Acknowledged
Problem with installing app
One of my user has tried to install widget PSX-7 (https://apps.garmin.com/apps/1944b8b4-409e-482d-b7b3-becd4e8b1b05) but he couldn't due the incapability error but he has installed PSX-6 (https://apps.garmin.com/apps/e4ce9423-c37e-4aa7-b778-f24c2347c923). Both are built the same SDK (7.3.1m PSX-7 few days later), both have the same min API level to 2.4.
Parents
  • There is no default language but there is default resource and inside "strings" - it means default strings.
    The manifest defines languages or nothing -> compiler builds languages or none but ALWAYS default.
    Watch, user -> language = LAN, starting app, system check if there is a resources for LAN, if not, simple load res from default.
    So if a dev prepare only default resource and inside Esperanto strings all will be shown in Esperanto independent of LAN.
    I understand all of that but again that doesn't explain how the compiler would know that your app supports English unless you say so, or you leave the languages unspecified.
    Your implicit answer would be that it doesn't matter (due to all the things you said above), but now we both know better.
    Why shouldn't the compiler include/exclude devices based on language support? It is this process that mandates that you list all the languages your app supports, if you choose to list any at all (otherwise the compiler just assumes you support English).
    Right and I already covered that. That covers the process of string lookups, but not the specification of what languages your app supports. Perhaps the mistake here was to assume that string lookup is the only way that languages have any effect on CIQ apps.
    > The complete lack of documentation around part numbers with respect to CIQ is a little disappointing.
    But actually, the behavior here is documented. If either of us had read the related docs recently, we would've seen the problem immediately.
    https://developer.garmin.com/connect-iq/core-topics/manifest-and-permissions/
    Languages
    Connect IQ apps can be localized across over 30 languages, and the languages your app support can impact what regions of the world your app is available in. In the manifest you can declare the languages your app supports, which will be used when exporting your application to the store. See Resources for more information.
    Notice how it does *not* say anything like: "the languages your app supports are only used to look up strings in resources, and nothing else".
Comment
    Languages
Children
No Data
