Acknowledged
Problem with installing app
One of my user has tried to install widget PSX-7 (https://apps.garmin.com/apps/1944b8b4-409e-482d-b7b3-becd4e8b1b05) but he couldn't due the incapability error but he has installed PSX-6 (https://apps.garmin.com/apps/e4ce9423-c37e-4aa7-b778-f24c2347c923). Both are built the same SDK (7.3.1m PSX-7 few days later), both have the same min API level to 2.4.
Parents
  • > I won't waste time to check jsons and language, simple I will check all languages, make default resources and because compiler uses tree to build resources it will use default strings for any language I will dicide to not translate...
    I don't think you have to do that. Just do what you do today -- select the languages that have non-default resources -- and also add English to the list.
    I did a quick check and out of 298 part numbers, only one of them doesn't support English: gpsmap67 (APAC)
Comment
Children
No Data
