Ticket Created
over 3 years ago
CIQQA-903
Processing JSON with missing root
The following (which is valid JSON) returns  INVALID_HTTP_BODY_IN_NETWORK_RESPONSE.
It's missing the root node but is still valid JSON. Missing the root node is fairy common. So, it should be able to be processed by IQ.
"name":"aaaa"
"name":"bbbb"
The following  is not missing the root node (and works).
"list" : [
"name":"aaaa"
"name":"bbbb"
  • The bottom line is that the code that processes the HTTP response body for a JSON request requires that data to represent a JSON object.
    This is a choice. It appears the name of the object member can be empty. The code that processes the root could give the object an empty name.
  • There are some languages that provide for "automatic" serialization/deserialization between objects and JSON. As far as I understand, you have to provide the code for doing that in Monkey C.
    Yes. We provide that code. That code expects the response body to contain a JSON object, and it converts that JSON object to a MonkeyC Dictionary type.
    That is, a dictionary is not the same as an object.
    I never said that. I specifically used the term JSON object in all of my comments above. I did this intentionally because JSON object has a very specific meaning.
    You can check the definition by reading the ECMA specification [1]. To recap, a JSON object is a collection of zero or more name/value pairs, where the names are always of type String. This means that JSON object is just an associative collection with keys that are strings. It is a formal subset of the dictionary type in many programming languages. In Java, the type org.json.JSONObject extends java.lang.Map<String, JsonObject> [2]. In python, a parsed JSON object is returned as a native dict type.
    The bottom line is that the code that processes the HTTP response body for a JSON request requires that data to represent a JSON object. As such, it must conform to the grammar that describes JSON object [1].
    [1] https://www.ecma-international.org/wp-content/uploads/ECMA-404_2nd_edition_december_2017.pdf
    2] https://docs.oracle.com/javaee/7/api/javax/json/JsonObject.html
    That is, a dictionary is not the same as an object. They don't even work the same way.
  • People are letting their sense of "architectural purity" make things less useful in the real world.
  • The issue is missing the key in the root. Not in other levels.
    > It's fairly common to be missing the key at the root.
    The JSON format requires JSON Object keys to be String. Additionally, the null object is of type Null. Since String and Null are not the same type, it is not legal for null to be a key. You can read the JSON standard here. It is short and quite simple.
    Even if null could be a key, there is a big difference between a null key and omitting the key, which it seems is what you believe is happening.
    The difference between the snips in the original post is *not* that the key is null in one and the empty string in the other.
    The first snip shows is an JSON Array of JSON Object. The second is a JSON Object with a key/value pair that has a value that is an Array of JSON Object. The types are very different from both a JSON perspective and a ConnectIQ perspective.
    It's common for consumers to deal with it. It's Garmin being odd man out.
    As I said in my original response, we (ConnectIQ) require the HTTP response body to contain a well formed JSON Object (a Dictionary). Some services generate HTTP responses that are valid JSON Values (any of JSON Object, Array, Number, String, true, false, or null). This means that ConnectIQ accepts only a subset of the types produced by some web services.
    As I said in my original response, this is something we know. The issue has come up several times and has not been fixed. There are existing tickets in our backlog for it, but I don't have any reason to believe that the will be fixed soon.
