Acknowledged
Instinct 2S completely hangs with BLE bg wf
i'm developing a BLE background watchface and am seeing complete watch hangs on Instinct 2S after about 1 to 2 days of running the wf (and I believe FR 965M but I have stopped testing that due to its inadequate battery.)
i'm not sure which connect iq calls are causing this but i will try to gather more info. since it happens so infrequently (i've seen it at least 3 times and have never been able to get past 2 days of runtime so i'm sure i'll see it again), i'm starting this bug report now anyway to see if others have seen it.
the only thing i can do to the watch after the hang is hold the light button for a long time to power it down, it responds to nothing else and does not update the wf at all.
Parents Comment Children
  • Ok, after 12+ hours, everything is fine.  I moved the watch out of range for about 30 minutes, moved it back in range and it picked up as it should.
    The I2 devices have less memory for things like watch faces.  Are you sure you're not running into a problem with memory?  On a I2, the watch face I'm using to test is about 40k with the peak about 42k
