Hey,
I'm currently developing a Connect IQ app and I think I found a bug in the MonkeyC compilator. With the following code, the second line in the onStart method would be underlined with the error 'Attempting to perform container access on null.'. Trying to compile would result in the same issue. This is performed from the default widget template app with VSCode, SDK version 8.2.3 and trying to compile for device forerunner 955.
import Toybox.Application;
import Toybox.Lang;
import Toybox.WatchUi;
import Toybox.System;
class testApp extends Application.AppBase {
public static const RESOLUTION_MAP = {
1 => [:_4K, :_16R9],
4 => [:_2K7, :_16R9],
6 => [:_2K7, :_4R3],
7 => [:_1440, :_16R9],
9 => [:_1080, :_16R9],
function initialize() {
AppBase.initialize();
// onStart() is called on application start up
function onStart(state as Dictionary?) as Void {
var test = 1;
var result = RESOLUTION_MAP.get(test)[0];
System.println(result);
// onStop() is called when your application is exiting
function onStop(state as Dictionary?) as Void {
// Return the initial view of your application here
function getInitialView() as [Views] or [Views, InputDelegates] {
return [ new testView() ];
function getApp() as testApp {
return Application.getApp() as testApp;
I found a workaround by type checking the container access as followed so that I can compile my code, but I still get a compilation warning for the line within the if statement 'Statement is not reachable'. I checked in a test project, and the statement is actually reachable if the key provided exists in the const Dictionary RESOLUTION_MAP.
var resolution = RESOLUTION_MAP.get(setting);
if (resolution instanceof Symbol) {
System.println(RESOLUTION_LABELS.get(resolution[0]));
Don't hesitate to reach out to me if you need any other information to reproduce the issue !
flowstate
Cancel
Vote Up
0
Vote Down
More
Cancel
Comment-
flowstate
Cancel
Vote Up
0
Vote Down
More
Cancel
Children
