Complete
CIQSTORE-1573
Fixed
Details: "Could not find symbol '00800311'"
SDK 3.1.5 fails on real device (with old firmware) while SDK 3.1.4 works.
when using SDK 3.1.5 my connect iq background watchface app fails with Details: "Could not find symbol '00800311'"
the stack pc is always at the end of my view code, no matter what i try its not something the app is really doing.
Parents
  • You're trying to side-load an app on a device, right?
    If so, it is very likely that the problem is because the PRG is compiled to run on a device with support for the 3.1.4 SDK (which comes with the 4.90 firmware), but your device doesn't have that support.
    If you had uploaded the app to the store and tried to download it to your device, you would get a message that tells you that you need to update your device firmware. Since you're side-loading there is nothing to prevent you from doing this.
    If you really must use older firmware, you will need to use an SDK that builds PRG files that are compatible with that firmware. In the case of the vivoactive3/3m, you'd want to use the 3.1.4 SDK.
Comment
Children
