Ticket Created
WERETECH-7119, WERETECH-7120, WERETECH-8181
Split issues in this thread into multiple issues.
MapView and MapTrackView classes are broken - even more on CIQ3.1
Hi,
not only that CIQ 3.0 implementation of MapView and MapTrackView still have more issues than actual working features, CIQ 3.1 even made them worse.
Newly, UI rendered by both classes can not be refreshed on CIQ 3.1 devices by calls from code after first initialisation - for example by setMapVisibleArea method as it is described here:
https://forums.garmin.com/developer/connect-iq/f/discussion/191378/fenix-6-ciq-maps-implementation/932413#932413
I can summary also the older issues if it will help somebody to take care of them in one run. But some of them are already mentioned on various places of the forum without any positive reaction from CIQ team, so I don't want to waste time if nobody ask for them.
Will there be please finally time to fix those important parts of CIQ after settling down dust from CIQ 3.1 public release? This is kind of things why Connect IQ is extremely hard to use for any more complex apps which should be perfectly doable according to documentation.  In my case I have to disable maps on all CIQ 3.1 devices until the problems will be solved leaving my users confused again. Disappointed
  • Also don't forget, that whether you see those +/- buttons on F7/EPIX when entering the map screen depends on state of map screen shown on device previously, doesn't matter whether in your CIQ app or native activity app. And you can try to force MAP_MODE_PREVIEW as you want.
    All in all, this is great example where it would be enough, if some person from CIQ team spend one day trying to implement the screen to some meaningful app and fix all issues/glitches he found in the process instead of waiting for us to to report them without getting any feedback. This should happened years ago after 3.0 release, where maps was one of the biggest addition. This is exactly what I tought by bullet #1 in this post: https://forums.garmin.com/developer/connect-iq/f/discussion/7985/general-wishes-ideas-for-connect-iq-future/1368779#1368779
    On the other hand, I think behaviour of map screen on these new devices with both touch/buttons controls make sense. So its only on CIQ platform to incorporate changes to be compatible with this approach - like disabling movement of the map when sliding to different screen from map on preview mode (just like it is on native activity apps).
  • I saw something similar but need to play with it some more first.  Brought up my app with a map display.  When I tapped the screen on the Epix, it showed the native +/- icons, but you couldn't tap those to zoom in/out.  Since I handle the back button myself, there was no way to get the native +/- to go away.
    Good news is there were no crashes, but it definitely wasn't working like i'd expect.  Part of it is probably with how I intercept taps and button presses.  But given the other limitations, like not being able to get the current zoom level, I want to do everything myself with zooming and panning, but there doesn't appear to be any way to do that.
  • Any hope of this getting properly fixed? This is still broken on the new Epix gen 2 watch - MAP_MODE_PREVIEW gets overridden as soon as you touch the screen.
    Also, it would be nice with some way to query the actual lat/lon boundaries rendered on the map. Same with a way to query the discrete zoom levels used.
  • I looked around and it seems like the issues are still open. I will poke them about this and see if there's any lead on this.
  • Oh, it would also help if I don't react to just part of the thread as half  of the replies were not visible including my new one above. They appeared only after I change view to new posts on top.. Dizzy face
