Ticket Created
CIQQA-903
Processing JSON with missing root
The following (which is valid JSON) returns  INVALID_HTTP_BODY_IN_NETWORK_RESPONSE.
It's missing the root node but is still valid JSON. Missing the root node is fairy common. So, it should be able to be processed by IQ.
"name":"aaaa"
"name":"bbbb"
The following  is not missing the root node (and works).
"list" : [
"name":"aaaa"
"name":"bbbb"
Parents
  • > Maybe it's valid json but sdk need name for dictionary key so error...
    Yes. The makeWebRequest functionality requires the incoming JSON to be a JSON Object (a MonkeyC dictionary). This has come up before, several times. We have not changed the behavior thus far, so I have some doubt that we'd change it unless there was a really good motivation.
    > Why can't the key be an empty string?
    The data that doesn't work that is shown above is a JSON Array, and as I've just explained we expect the web service to provide a JSON Object (a Dictionary). A JSON Object with an empty key is *not* the same as a JSON Array. Example..
    # this is a JSON array
        "name":"aaaa"
        "name":"bbbb"
    # this is a JSON dictionary with an empty string as a key
              "name":"aaaa"
              "name":"bbbb"
    If the incoming JSON is a valid JSON Object (Dictionary), we should be able to process it.
Comment
        "name":"aaaa"
        "name":"bbbb"
              "name":"aaaa"
              "name":"bbbb"
Children
No Data
