Complete
over 2 years ago
Received the new part number 006-B4542-00 for Epix Pro 51mm through SDK manager but Connect IQ does not accept uploads
The following errors were detected in your app file
There were no compatible devices found for the part numbers declared in the manifest file. 006-B4542-00
Btw. since there are apparent issues with the new SDK 6.2.0, do you still recommend using it?
If not how can I safely downgrade to 4.2.4?
When I set 4.2.4 as current SDK some devices do no longer show a Target API level in the run configuration combobox!?
Parents
  • And I have already moved to VS Code and the change was rather painless.
    All I had to do was add VS Code launch configurations but other than that it worked right away with the project structure I had with Eclipse.
    One postive thing I can already report is that the compilation/simulator launches faster.
Comment
Children
No Data
