Complete
CIQSTORE-1573
Fixed
Details: "Could not find symbol '00800311'"
SDK 3.1.5 fails on real device (with old firmware) while SDK 3.1.4 works.
when using SDK 3.1.5 my connect iq background watchface app fails with Details: "Could not find symbol '00800311'"
the stack pc is always at the end of my view code, no matter what i try its not something the app is really doing.
  • I have the same problem. How to find out what '00800311' means? And how to check Memory Usage Stats?
  • I have the same problem, the only difference is symbol: I get "Could not find symbol '00000187'". I tried several SDK versions (including the latest) and I get the same error.
    1. How can I check Memory Usage Stats? Although I doubt the problem is memory...
    2. Is there any way to find out what does '00000187' mean? If not what's the point of this error message?
    ERA is also not very helpful...
  • I just don't use some old firmware versions with some new ask versions. If I want to try an old formate I'll rebuild on an older sdk and release it under a beta version app.
  • Hi,
    did you find a solution as I've same problem ?
    I'm having the same problem with a 6.6 firmware and the RaceQs app.
    Error: Symbol Not Found Error
    Time: 2019-12-12T10:47:06Z
    Part-Number: 006-B2700-00
    Firmware-Version: '6.60'
    Language-Code: eng
    ConnectIQ-Version: 3.1.5
    Store-Id: 74c474f8-4140-4794-afb7-f56817083bd5
    Store-Version: 16
    Filename: 9CC71426
    Appname: raceQs
    Stack:
      - pc: 0x1000fecc
    Time: 2019-12-12T11:05:20Z
    Language-Code: eng
    Store-Version: 16
    Filename: 9CC71426
    Appname: raceQs
    Stack:
      - pc: 0x1000fecc
