Hello,
On fenix 6 device there are Glances and widget with pressure sensor access does not show info. Fenix 7x device is ok.
When you enter the widget on any device from Glances mode it displays values normally.
App is:
https://apps.garmin.com/en-US/apps/00678298-6672-4228-9c82-c9aa00e43df0
Expected: in Glances mode widget has onUpdate() event on fenix 6 device. sw 22.10 after each Ui.requestUpdate(); call.
Event appears in timer, so update requested often.
The same bug exists in simulator for Descent G1.
Please verify it..
Simulator behaves the same: fenix 6 (non pro version) does not access to sensor, but fenix 7x in Glances mode displays all ok.
SDK 4.1.4 used. Eclipse Plugin 4.1.2.
