Acknowledged
CIQQA-3377
impossible to keep ANT+ sensors paired to the simulator
I'm running Connect IQ Device Simulator 8.2.2 the most recent version on my Mac, and I have a Garmin ANT+ stick.
I'm able to pair ANT+ sensors; but I have no idea how to keep them paired.
Currently the flow goes like this:
- Start datafield simulator
- Open Settings -> Manage Sensors menu
- Search and pair ANT+ sensors (this process kills the running app, but does allow me to pair the sensors).
- But now we have to somehow restart our app because the app is not running; so I kill the simulator and restart it
- Now my app is running but my ANT+ sensors are all in the "Disconnected" state. There is no obvious way to get them to search mode or reconnect without going through the same flow as before which will kill my app; clicking Unpair or RemoveAll will kill the app. Then I can repair the sensors but I will have to reboot the simulator to get my app running again and then it will not be disconnected.
Sometimes, with shear luck, when I restart the simulator my app will be successfully paired with the ANT+ sensor(s). No idea why this sometimes works, it's about 1 in 20. Makes it very cumbersome to test and develop locally. Am i doing something wrong? What is the recommended approach to get your app restarted after the pairing menu kills the app?
Parents
  • yes I reproduced this exact behavior; I think it's a bug
    Yeah, I guess there's some kind of communications issue with the sim. Probably when you press Run enough times, it finally forces the previous run attempt to finally go through, but then you have to cancel the final run attempt (unless you feel like waiting a few more seconds).
    Also not the best user experience.
Comment
Children
No Data
