Acknowledged
Instinct 2S completely hangs with BLE bg wf
i'm developing a BLE background watchface and am seeing complete watch hangs on Instinct 2S after about 1 to 2 days of running the wf (and I believe FR 965M but I have stopped testing that due to its inadequate battery.)
i'm not sure which connect iq calls are causing this but i will try to gather more info. since it happens so infrequently (i've seen it at least 3 times and have never been able to get past 2 days of runtime so i'm sure i'll see it again), i'm starting this bug report now anyway to see if others have seen it.
the only thing i can do to the watch after the hang is hold the light button for a long time to power it down, it responds to nothing else and does not update the wf at all.
  • my i2s is still running fine.
    With the sensor I'm using I read 2 characteristics every 5 minutes.  On the pi I'm using I turn on an LED when it's connected and log time connect/disconnect times.  Reading 2 takes one second.  If it's taking long with your sensor, I'd suspect the sensor.
  • well i wrote another reply yesterday and it was rejected as spam. i "appealed" so if you see it later just ignore.
    looks like the f7p is still working fine after almost 3 days, so i have to assume the i2s doesn't like something that i'm doing.
    if your i2s is still working more than 2 days can you tell me if you do any of the following? i'll try without these starting now...
    - turn off phone connection, wrist heartrate, and wifi (the latter might only be on the f7p) - i did this on the i2s via power manager but on the f7p i had to use individual settings to keep the watchface on.
    - use the saved (to storage) scan result instead of re-scanning each time
    - read 3 characteristics some of the time (at least every 30 minutes). this takes nearly all 30 seconds of bg process on the i2s, sometimes more so it is killed - the f7p is a lot quicker at this so doesn't get killed much if at all.  i'll reduce it to 1 to test.
  • from first bg process when powered off and on again:
    memory: total: 28688, used: 15744, free: 12944
    last bg process memory status before hang:
  • Ok, after 12+ hours, everything is fine.  I moved the watch out of range for about 30 minutes, moved it back in range and it picked up as it should.
    The I2 devices have less memory for things like watch faces.  Are you sure you're not running into a problem with memory?  On a I2, the watch face I'm using to test is about 40k with the peak about 42k
