Ticket Created
over 3 years ago
CIQQA-1148
Persistent login details for SDK manager and simulator
            OS: Ubuntu 20.04
   SDK Manager: 1.0.4
Connect IQ SDK: 4.1.2
Neither the SDK manager nor the simulator (when accessing app settings) remember the login details for my garmin account. This means typing in my email and finding/copying my password from a password manager each and every time I run them. This gets rather tedious after a while - so is there a way to persist the login details or is it supposed to and there's a bug preventing it from working?
Related question: Why does the simulator require an account login to manipulate the local settings?
On another note - the app settings window in the simulator has the odd behaviour that if you keep it open it will not allow you to make multiple changes. Instead you have to close the window and open it again.
I've recently started using Connect IQ again having not worked on my old watchface for many years and have been very pleased to find the move to VSCode and better cross-platform support - so thanks!
  • With the help of Kyle who provided a version of the SDK manager with more logging we were able to figure out that KDE does not support "org.freedesktop.secrets" via dbus in Kubuntu 20.04. It looks like a future version of kwallet may support it, but probably not until Kubuntu 22.10.
    In the meantime there are a couple of solutions I've tried and will document here in case anyone else has the same issue:
    Method 1 - simplest
    Install "gnome-keyring". Not ideal on a KDE system, but it does work. We don't need any of the associated bits so a
    $ sudo apt install --no-install-recommends gnome-keyring
    should do the trick. Since it's only being used to store credentials for the Garmin SDK manager and emulator then setting a password is optional (leave blank when prompted).
    Method 2
    Install KeePassXC (not from the standard repos because that version is too old) and then follow the instructions at https://rtfm.co.ua/en/what-is-linux-keyring-gnome-keyring-secret-service-and-d-bus/#KeePass to configure it for Secret Service integration.
  • , if you'd be willing to help us troubleshoot this please email [email protected] and we can get some additional logs from you to see what is going on. Mention this thread and ask to be redirected to me in the email.
  • Yes, the package "libsecret-1-0" is installed. I didn't install it manually so it's either part of the standard Ubuntu install, or is a dependency for something else I've installed.
  • Would you happen to have libsecret installed on this computer?
  • It looks like the "rememberMeChecked" property is set to false in the login window and also the "rememberMeShown" property is set to false which I guess hides the checkbox on that page.
    Apr 25 23:14:06 dodeca WebKitNetworkProcess[162560]: > POST /sso/signin?service=https%3A%2F%2Fsso.garmin.com%2Fsso%2Fembed&source=https%3A%2F%2Fsso.garmin.com%2Fsso%2Fembed&redirectAfterAccountLoginUrl=https%3A%2F%2Fsso.garmin.com%2Fsso%2Fembed&redirec
    tAfterAccountCreationUrl=https%3A%2F%2Fsso.garmin.com%2Fsso%2Fembed&gauthHost=https%3A%2F%2Fsso.garmin.com%2Fsso&locale=en&id=gauth-widget&cssUrl=https%3A%2F%2Fdeveloper.garmin.com%2Fdownloads%2Fconnect-iq%2Fsdk-manager-login.css&clientId=ConnectIqSdkM
    anager&rememberMeShown=false&rememberMeChecked=false&createAccountShown=true&openCreateAccount=false&displayNameShown=false&consumeServiceTicket=true&initialFocus=true&embedWidget=true&generateExtraServiceTicket=false&generateTwoExtraServiceTickets=fal
    se&generateNoServiceTicket=false&globalOptInShown=false&globalOptInChecked=false&mobile=false&connectLegalTerms=false&showTermsOfUse=false&showPrivacyPolicy=false&showConnectLegalAge=false&locationPromptShown=false&showPassword=true&useCustomHeader=fal
    se&mfaRequired=false&performMFACheck=false&rememberMyBrowserShown=false&rememberMyBrowserChecked=false HTTP/1.1
    Apr 25 23:14:06 dodeca WebKitNetworkProcess[162560]: > Soup-Debug-Timestamp: 1650924846
    Apr 25 23:14:06 dodeca WebKitNetworkProcess[162560]: > Soup-Debug: SoupSession 1 (0x5581f9fd0100), SoupMessage 21 (0x5581fa3600c0), SoupSocket 19 (0x5581fa3161c0)
    Apr 25 23:14:06 dodeca WebKitNetworkProcess[162560]: > Host: sso.garmin.com
    Apr 25 23:14:06 dodeca WebKitNetworkProcess[162560]: > Referer: sso.garmin.com/.../signin
    .com%2Fsso%2Fembed&redirectAfterAccountCreationUrl=https%3A%2F%2Fsso.garmin.com%2Fsso%2Fembed&gauthHost=https%3A%2F%2Fsso.garmin.com%2Fsso&locale=en&id=gauth-widget&cssUrl=https%3A%2F%2Fdeveloper.garmin.com%2Fdownloads%2Fconnect-iq%2Fsdk-manager-login.
    css&clientId=ConnectIqSdkManager&rememberMeShown=false&rememberMeChecked=false&createAccountShown=true&openCreateAccount=false&displayNameShown=false&consumeServiceTicket=true&initialFocus=true&embedWidget=true&generateExtraServiceTicket=false&generate
    TwoExtraServiceTickets=false&generateNoServiceTicket=false&globalOptInShown=false&globalOptInChecked=false&mobile=false&connectLegalTerms=false&showTermsOfUse=false&showPrivacyPolicy=false&showConnectLegalAge=false&locationPromptShown=false&showPasswor
    d=true&useCustomHeader=false&mfaRequired=false&performMFACheck=false&rememberMyBrowserShown=false&rememberMyBrowserChecked=false
    Apr 25 23:14:06 dodeca WebKitNetworkProcess[162560]: > Origin: https://sso.garmin.com
    Apr 25 23:14:06 dodeca WebKitNetworkProcess[162560]: > Content-Type: application/x-www-form-urlencoded
    Apr 25 23:14:06 dodeca WebKitNetworkProcess[162560]: > Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
    Apr 25 23:14:06 dodeca WebKitNetworkProcess[162560]: > User-Agent: Mozilla/5.0 (X11; Ubuntu; Linux x86_64) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/15.0 Safari/605.1.15
    Apr 25 23:14:06 dodeca WebKitNetworkProcess[162560]: > Accept-Encoding: gzip, deflate
    Apr 25 23:14:06 dodeca WebKitNetworkProcess[162560]: > Accept-Language: en-US
    Apr 25 23:14:06 dodeca WebKitNetworkProcess[162560]: > Connection: Keep-Alive
