To replicate:
1. Start an app...
2. Use Application.getApp().setProperty(key,value); to set a property
3. Use Ctrl + M to verify setting is stored in ApplicationProperties
4. Restart the app
5. Use Ctrl + M to verify setting is still stored in ApplicationProperties
6. Start Application Settings
ACTUAL BEHAVIOUR
7. Note that entire settings form has been reset to default values. It is not referring to current application properties at all.
EXPECTED BEHAVIOUR.
7. Application Settings should open with current values of application properties
