Acknowledged
SDK bug in loading properties
Hello,
I have a boolean-property which stopped working, i.e. its value upon invoking
Toybox.Application.Properties.getValue("somePropertyKey")
is 'true' regardless of whether it is set to true/false in properties.xml;
Since it used to work I have changed SDK and found out it worked properly with older SDKs,
i.e. leaving code+properties intact (w/ the prop set to 'false'),
and only changing the SDK being used to compile/run, then compiling+running yield the following results:
  • connectiq-sdk-mac-4.1.1-2022-03-14-18db583bc: Properties.getValue return false, i.e. as expected
  • connectiq-sdk-mac-4.1.2-2022-04-07-15e8df3ed: Properties.getValue return false, i.e. as expected
  • connectiq-sdk-mac-4.1.3-2022-05-10-b3aaee541: Properties.getValue return TRUE instead of false
  • connectiq-sdk-mac-4.1.4-2022-06-07-f86da2dee: Properties.getValue return TRUE instead of false
  • connectiq-sdk-mac-4.1.5-2022-08-03-6e17bf167: Properties.getValue return TRUE instead of false
  • connectiq-sdk-mac-4.2.0.beta1-2022-10-11-bff57b73c: 'make' fails w/ 'Error 100' and does not provide any further details
Unless I am missing something, this is a bug, which might also be related to:
- https://forums.garmin.com/developer/connect-iq/i/bug-reports/bug-boolean-properties-with-default-value-true-can-t-be-changed-in-simulator
- https://forums.garmin.com/developer/connect-iq/i/bug-reports/sdk-4-1-1-settings-issues
Parents
  • I built+run the sim, and the sim showed what it needs to show when the boolean is set to 'true'; but the default-value in the properties for that boolean was 'false';
    I have then added traces to print what value is retrieved by Toybox.Application.Properties.getValue("somePropertyKey"), and the value was 'true';
    I have then left the code+properties intact, and switched SDK + compile + run and got the results listed above.
    I am therefore assuming this is an SDK issue rather than a sim issue.
    I am not sure how to explain how it works for  - perhaps he uses some old caching i.e. my build script is set to delete the temporary folder the sim (I think) creates whenever it is launched
Comment
Children
No Data
