Acknowledged
Instinct 2S completely hangs with BLE bg wf
i'm developing a BLE background watchface and am seeing complete watch hangs on Instinct 2S after about 1 to 2 days of running the wf (and I believe FR 965M but I have stopped testing that due to its inadequate battery.)
i'm not sure which connect iq calls are causing this but i will try to gather more info. since it happens so infrequently (i've seen it at least 3 times and have never been able to get past 2 days of runtime so i'm sure i'll see it again), i'm starting this bug report now anyway to see if others have seen it.
the only thing i can do to the watch after the hang is hold the light button for a long time to power it down, it responds to nothing else and does not update the wf at all.
Parents
  • my i2s is still running fine.
    With the sensor I'm using I read 2 characteristics every 5 minutes.  On the pi I'm using I turn on an LED when it's connected and log time connect/disconnect times.  Reading 2 takes one second.  If it's taking long with your sensor, I'd suspect the sensor.
Comment
Children
No Data
