Acknowledged
onUpdate() event occurs once in Glances for fenix 6 (may be other devices).
Hello,
On fenix 6 device there are Glances and widget with pressure sensor access does not show info. Fenix 7x device is ok.
When you enter the widget on any device from Glances mode it displays values normally.
App is:
https://apps.garmin.com/en-US/apps/00678298-6672-4228-9c82-c9aa00e43df0
Expected: in Glances mode widget has onUpdate() event on fenix 6 device. sw 22.10 after each        Ui.requestUpdate();      call.
Event appears in timer, so update requested often.
The same bug exists in simulator for Descent G1.
Please verify it..
Simulator behaves the same: fenix 6 (non pro version) does not access to sensor, but fenix 7x in Glances mode displays all ok.
SDK 4.1.4 used. Eclipse Plugin 4.1.2.
  • What you're dealing with sounds like the live update for glances.
    on the non pro f6, it's "liveUpdates": false
    while on the f7x, it's true.
    When false, WatchUi.requestUpdate is ignored.
    See https://developer.garmin.com/connect-iq/core-topics/glances/#glances
    Glance Lifecycle
    Depending on a device’s resource limitations, GlanceView can be updated in two different ways.
    Live UI Update
    Devices that have ample resources [1] will start the Widget in Glance mode, and keep it alive. The provided GlanceView will be updated as needed by the system, and calls to WatchUi.requestUpdate() will trigger a View update as expected.
    Note: It’s highly recommended that the update rate should be kept under 1HZ to provide a better scrolling experience.
    Background UI Update
    Devices that have less memory [2] will start the app only when the system deems it appropriate, and calls to WatchUi.requestUpdate() will have no effect. Such a device could update their glance view when it becomes visible (activated) and at least 30 seconds since last update.
