
  • I built+run the sim, and the sim showed what it needs to show when the boolean is set to 'true'; but the default-value in the properties for that boolean was 'false';
    I have then added traces to print what value is retrieved by Toybox.Application.Properties.getValue("somePropertyKey"), and the value was 'true';
    I have then left the code+properties intact, and switched SDK + compile + run and got the results listed above.
    I am therefore assuming this is an SDK issue rather than a sim issue.
    I am not sure how to explain how it works for  - perhaps he uses some old caching i.e. my build script is set to delete the temporary folder the sim (I think) creates whenever it is launched
