Complete
WERETECH-9595
Cannot Reproduce
Edge 1030plus makeImageRequest blue hue while activity is recording
I have had two reports from users of the Edge 1030 Plus that when they run my weather radar widget on their device, the image is displayed with a blue hue over the image.  One user has tracked down the issue only occurs when the device is actively recording a ride and provided these two pictures.  Both users appear to be on FW version 2.30.  So I don't know if this was fixed with version 3.0 or if this is something going on with the image processing server/GCM.  See the pictures.  I know I don't check for a running activity in my code and I only request and display the image as provided by the radar source, so I am at a loss as to how to troubleshoot this.
Activity not started (looks fine).
Activity being recorded (timer running)
Parents
  • We did have a partial misunderstanding, but thanks for clarifying.  You got the app.  Here is a static snapshot of the settings used to request the images in my widget for the Edge 1030 plus.  As you can see, on the Edge devices I don't use any palette options.
    imgurl = ciq.sabeard.net/.../rainviewer.php;
    imgparam= {lat=>38.852069, scwidth=>282, scheight=>419, zlevel=>9, lon=>-94.804038, tsoffset=>0};
    imgopt= null;
    Comm.makeImageRequest(imgurl, imgparam, imgopt, method(:onReceiveImage));
    While not the full app code, hopefully this will give you a better way to look into how I am using the makeImageRequest.  Let me know if you need more info.
Comment
    imgopt= null;
Children
  • The test group confirms that they tested the following scenarios with "the users test app" and were not able to reproduce:
    1. with wifi disabled on the edge; connected to mobile over BT/BLE
    2. with an activity recording in progress; connected to mobile over BT/BLE
    Let me see if there are some other strings I can pull to get another reproduction attempt.
