Ticket Created
JAZZ-2917
Edge device crash on BLE
Hallo,
I've been working on a companion app for a BLE device and I have been experiencing a number of issues with device crashes, so the device restarting, not the standard CIQ error.
The device I am using for testing is an Edge 530. The issues happen both when the app is sideloaded as an app or a widget, but never occur in the simulator (not sure if you can even have that crash).
These issues mainly occur when leaving the app/widget shortly after having initiated pairing (device = Ble.pairDevice(result)), and happens both if the connection has been made and if not (onConnectedStateChanged( device, state ) triggered), but can also occur when changing quickly between the scanning and device views.
This also happens when using the Thingy 52 app, with some minor changes to run on the Edge 530 (exchanging the bitmaps with smaller ones) and changing the UUIDs to something that will find our devices.
So my question is first of all, are there known issues with the BLE that can cause device crashes (specifically on the Edge 530), and is there any way to debug this sort of error?
All the best, Jonas
Parents Comment Children
    Former Member in reply to jim_m_58
    So I cleared the err_log.txt before triggering it again, below are the results:
    "unit_id":"3304335715",
    "product_name":"Edge 530",
    "software_part_number":"006-B3121-00",
    "ms_since_epoch":1584102645000,
    "system_version":"5.34",
    "build_type":"PRODUCTION",
    "backtrace":"
    Function Address: 0x60187A3C
       Call Address at Function: 0x60187A84
    Function Address: 0x6029F548
       Call Address at Function: 0x6029F61A
    Function Address: 0x6029F6F8
       Call Address at Function: 0x6029F706
    Function Address: 0x601863E4
       Call Address at Function: 0x60186428
    Function Address: 0x60186998
       Call Address at Function: 0x60186A24
    Function Address: 0x60186BBC
       Call Address at Function: 0x60186C06
    Function Address: 0x60185038
       Call Address at Function: 0x60185266
    Function Address: 0x60185A30
       Call Address at Function: 0x60185A92
    Function Address: 0x60182CF0
       Call Address at Function: 0x60182D04
    Function Address: 0x6044E1E8
       Call Address at Function: 0x6044E2CA
    Function Address: 0x60762CF0
       Call Address at Function: 0x60762D10
    "error_cause":"RTL Trap",
    "proprietary_info":{
        "Commit ID":"6da9b741a485ad69a16dc5540d8aa6d582b74bde",
        "Time":"2020-3-13 13:30:45",
        "Ram Dump":"2",
        "ESht PC":"0x6030715D",
        "ESht SP":"0x621E2798",
        "Project Specific":"0x621E2798",
        "CDP_LOG":"605F08A1,6045AA15,6045B811,6045AA15,605D76A5,60211D59,601CCA2D,605D23F9,601CCA2D,601CCA2D,601CCA2D,60211D59,605D76A5,",
        "RTL Error Number":"6E5D8024",
        "Error Message":"00000006,00000000,0000000C,00000000,00000000,61E91CB0,00000006,00000060,60A2F3A0,00000000,62259A7C,00000002,D04C78CC,62259A08,601862D5,60187A84,000F003F",
        "Task Name":"wscm_ble_main",
        "Saved SP":"62259A08",
        "Saved LR":"601862D5",
        "Saved PC":"60187A84",
        "R[0]":"00000006",
        "R[1]":"00000000",
        "R[2]":"0000000C",
        "R[3]":"00000000",
        "R[4]":"00000000",
        "R[5]":"61E91CB0",
        "R[6]":"00000006",
        "R[7]":"00000060",
        "R[8]":"60A2F3A0",
        "R[9]":"00000000",
        "R[10]":"62259A7C",
        "R[11]":"00000002",
        "R[12]":"D04C78CC",
        "R[13]":"62259A08",
        "R[14]":"601862D5",
        "R[15]":"60187A84",
        "cpsr":"000F003F"
    Now hopefully this can provide the correct people with some context.
    Thanks for the input Thumbsup
