Acknowledged
CIQ Simulator crashes on Mac regularly
After keeping it running for a while and launching an app repeatedly over several hours, the simulator will inevitably crash.
I believe this has been happening ever since I started using a Mac (Apple silicon) for CIQ SDK almost 2 years ago.
That means with all the current Mac OS and CIQ SDK versions since that time.
No such problems with the same CIQ SDK version running on Windows.
Thread 28 Crashed:
0 ??? 0x7ff89446e9a8 ???
1 libsystem_kernel.dylib 0x7ff80510122a __pthread_kill + 10
2 libsystem_pthread.dylib 0x7ff805138f7b pthread_kill + 263
3 libsystem_c.dylib 0x7ff805082ca5 abort + 123
4 simulator 0x10231387d 0x102287000 + 575613
5 simulator 0x1023956ac 0x102287000 + 1107628
6 simulator 0x102b8d40c 0x102287000 + 9462796
7 simulator 0x102b8ce9f 0x102287000 + 9461407
8 libsystem_pthread.dylib 0x7ff805139259 _pthread_start + 125
9 libsystem_pthread.dylib 0x7ff805134c7b thread_start + 15
Thread 28 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x0000000000000000 rcx: 0x0000000000000000 rdx: 0x0000000000000000
rdi: 0x00007fa97becd6f0 rsi: 0x0000000000000003 rbp: 0x0000000000000000 rsp: 0x0000000000000000
r8: 0x0000000309c9e000 r9: 0x0000000000000000 r10: 0x0000000000000000 r11: 0x00007fa97bdca4c0
r12: 0x00000000000129a3 r13: 0x0000000309c9e000 r14: 0x0000000000000006 r15: 0x0000000000000016
rip: <unavailable> rfl: 0x0000000000000283
tmp0: 0xffffffffffffffff tmp1: 0x00007ff89446e97c tmp2: 0x00007ff805101220
Parents
  • The SDK 6.4.2 claims to have been made solely for the purpose of fixing crashes seen in macOS Sonoma.
    Unfortunately I do not see any improvement. It just keeps crashing, can't survive even a few hours.
    It is really sad, because the miserable quality of the simulator makes Mac pretty much useless for any serious Connect IQ development.
    I gave up and switched back to Windows.
    The crashing is not the only problem, although definitely the most troublesome.
    Another problem is that the entry fields for different parameters in the menus don't work properly.
    For example, try to enter Battery Percentage's decimal digit (e.g. 95.5) - it just won't let you. Same thing with walking and running step length in User Profile. But entering decimal point in Set Position menu works without issues.
    Another example in User Profile, when I try to enter Height and Weight, the next time I open it I see Height 243.0 cm and Weight 443.0 kg.
    There are minor issues too which are not critical, but contribute to the overall impression of very poor quality - for instance in View Memory window, the default Size column width is wrong, so you can't see it upon opening, you have to adjust it every time in order to see it.
    Below is my latest crash report.
    Translated Report (Full Report Below)
    Process: simulator [47810]
    Path: /Users/USER/Library/Application Support/Garmin/*/ConnectIQ.app/Contents/MacOS/simulator
    Identifier: com.garmin.connectiq.simulator
    Version: 6.4.2 (6.4.2)
    Code Type: X86-64 (Translated)
    Parent Process: launchd [1]
    User ID: 501
    Date/Time: 2024-03-20 17:22:55.6293 +0700
    OS Version: macOS 14.2.1 (23C71)
    Report Version: 12
    Anonymous UUID: 277CCC3B-2E88-EAA7-7D3F-B4E208A73F60
    Sleep/Wake UUID: AB63B6C3-867E-4F06-B276-6629ACF1A424
    Time Awake Since Boot: 400000 seconds
    Time Since Wake: 15 seconds
    System Integrity Protection: enabled
    Notes:
    PC register does not match crashing frame (0x0 vs 0x7FF8AA0CAA78)
    Crashed Thread: 6 ant_main
    Exception Type: EXC_CRASH (SIGABRT)
    Exception Codes: 0x0000000000000000, 0x0000000000000000
    Termination Reason: Namespace SIGNAL, Code 6 Abort trap: 6
    Terminating Process: simulator [47810]
    Application Specific Information:
    abort() called
    Error Formulating Crash Report:
    Thread 0:: Dispatch queue: com.apple.main-thread
    0 AppKit 0x7ff81d1957b9 _DPSNextEvent + 880
    1 AppKit 0x7ff81da8df64 -[NSApplication(NSEventRouting) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1304
    2 AppKit 0x7ff81d186d32 -[NSApplication run] + 603
    3 simulator 0x102eb92fa 0x102445000 + 10961658
    4 simulator 0x102db8e0d 0x102445000 + 9911821
    5 simulator 0x102d2a97e 0x102445000 + 9329022
    6 simulator 0x102cfd293 0x102445000 + 9142931
    7 simulator 0x102e758da 0x102445000 + 10684634
    8 simulator 0x102d5fad8 0x102445000 + 9546456
    9 simulator 0x102486f12 0x102445000 + 270098
    10 dyld 0x203aba386 start + 1942
    Thread 1:: com.apple.rosetta.exceptionserver
    0 runtime 0x7ff7ffe98294 0x7ff7ffe94000 + 17044
    Thread 2:: com.apple.NSEventThread
    0 ??? 0x7ff8aa0caa78 ???
    1 libsystem_kernel.dylib 0x7ff819b0ba2e mach_msg2_trap + 10
    2 libsystem_kernel.dylib 0x7ff819b19e3a mach_msg2_internal + 84
    3 libsystem_kernel.dylib 0x7ff819b12b62 mach_msg_overwrite + 653
    4 libsystem_kernel.dylib 0x7ff819b0bd1f mach_msg + 19
    5 CoreFoundation 0x7ff819c27909 __CFRunLoopServiceMachPort + 143
    6 CoreFoundation 0x7ff819c2637c __CFRunLoopRun + 1371
    7 CoreFoundation 0x7ff819c25859 CFRunLoopRunSpecific + 557
    8 AppKit 0x7ff81d2f2fac _NSEventThread + 122
    9 libsystem_pthread.dylib 0x7ff819b4b202 _pthread_start + 99
    10 libsystem_pthread.dylib 0x7ff819b46bab thread_start + 15
    Thread 3:: TSK bkgd
    1 libsystem_kernel.dylib 0x7ff819b0e5ce __psynch_cvwait + 10
    2 libsystem_pthread.dylib 0x7ff819b4b76b _pthread_cond_wait + 1211
    3 simulator 0x102bd17ba 0x102445000 + 7915450
    4 simulator 0x102bd0a72 0x102445000 + 7912050
    5 libsystem_pthread.dylib 0x7ff819b4b202 _pthread_start + 99
    6 libsystem_pthread.dylib 0x7ff819b46bab thread_start + 15
    Thread 4:: NFM_Region_0
    4 simulator 0x102c45e93 0x102445000 + 8392339
    5 simulator 0x102bd0aa6 0x102445000 + 7912102
    6 libsystem_pthread.dylib 0x7ff819b4b202 _pthread_start + 99
    7 libsystem_pthread.dylib 0x7ff819b46bab thread_start + 15
    Thread 5:: IOPAppMain
    4 simulator 0x102943115 0x102445000 + 5234965
    5 simulator 0x102bd0a90 0x102445000 + 7912080
    Thread 6 Crashed:: ant_main
    1 libsystem_kernel.dylib 0x7ff819b127a2 __pthread_kill + 10
    2 libsystem_pthread.dylib 0x7ff819b4af30 pthread_kill + 262
    3 libsystem_c.dylib 0x7ff819a69a49 abort + 126
    4 simulator 0x1024e3168 0x102445000 + 647528
    5 simulator 0x1030c2b59 0x102445000 + 13097817
    6 simulator 0x1024e2e60 0x102445000 + 646752
    7 simulator 0x102bd4bb2 0x102445000 + 7928754
    8 simulator 0x102bd43b9 0x102445000 + 7926713
    9 simulator 0x102bd97d8 0x102445000 + 7948248
    10 simulator 0x102900447 0x102445000 + 4961351
    11 simulator 0x1029182be 0x102445000 + 5059262
    12 simulator 0x102bd0a90 0x102445000 + 7912080
    13 libsystem_pthread.dylib 0x7ff819b4b202 _pthread_start + 99
    14 libsystem_pthread.dylib 0x7ff819b46bab thread_start + 15
    Thread 7:: GPS main
    Thread 8:: SNS main
    Thread 9:: fit activity
    4 simulator 0x102982562 0x102445000 + 5494114
    Thread 10:: ftm main
    0 simulator 0x102928d10 0x102445000 + 5127440
    1 simulator 0x102c9c8d2 0x102445000 + 8747218
    2 simulator 0x102997497 0x102445000 + 5579927
    3 simulator 0x102991caa 0x102445000 + 5557418
    4 simulator 0x102bd0a90 0x102445000 + 7912080
    Thread 11:: TVM main
    4 simulator 0x102b798d5 0x102445000 + 7555285
    Thread 12:: TVM defrag
    Thread 13:: parse main
    4 simulator 0x10246726b 0x102445000 + 139883
    Thread 14:: GPX archive trk
    4 simulator 0x102c56df5 0x102445000 + 8461813
    Thread 15:: URM Main
    4 simulator 0x102965925 0x102445000 + 5376293
    Thread 16:: mma sql bkg
    Thread 17:: TLG main
    2 libsystem_pthread.dylib 0x7ff819b4b79c _pthread_cond_wait + 1260
    3 simulator 0x102bd0550 0x102445000 + 7910736
    4 simulator 0x102bd17ba 0x102445000 + 7915450
    5 simulator 0x102c56c1e 0x102445000 + 8461342
    6 simulator 0x102bd0aa6 0x102445000 + 7912102
    7 libsystem_pthread.dylib 0x7ff819b4b202 _pthread_start + 99
    8 libsystem_pthread.dylib 0x7ff819b46bab thread_start + 15
    Thread 18:: libcurl Async H
    4 simulator 0x10295f3b5 0x102445000 + 5350325
    Thread 19:: Download Manage
    4 simulator 0x102961905 0x102445000 + 5359877
    Thread 20:: Shell main
    1 libsystem_kernel.dylib 0x7ff819b12832 __accept + 10
    2 simulator 0x102c51af2 0x102445000 + 8440562
    3 simulator 0x102c4e8f7 0x102445000 + 8427767
    Thread 21:
    3 libc++.1.dylib 0x7ff819a833c2 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18
    4 simulator 0x102510182 0x102445000 + 831874
    5 simulator 0x10251007f 0x102445000 + 831615
    6 simulator 0x10250ff22 0x102445000 + 831266
    Thread 22:
    2 simulator 0x1025732bc 0x102445000 + 1237692
    3 simulator 0x10254728c 0x102445000 + 1057420
    4 simulator 0x102dcbdbc 0x102445000 + 9989564
    5 simulator 0x102dcb84f 0x102445000 + 9988175
    Thread 23:: Shell handler
    3 simulator 0x102bd02ec 0x102445000 + 7910124
    4 simulator 0x102572824 0x102445000 + 1234980
    5 simulator 0x102c5186a 0x102445000 + 8439914
    6 simulator 0x102c50dc3 0x102445000 + 8437187
    7 simulator 0x102c4f257 0x102445000 + 8430167
    8 simulator 0x102bd0a90 0x102445000 + 7912080
    Thread 24:
    1 libsystem_kernel.dylib 0x7ff819b0f13a __recvfrom + 10
    2 simulator 0x102c51ed1 0x102445000 + 8441553
    3 simulator 0x102c50e62 0x102445000 + 8437346
    4 simulator 0x10256feaa 0x102445000 + 1224362
    5 simulator 0x1025777ff 0x102445000 + 1255423
    6 simulator 0x102dcbdbc 0x102445000 + 9989564
    7 simulator 0x102dcb84f 0x102445000 + 9988175
    8 libsystem_pthread.dylib 0x7ff819b4b202 _pthread_start + 99
    9 libsystem_pthread.dylib 0x7ff819b46bab thread_start + 15
    Thread 25:
    3 simulator 0x102dc967d 0x102445000 + 9979517
    4 simulator 0x10258daf6 0x102445000 + 1346294
    5 simulator 0x10258d680 0x102445000 + 1345152
    6 simulator 0x1025777ff 0x102445000 + 1255423
    7 simulator 0x102dcbdbc 0x102445000 + 9989564
    8 simulator 0x102dcb84f 0x102445000 + 9988175
    Thread 26:
    0 runtime 0x7ff7ffeb694c 0x7ff7ffe94000 + 141644
    Thread 27:
    Thread 28:: Dispatch queue: com.Metal.DeviceDispatchQueue
    0 IOGPU 0x7ff919d9782d IOGPUResourceSetPurgeable + 9
    1 IOGPU 0x7ff919d919c2 -[IOGPUMetalResource setPurgeableState:] + 212
    2 IOGPU 0x7ff919d925a3 -[IOGPUMetalResourcePool updateResourcePurgeability] + 159
    3 IOGPU 0x7ff919d8affb -[IOGPUMetalDevice updateResourcePoolPurgeability] + 71
    4 IOGPU 0x7ff919d8a0be -[IOGPUMetalDevice periodicUpdateResourcePoolPurgeability] + 68
    5 libdispatch.dylib 0x7ff8199a359a _dispatch_client_callout + 8
    6 libdispatch.dylib 0x7ff8199a60c7 _dispatch_continuation_pop + 523
    7 libdispatch.dylib 0x7ff8199b66f8 _dispatch_source_invoke + 2076
    8 libdispatch.dylib 0x7ff8199a94bb _dispatch_lane_serial_drain + 387
    9 libdispatch.dylib 0x7ff8199aa100 _dispatch_lane_invoke + 377
    10 libdispatch.dylib 0x7ff8199b3aee _dispatch_root_queue_drain_deferred_wlh + 271
    11 libdispatch.dylib 0x7ff8199b33fd _dispatch_workloop_worker_thread + 451
    12 libsystem_pthread.dylib 0x7ff819b47c47 _pthread_wqthread + 327
    13 libsystem_pthread.dylib 0x7ff819b46b97 start_wqthread + 15
    Thread 29:: Dispatch queue: com.Metal.DeviceDispatch
    0 IOKit 0x7ff81d035477 __IONotificationPortSetDispatchQueue_block_invoke + 4
    1 libdispatch.dylib 0x7ff8199a359a _dispatch_client_callout + 8
    2 libdispatch.dylib 0x7ff8199a60c7 _dispatch_continuation_pop + 523
    3 libdispatch.dylib 0x7ff8199b66f8 _dispatch_source_invoke + 2076
    4 libdispatch.dylib 0x7ff8199a94bb _dispatch_lane_serial_drain + 387
    5 libdispatch.dylib 0x7ff8199aa100 _dispatch_lane_invoke + 377
    6 libdispatch.dylib 0x7ff8199b3aee _dispatch_root_queue_drain_deferred_wlh + 271
    7 libdispatch.dylib 0x7ff8199b33fd _dispatch_workloop_worker_thread + 451
    8 libsystem_pthread.dylib 0x7ff819b47c47 _pthread_wqthread + 327
    9 libsystem_pthread.dylib 0x7ff819b46b97 start_wqthread + 15
    Thread 30:
    Thread 6 crashed with X86 Thread State (64-bit):
    rdi: 0x000000010357a828 rsi: 0x000000030a4af000 rbp: 0x0000000000000000 rsp: 0x0000000000000000
    r8: 0x000000030a4ae588 r9: 0x0000000000000000 r10: 0x0000000000000000 r11: 0x0000000000000043
    r12: 0x000000000000ad03 r13: 0x0000000000000000 r14: 0x000000030a4af000 r15: 0x0000000000000016
    rip: <unavailable> rfl: 0x0000000000000287
    tmp0: 0xffffffffffffffff tmp1: 0x00007ff8aa0caa4c tmp2: 0x00007ff819b12798
    Binary Images:
    0x203ab4000 - 0x203b53fff dyld (*) <ab17bf63-259b-3b48-8d70-863166a2191c> /usr/lib/dyld
    0x10d586000 - 0x10d595fff libobjc-trampolines.dylib (*) <c35523ac-5fc8-3185-b4fb-28be5af3f218> /usr/lib/libobjc-trampolines.dylib
    0x7ff7ffe94000 - 0x7ff7ffec3fff runtime (*) <c4c97159-5c72-3e75-ba2d-d6ca98ea626f> /usr/libexec/rosetta/runtime
    0x10cd8d000 - 0x10cde0fff libRosettaRuntime (*) <7af8ba1e-5c4d-393d-99cd-92566f60c450> /Library/Apple/*/libRosettaRuntime
    0x102445000 - 0x103410fff com.garmin.connectiq.simulator (6.4.2) <8b447e7e-4cdb-3243-926d-9048585fcb2c> /Users/USER/Library/Application Support/Garmin/*/ConnectIQ.app/Contents/MacOS/simulator
    0x7ff81d157000 - 0x7ff81e563ffb com.apple.AppKit (6.9) <20292f0b-3eb2-3566-91e2-ea657457d71d> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ???
    0x7ff819b0a000 - 0x7ff819b44ff7 libsystem_kernel.dylib (*) <9927a0a9-dfa8-3ffa-88d8-62055f37a137> /usr/lib/system/libsystem_kernel.dylib
    0x7ff819bab000 - 0x7ff81a044ffc com.apple.CoreFoundation (6.9) <fd59424c-be72-3201-b98c-0421b284ffbb> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x7ff819b45000 - 0x7ff819b50fff libsystem_pthread.dylib (*) <a9ba8a53-d774-3fe9-8bde-64187bff7ea9> /usr/lib/system/libsystem_pthread.dylib
    0x7ff8199ea000 - 0x7ff819a71fff libsystem_c.dylib (*) <29a0020e-3766-39df-80fe-9aa731847daa> /usr/lib/system/libsystem_c.dylib
    0x7ff819a72000 - 0x7ff819af0fff libc++.1.dylib (*) <c4311955-de8c-341a-bf4e-46f9a9b26d7a> /usr/lib/libc++.1.dylib
    0x7ff919d80000 - 0x7ff919db7ff1 com.apple.IOGPU (93.10.1) <34e8d18c-7efd-3f68-a802-4f73a4382deb> /System/Library/PrivateFrameworks/IOGPU.framework/Versions/A/IOGPU
    0x7ff8199a0000 - 0x7ff8199e6ffd libdispatch.dylib (*) <895cad19-704c-3ff8-b148-23689a163b12> /usr/lib/system/libdispatch.dylib
    0x7ff81d030000 - 0x7ff81d0f2ff7 com.apple.framework.IOKit (2.0.2) <d556ec12-074c-30d8-958e-7b88c4b1178c> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    External Modification Summary:
    Calls made by other processes targeting this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
    Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
    Calls made by all processes on this machine:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
    VM Region Summary:
    ReadOnly portion of Libraries: Total=794.9M resident=0K(0%) swapped_out_or_unallocated=794.9M(100%)
    Writable regions: Total=1.4G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.4G(100%)
    VIRTUAL REGION
    REGION TYPE SIZE COUNT (non-coalesced)
    Accelerate framework 256K 2
    Activity Tracing 256K 1
    CG image 3220K 40
    CG raster data 2232K 2
    ColorSync 252K 33
    CoreAnimation 4804K 50
    CoreGraphics 12K 2
    CoreUI image data 2932K 22
    Dispatch continuations 64.0M 1
    Foundation 40K 2
    Kernel Alloc Once 8K 1
    MALLOC 1.1G 63
    MALLOC guard page 192K 12
    Rosetta Arena 4096K 2
    Rosetta Generic 1792K 445
    Rosetta IndirectBranch 1024K 1
    Rosetta JIT 128.0M 1
    Rosetta Return Stack 600K 60
    Rosetta Thread Context 600K 60
    STACK GUARD 12K 3
    Stack 22.8M 33
    Stack Guard 56.1M 27
    VM_ALLOCATE 4804K 14
    VM_ALLOCATE (reserved) 4K 1 reserved VM address space (unallocated)
    __CTF 824 1
    __DATA 32.5M 539
    __DATA_CONST 36.6M 341
    __DATA_DIRTY 1523K 177
    __FONT_DATA 2352 1
    __INFO_FILTER 8 1
    __LINKEDIT 144.3M 10
    __OBJC_RO 71.1M 1
    __OBJC_RW 2166K 3
    __TEXT 650.6M 559
    dyld private memory 260K 2
    mapped file 7.2G 875
    shared memory 816K 17
    unshared pmap 14.6M 10
    TOTAL 9.5G 3415
    TOTAL, minus reserved VM space 9.5G 3415
    Full Report
    {"app_name":"simulator","timestamp":"2024-03-20 17:22:59.00 +0700","app_version":"6.4.2","slice_uuid":"8b447e7e-4cdb-3243-926d-9048585fcb2c","build_version":"6.4.2","platform":1,"bundleID":"com.garmin.connectiq.simulator","share_with_app_devs":1,"is_first_party":0,"bug_type":"309","os_version":"macOS 14.2.1 (23C71)","roots_installed":0,"name":"simulator","incident_id":"2087872B-B054-4E13-A11B-C2DBCF820703"}
    "uptime" : 400000,
    "procRole" : "Background",
    "version" : 2,
    "userID" : 501,
    "deployVersion" : 210,
    "modelCode" : "MacBookAir10,1",
    "coalitionID" : 12834,
    "osVersion" : {
    "train" : "macOS 14.2.1",
    "build" : "23C71",
    "releaseType" : "User"
    "captureTime" : "2024-03-20 17:22:55.6293 +0700",
    "codeSigningMonitor" : 1,
    "incident" : "2087872B-B054-4E13-A11B-C2DBCF820703",
    "pid" : 47810,
    "translated" : true,
    "cpuType" : "X86-64",
    "roots_installed" : 0,
    "bug_type" : "309",
    "procLaunch" : "2024-03-20 11:50:58.0600 +0700",
    "procStartAbsTime" : 9188334550025,
    "procExitAbsTime" : 9616875107620,
    "procName" : "simulator",
    "procPath" : "\/Users\/USER\/Library\/Application Support\/Garmin\/*\/ConnectIQ.app\/Contents\/MacOS\/simulator",
    "bundleInfo" : {"CFBundleShortVersionString":"6.4.2","CFBundleVersion":"6.4.2","CFBundleIdentifier":"com.garmin.connectiq.simulator"},
    "storeInfo" : {"deviceIdentifierForVendor":"8328F350-2F45-5923-BD5F-2C5ABB306647","thirdParty":true},
    "parentProc" : "launchd",
    "parentPid" : 1,
    "coalitionName" : "com.garmin.connectiq.simulator",
    "crashReporterKey" : "277CCC3B-2E88-EAA7-7D3F-B4E208A73F60",
    "lowPowerMode" : 1,
    "codeSigningID" : "com.garmin.connectiq.simulator",
    "codeSigningTeamID" : "72ES32VZUA",
    "codeSigningFlags" : 570503953,
    "codeSigningValidationCategory" : 6,
    "codeSigningTrustLevel" : 4294967295,
    "wakeTime" : 15,
    "sleepWakeUUID" : "AB63B6C3-867E-4F06-B276-6629ACF1A424",
    "sip" : "enabled",
    "exception" : {"codes":"0x0000000000000000, 0x0000000000000000","rawCodes":[0,0],"type":"EXC_CRASH","signal":"SIGABRT"},
    "termination" : {"flags":0,"code":6,"namespace":"SIGNAL","indicator":"Abort trap: 6","byProc":"simulator","byPid":47810},
    "asi" : {"libsystem_c.dylib":["abort() called"]},
    "extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
    "faultingThread" : 6,
    "threads" : [{"id":2963658,"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":13052673568},"r12":{"value":0},"rosetta":{"tmp2":{"value":140706060075144},"tmp1":{"value":140703616817081},"tmp0":{"value":140703616817081}},"rbx":{"value":0},"r8":{"value":2963658},"r15":{"value":140704689010312,"symbolLocation":0,"symbol":"_NSConcreteStackBlock"},"r10":{"value":0},"rdx":{"value":140704658355969,"symbolLocation":1,"symbol":"__CFOASafe"},"rdi":{"value":140648009254592},"r9":{"value":18446744069414584320},"r13":{"value":18446744073709551615},"rflags":{"value":514},"rax":{"value":1},"rsp":{"value":13052672592},"r11":{"value":701696},"rcx":{"value":281474976733568},"r14":{"value":140704631175752},"rsi":{"value":140704658355992,"symbolLocation":0,"symbol":"__CFRuntimeClassTables"}},"queue":"com.apple.main-thread","frames":[{"imageOffset":255929,"symbol":"_DPSNextEvent","symbolLocation":880,"imageIndex":5},{"imageOffset":9662308,"symbol":"-[NSApplication(NSEventRouting) _nextEventMatchingEventMask:untilDate:inMode:dequeue:]","symbolLocation":1304,"imageIndex":5},{"imageOffset":195890,"symbol":"-[NSApplication run]","symbolLocation":603,"imageIndex":5},{"imageOffset":10961658,"imageIndex":4},{"imageOffset":9911821,"imageIndex":4},{"imageOffset":9329022,"imageIndex":4},{"imageOffset":9142931,"imageIndex":4},{"imageOffset":10684634,"imageIndex":4},{"imageOffset":9546456,"imageIndex":4},{"imageOffset":270098,"imageIndex":4},{"imageOffset":25478,"symbol":"start","symbolLocation":1942,"imageIndex":0}]},{"id":2963667,"name":"com.apple.rosetta.exceptionserver","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":9908489551872},"r12":{"value":0},"rosetta":{"tmp2":{"value":0},"tmp1":{"value":0},"tmp0":{"value":0}},"rbx":{"value":0},"r8":{"value":2307},"r15":{"value":0},"r10":{"value":4510958404},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":4510958436},"r13":{"value":0},"rflags":{"value":515},"rax":{"value":268451845},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":17314086914},"r14":{"value":0},"rsi":{"value":2616}},"frames":[{"imageOffset":17044,"imageIndex":2}]},{"id":2963777,"name":"com.apple.NSEventThread","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":162757785681920},"r12":{"value":4294967295},"rosetta":{"tmp2":{"value":140703559687738},"tmp1":{"value":140705981573992},"tmp0":{"value":18446744073709551615}},"rbx":{"value":162757785681920},"r8":{"value":0},"r15":{"value":162757785681920},"r10":{"value":162757785681920},"rdx":{"value":8589934592},"rdi":{"value":4294967295},"r9":{"value":162757785681920},"r13":{"value":21592279046},"rflags":{"value":643},"rax":{"value":268451845},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":21592279046},"r14":{"value":2},"rsi":{"value":2}},"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":6702,"symbol":"mach_msg2_trap","symbolLocation":10,"imageIndex":7},{"imageOffset":65082,"symbol":"mach_msg2_internal","symbolLocation":84,"imageIndex":7},{"imageOffset":35682,"symbol":"mach_msg_overwrite","symbolLocation":653,"imageIndex":7},{"imageOffset":7455,"symbol":"mach_msg","symbolLocation":19,"imageIndex":7},{"imageOffset":510217,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":143,"imageIndex":8},{"imageOffset":504700,"symbol":"__CFRunLoopRun","symbolLocation":1371,"imageIndex":8},{"imageOffset":501849,"symbol":"CFRunLoopRunSpecific","symbolLocation":557,"imageIndex":8},{"imageOffset":1687468,"symbol":"_NSEventThread","symbolLocation":122,"imageIndex":5},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}]},{"id":2963778,"name":"TSK bkgd","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703559640516},"tmp1":{"value":140705981573708},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703559897549,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13055975424},"rsi":{"value":0}},"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":17870,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":7},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":9},{"imageOffset":7915450,"imageIndex":4},{"imageOffset":7912050,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}]},{"id":2963779,"name":"NFM_Region_0","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703559640516},"tmp1":{"value":140705981573708},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703559897549,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":12288},"r10":{"value":0},"rdx":{"value":12288},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":52780853113088},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":768},"rcx":{"value":0},"r14":{"value":13056512000},"rsi":{"value":0}},"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":17870,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":7},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":9},{"imageOffset":7915450,"imageIndex":4},{"imageOffset":8392339,"imageIndex":4},{"imageOffset":7912102,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}]},{"id":2963780,"name":"IOPAppMain","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703559640516},"tmp1":{"value":140705981573708},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703559897549,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13057048576},"rsi":{"value":0}},"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":17870,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":7},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":9},{"imageOffset":7915450,"imageIndex":4},{"imageOffset":5234965,"imageIndex":4},{"imageOffset":7912080,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}]},{"triggered":true,"id":2963781,"name":"ant_main","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":0},"r12":{"value":44291},"rosetta":{"tmp2":{"value":140703559657368},"tmp1":{"value":140705981573708},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":13057582472},"r15":{"value":22},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":4351043624},"r9":{"value":0},"r13":{"value":0},"rflags":{"value":647},"rax":{"value":0},"rsp":{"value":0},"r11":{"value":67},"rcx":{"value":0},"r14":{"value":13057585152},"rsi":{"value":13057585152}},"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":34722,"symbol":"__pthread_kill","symbolLocation":10,"imageIndex":7},{"imageOffset":24368,"symbol":"pthread_kill","symbolLocation":262,"imageIndex":9},{"imageOffset":522825,"symbol":"abort","symbolLocation":126,"imageIndex":10},{"imageOffset":647528,"imageIndex":4},{"imageOffset":13097817,"imageIndex":4},{"imageOffset":646752,"imageIndex":4},{"imageOffset":7928754,"imageIndex":4},{"imageOffset":7926713,"imageIndex":4},{"imageOffset":7948248,"imageIndex":4},{"imageOffset":4961351,"imageIndex":4},{"imageOffset":5059262,"imageIndex":4},{"imageOffset":7912080,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}]},{"id":2963782,"name":"GPS main","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703559640516},"tmp1":{"value":140705981573708},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703559897549,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13058121728},"rsi":{"value":0}},"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":17870,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":7},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":9},{"imageOffset":7915450,"imageIndex":4},{"imageOffset":7912050,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}]},{"id":2963783,"name":"SNS main","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703559640516},"tmp1":{"value":140705981573708},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703559897549,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13058658304},"rsi":{"value":0}},"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":17870,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":7},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":9},{"imageOffset":7915450,"imageIndex":4},{"imageOffset":7912050,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}]},{"id":2963784,"name":"fit activity","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703559640516},"tmp1":{"value":140705981573708},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703559897549,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":256},"r10":{"value":0},"rdx":{"value":256},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":1103806595584},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13059194880},"rsi":{"value":0}},"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":17870,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":7},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":9},{"imageOffset":7915450,"imageIndex":4},{"imageOffset":5494114,"imageIndex":4},{"imageOffset":7912080,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}]},{"id":2963785,"name":"ftm main","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":13059729568},"r12":{"value":255},"rosetta":{"tmp2":{"value":4361048740},"tmp1":{"value":4377748320},"tmp0":{"value":4338126096}},"rbx":{"value":8},"r8":{"value":18},"r15":{"value":17837311},"r10":{"value":0},"rdx":{"value":1},"rdi":{"value":30},"r9":{"value":4294967295},"r13":{"value":0},"rflags":{"value":518},"rax":{"value":4337942002},"rsp":{"value":13059729544},"r11":{"value":0},"rcx":{"value":4337942080},"r14":{"value":144},"rsi":{"value":0}},"frames":[{"imageOffset":5127440,"imageIndex":4},{"imageOffset":8747218,"imageIndex":4},{"imageOffset":5579927,"imageIndex":4},{"imageOffset":5557418,"imageIndex":4},{"imageOffset":7912080,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}]},{"id":2963786,"name":"TVM main","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703559640516},"tmp1":{"value":140705981573708},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703559897549,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":4352},"r10":{"value":0},"rdx":{"value":4352},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":18695992644096},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13060268032},"rsi":{"value":0}},"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":17870,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":7},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":9},{"imageOffset":7915450,"imageIndex":4},{"imageOffset":7555285,"imageIndex":4},{"imageOffset":7912080,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}]},{"id":2963787,"name":"TVM defrag","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703559640516},"tmp1":{"value":140705981573708},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703559897549,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13060804608},"rsi":{"value":0}},"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":17870,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":7},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":9},{"imageOffset":7915450,"imageIndex":4},{"imageOffset":7912050,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}]},{"id":2963797,"name":"parse main","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703559640516},"tmp1":{"value":140705981573708},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703559897549,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13061341184},"rsi":{"value":0}},"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":17870,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":7},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":9},{"imageOffset":7915450,"imageIndex":4},{"imageOffset":139883,"imageIndex":4},{"imageOffset":7912080,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}]},{"id":2963798,"name":"GPX archive trk","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703559640516},"tmp1":{"value":140705981573708},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703559897549,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":256},"r10":{"value":0},"rdx":{"value":256},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":1103806595584},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13061877760},"rsi":{"value":0}},"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":17870,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":7},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":9},{"imageOffset":7915450,"imageIndex":4},{"imageOffset":8461813,"imageIndex":4},{"imageOffset":7912080,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}]},{"id":2963799,"name":"URM Main","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703559640516},"tmp1":{"value":140705981573708},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703559897549,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":256},"r10":{"value":0},"rdx":{"value":256},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":1103806595584},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13062414336},"rsi":{"value":0}},"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":17870,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":7},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":9},{"imageOffset":7915450,"imageIndex":4},{"imageOffset":5376293,"imageIndex":4},{"imageOffset":7912080,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}]},{"id":2963800,"name":"mma sql bkg","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703559640516},"tmp1":{"value":140705981573708},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703559897549,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13062950912},"rsi":{"value":0}},"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":17870,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":7},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":9},{"imageOffset":7915450,"imageIndex":4},{"imageOffset":7912050,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}]},{"id":2963802,"name":"TLG main","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":999974000},"rosetta":{"tmp2":{"value":140703559640516},"tmp1":{"value":140705981573708},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":13064023688},"r15":{"value":256},"r10":{"value":0},"rdx":{"value":256},"rdi":{"value":999974000},"r9":{"value":65704},"r13":{"value":1103806595584},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":512},"rsi":{"value":43740}},"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":17870,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":7},{"imageOffset":26524,"symbol":"_pthread_cond_wait","symbolLocation":1260,"imageIndex":9},{"imageOffset":7910736,"imageIndex":4},{"imageOffset":7915450,"imageIndex":4},{"imageOffset":8461342,"imageIndex":4},{"imageOffset":7912102,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}]},{"id":2963803,"name":"libcurl Async H","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703559640516},"tmp1":{"value":140705981573708},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703559897549,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13064560640},"rsi":{"value":0}},"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":17870,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":7},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":9},{"imageOffset":7915450,"imageIndex":4},{"imageOffset":5350325,"imageIndex":4},{"imageOffset":7912102,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}]},{"id":2963804,"name":"Download Manage","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703559640516},"tmp1":{"value":140705981573708},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703559897549,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13065097216},"rsi":{"value":0}},"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":17870,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":7},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":9},{"imageOffset":7915450,"imageIndex":4},{"imageOffset":5359877,"imageIndex":4},{"imageOffset":7912102,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}]},{"id":2963805,"name":"Shell main","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":4286709759},"r12":{"value":140648007806520},"rosetta":{"tmp2":{"value":140703559657512},"tmp1":{"value":140705981573708},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":0},"r15":{"value":140647462915408},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":4351622168},"r9":{"value":4286709759},"r13":{"value":4351621792},"rflags":{"value":646},"rax":{"value":4},"rsp":{"value":3566},"r11":{"value":4286578688},"rcx":{"value":0},"r14":{"value":4351621920},"rsi":{"value":140647462917408}},"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":34866,"symbol":"__accept","symbolLocation":10,"imageIndex":7},{"imageOffset":8440562,"imageIndex":4},{"imageOffset":8427767,"imageIndex":4},{"imageOffset":7912080,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}]},{"id":2963811,"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":17870,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":7},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":9},{"imageOffset":70594,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":18,"imageIndex":11},{"imageOffset":831874,"imageIndex":4},{"imageOffset":831615,"imageIndex":4},{"imageOffset":831266,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":160},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703559640516},"tmp1":{"value":140705981573708},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703559897549,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":160},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13066706944},"rsi":{"value":0}}},{"id":2963813,"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":34866,"symbol":"__accept","symbolLocation":10,"imageIndex":7},{"imageOffset":1237692,"imageIndex":4},{"imageOffset":1057420,"imageIndex":4},{"imageOffset":9989564,"imageIndex":4},{"imageOffset":9988175,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":5742},"r12":{"value":4334056224},"rosetta":{"tmp2":{"value":140703559657512},"tmp1":{"value":140705981573708},"tmp0":{"value":18446744073709551615}},"rbx":{"value":13067242888},"r8":{"value":13067243024},"r15":{"value":4351065016},"r10":{"value":13067242888},"rdx":{"value":0},"rdi":{"value":140648007539632},"r9":{"value":5742},"r13":{"value":13067243520},"rflags":{"value":646},"rax":{"value":4},"rsp":{"value":1},"r11":{"value":4294967168},"rcx":{"value":0},"r14":{"value":140648007539632},"rsi":{"value":140648007539568}}},{"id":2964406,"name":"Shell handler","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703559640516},"tmp1":{"value":140705981573708},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703559897549,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13053767680},"rsi":{"value":0}},"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":17870,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":7},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":9},{"imageOffset":7910124,"imageIndex":4},{"imageOffset":1234980,"imageIndex":4},{"imageOffset":8439914,"imageIndex":4},{"imageOffset":8437187,"imageIndex":4},{"imageOffset":8430167,"imageIndex":4},{"imageOffset":7912080,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}]},{"id":2964407,"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":20794,"symbol":"__recvfrom","symbolLocation":10,"imageIndex":7},{"imageOffset":8441553,"imageIndex":4},{"imageOffset":8437346,"imageIndex":4},{"imageOffset":1224362,"imageIndex":4},{"imageOffset":1255423,"imageIndex":4},{"imageOffset":9989564,"imageIndex":4},{"imageOffset":9988175,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":0},"r12":{"value":12},"rosetta":{"tmp2":{"value":140703559643440},"tmp1":{"value":140705981573708},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":13066169628},"r15":{"value":140647460833264},"r10":{"value":0},"rdx":{"value":12},"rdi":{"value":140647460833312},"r9":{"value":0},"r13":{"value":13066169601},"rflags":{"value":646},"rax":{"value":4},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":140647460833312},"rsi":{"value":140647460833264}}},{"id":2964434,"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":17870,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":7},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":9},{"imageOffset":9979517,"imageIndex":4},{"imageOffset":1346294,"imageIndex":4},{"imageOffset":1345152,"imageIndex":4},{"imageOffset":1255423,"imageIndex":4},{"imageOffset":9989564,"imageIndex":4},{"imageOffset":9988175,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":4256},"r12":{"value":999388000},"rosetta":{"tmp2":{"value":140703559640516},"tmp1":{"value":140705981573708},"tmp0":{"value":18446744073709551615}},"rbx":{"value":140648007865600},"r8":{"value":140703559897549,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":1530112},"r10":{"value":140648007865600},"rdx":{"value":1530112},"rdi":{"value":999388000},"r9":{"value":4256},"r13":{"value":6578382365483008},"rflags":{"value":659},"rax":{"value":0},"rsp":{"value":2199023256064},"r11":{"value":512},"rcx":{"value":0},"r14":{"value":13067780096},"rsi":{"value":2}}},{"id":3062583,"frames":[{"imageOffset":141644,"imageIndex":2}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":18446744073709551615},"r12":{"value":0},"rosetta":{"tmp2":{"value":0},"tmp1":{"value":0},"tmp0":{"value":0}},"rbx":{"value":0},"r8":{"value":0},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":13053792256},"rdi":{"value":0},"r9":{"value":0},"r13":{"value":0},"rflags":{"value":531},"rax":{"value":13054328832},"rsp":{"value":409604},"r11":{"value":0},"rcx":{"value":73639},"r14":{"value":0},"rsi":{"value":0}}},{"id":3062792,"frames":[{"imageOffset":141644,"imageIndex":2}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":18446744073709551615},"r12":{"value":0},"rosetta":{"tmp2":{"value":0},"tmp1":{"value":0},"tmp0":{"value":0}},"rbx":{"value":0},"r8":{"value":0},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":13052694528},"rdi":{"value":0},"r9":{"value":0},"r13":{"value":0},"rflags":{"value":531},"rax":{"value":13053231104},"rsp":{"value":409604},"r11":{"value":0},"rcx":{"value":103035},"r14":{"value":0},"rsi":{"value":0}}},{"id":3063151,"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":13054883600},"r12":{"value":140646925953840},"rosetta":{"tmp2":{"value":140707857242562},"tmp1":{"value":20467},"tmp0":{"value":140646925953864}},"rbx":{"value":13054883620},"r8":{"value":481},"r15":{"value":0},"r10":{"value":140708996583000,"symbolLocation":0,"symbol":"OBJC_CLASS_$_IOGPUMetalPooledResource"},"rdx":{"value":13054883620},"rdi":{"value":140646925676880},"r9":{"value":0},"r13":{"value":140708956840376,"symbolLocation":0,"symbol":"OBJC_IVAR_$_IOGPUMetalPooledResource._priv"},"rflags":{"value":582},"rax":{"value":0},"rsp":{"value":13054883584},"r11":{"value":140707857242350,"symbolLocation":0,"symbol":"-[IOGPUMetalResource setPurgeableState:]"},"rcx":{"value":24},"r14":{"value":140646924656856},"rsi":{"value":3}},"queue":"com.Metal.DeviceDispatchQueue","frames":[{"imageOffset":96301,"symbol":"IOGPUResourceSetPurgeable","symbolLocation":9,"imageIndex":12},{"imageOffset":72130,"symbol":"-[IOGPUMetalResource setPurgeableState:]","symbolLocation":212,"imageIndex":12},{"imageOffset":75171,"symbol":"-[IOGPUMetalResourcePool updateResourcePurgeability]","symbolLocation":159,"imageIndex":12},{"imageOffset":45051,"symbol":"-[IOGPUMetalDevice updateResourcePoolPurgeability]","symbolLocation":71,"imageIndex":12},{"imageOffset":41150,"symbol":"-[IOGPUMetalDevice periodicUpdateResourcePoolPurgeability]","symbolLocation":68,"imageIndex":12},{"imageOffset":13722,"symbol":"_dispatch_client_callout","symbolLocation":8,"imageIndex":13},{"imageOffset":24775,"symbol":"_dispatch_continuation_pop","symbolLocation":523,"imageIndex":13},{"imageOffset":91896,"symbol":"_dispatch_source_invoke","symbolLocation":2076,"imageIndex":13},{"imageOffset":38075,"symbol":"_dispatch_lane_serial_drain","symbolLocation":387,"imageIndex":13},{"imageOffset":41216,"symbol":"_dispatch_lane_invoke","symbolLocation":377,"imageIndex":13},{"imageOffset":80622,"symbol":"_dispatch_root_queue_drain_deferred_wlh","symbolLocation":271,"imageIndex":13},{"imageOffset":78845,"symbol":"_dispatch_workloop_worker_thread","symbolLocation":451,"imageIndex":13},{"imageOffset":11335,"symbol":"_pthread_wqthread","symbolLocation":327,"imageIndex":9},{"imageOffset":7063,"symbol":"start_wqthread","symbolLocation":15,"imageIndex":9}]},{"id":3072015,"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":13068335072},"r12":{"value":0},"rosetta":{"tmp2":{"value":140705984557128},"tmp1":{"value":140703558153626},"tmp0":{"value":140706057774492}},"rbx":{"value":0},"r8":{"value":0},"r15":{"value":0},"r10":{"value":2},"rdx":{"value":0},"rdi":{"value":140646924587696},"r9":{"value":140646924592944},"r13":{"value":272},"rflags":{"value":582},"rax":{"value":2303},"rsp":{"value":13068335072},"r11":{"value":27021597764222976},"rcx":{"value":18446744071427850239},"r14":{"value":4571811264},"rsi":{"value":140703615374451,"symbolLocation":0,"symbol":"__IONotificationPortSetDispatchQueue_block_invoke"}},"queue":"com.Metal.DeviceDispatch","frames":[{"imageOffset":21623,"symbol":"__IONotificationPortSetDispatchQueue_block_invoke","symbolLocation":4,"imageIndex":14},{"imageOffset":13722,"symbol":"_dispatch_client_callout","symbolLocation":8,"imageIndex":13},{"imageOffset":24775,"symbol":"_dispatch_continuation_pop","symbolLocation":523,"imageIndex":13},{"imageOffset":91896,"symbol":"_dispatch_source_invoke","symbolLocation":2076,"imageIndex":13},{"imageOffset":38075,"symbol":"_dispatch_lane_serial_drain","symbolLocation":387,"imageIndex":13},{"imageOffset":41216,"symbol":"_dispatch_lane_invoke","symbolLocation":377,"imageIndex":13},{"imageOffset":80622,"symbol":"_dispatch_root_queue_drain_deferred_wlh","symbolLocation":271,"imageIndex":13},{"imageOffset":78845,"symbol":"_dispatch_workloop_worker_thread","symbolLocation":451,"imageIndex":13},{"imageOffset":11335,"symbol":"_pthread_wqthread","symbolLocation":327,"imageIndex":9},{"imageOffset":7063,"symbol":"start_wqthread","symbolLocation":15,"imageIndex":9}]},{"id":3072468,"frames":[{"imageOffset":141644,"imageIndex":2}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":18446744073709551615},"r12":{"value":0},"rosetta":{"tmp2":{"value":0},"tmp1":{"value":0},"tmp0":{"value":0}},"rbx":{"value":0},"r8":{"value":0},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":13069406208},"rdi":{"value":0},"r9":{"value":0},"r13":{"value":0},"rflags":{"value":531},"rax":{"value":13069942784},"rsp":{"value":409604},"r11":{"value":0},"rcx":{"value":94087},"r14":{"value":0},"rsi":{"value":0}}}],
    "usedImages" : [
    "source" : "P",
    "arch" : "x86_64",
    "base" : 8651489280,
    "size" : 655360,
    "uuid" : "ab17bf63-259b-3b48-8d70-863166a2191c",
    "path" : "\/usr\/lib\/dyld",
    "name" : "dyld"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 4518862848,
    "size" : 65536,
    "uuid" : "c35523ac-5fc8-3185-b4fb-28be5af3f218",
    "path" : "\/usr\/lib\/libobjc-trampolines.dylib",
    "name" : "libobjc-trampolines.dylib"
    "source" : "P",
    "arch" : "arm64",
    "base" : 140703127126016,
    "size" : 196608,
    "uuid" : "c4c97159-5c72-3e75-ba2d-d6ca98ea626f",
    "path" : "\/usr\/libexec\/rosetta\/runtime",
    "name" : "runtime"
    "source" : "P",
    "arch" : "arm64",
    "base" : 4510502912,
    "size" : 344064,
    "uuid" : "7af8ba1e-5c4d-393d-99cd-92566f60c450",
    "path" : "\/Library\/Apple\/*\/libRosettaRuntime",
    "name" : "libRosettaRuntime"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 4332998656,
    "CFBundleShortVersionString" : "6.4.2",
    "CFBundleIdentifier" : "com.garmin.connectiq.simulator",
    "size" : 16564224,
    "uuid" : "8b447e7e-4cdb-3243-926d-9048585fcb2c",
    "path" : "\/Users\/USER\/Library\/Application Support\/Garmin\/*\/ConnectIQ.app\/Contents\/MacOS\/simulator",
    "name" : "simulator",
    "CFBundleVersion" : "6.4.2"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703616561152,
    "CFBundleShortVersionString" : "6.9",
    "CFBundleIdentifier" : "com.apple.AppKit",
    "size" : 21024764,
    "uuid" : "20292f0b-3eb2-3566-91e2-ea657457d71d",
    "path" : "\/System\/Library\/Frameworks\/AppKit.framework\/Versions\/C\/AppKit",
    "name" : "AppKit",
    "CFBundleVersion" : "2487.30.108"
    "size" : 0,
    "source" : "A",
    "base" : 0,
    "uuid" : "00000000-0000-0000-0000-000000000000"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703559622656,
    "size" : 241656,
    "uuid" : "9927a0a9-dfa8-3ffa-88d8-62055f37a137",
    "path" : "\/usr\/lib\/system\/libsystem_kernel.dylib",
    "name" : "libsystem_kernel.dylib"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703560282112,
    "CFBundleIdentifier" : "com.apple.CoreFoundation",
    "size" : 4825085,
    "uuid" : "fd59424c-be72-3201-b98c-0421b284ffbb",
    "path" : "\/System\/Library\/Frameworks\/CoreFoundation.framework\/Versions\/A\/CoreFoundation",
    "name" : "CoreFoundation",
    "CFBundleVersion" : "2202"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703559864320,
    "size" : 49152,
    "uuid" : "a9ba8a53-d774-3fe9-8bde-64187bff7ea9",
    "path" : "\/usr\/lib\/system\/libsystem_pthread.dylib",
    "name" : "libsystem_pthread.dylib"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703558443008,
    "size" : 557056,
    "uuid" : "29a0020e-3766-39df-80fe-9aa731847daa",
    "path" : "\/usr\/lib\/system\/libsystem_c.dylib",
    "name" : "libsystem_c.dylib"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703559000064,
    "size" : 520192,
    "uuid" : "c4311955-de8c-341a-bf4e-46f9a9b26d7a",
    "path" : "\/usr\/lib\/libc++.1.dylib",
    "name" : "libc++.1.dylib"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140707857170432,
    "CFBundleShortVersionString" : "93.10.1",
    "CFBundleIdentifier" : "com.apple.IOGPU",
    "size" : 229362,
    "uuid" : "34e8d18c-7efd-3f68-a802-4f73a4382deb",
    "path" : "\/System\/Library\/PrivateFrameworks\/IOGPU.framework\/Versions\/A\/IOGPU",
    "name" : "IOGPU",
    "CFBundleVersion" : "93.10.1"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703558139904,
    "size" : 290814,
    "uuid" : "895cad19-704c-3ff8-b148-23689a163b12",
    "path" : "\/usr\/lib\/system\/libdispatch.dylib",
    "name" : "libdispatch.dylib"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703615352832,
    "CFBundleShortVersionString" : "2.0.2",
    "CFBundleIdentifier" : "com.apple.framework.IOKit",
    "size" : 798712,
    "uuid" : "d556ec12-074c-30d8-958e-7b88c4b1178c",
    "path" : "\/System\/Library\/Frameworks\/IOKit.framework\/Versions\/A\/IOKit",
    "name" : "IOKit"
    "sharedCache" : {
    "base" : 140703555452928,
    "size" : 21474836480,
    "uuid" : "aa32606f-3f8a-36dc-89ab-9c1bd7bf3104"
    "vmSummary" : "ReadOnly portion of Libraries: Total=794.9M resident=0K(0%) swapped_out_or_unallocated=794.9M(100%)\nWritable regions: Total=1.4G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.4G(100%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced) \n=========== ======= ======= \nAccelerate framework 256K 2 \nActivity Tracing 256K 1 \nCG image 3220K 40 \nCG raster data 2232K 2 \nColorSync 252K 33 \nCoreAnimation 4804K 50 \nCoreGraphics 12K 2 \nCoreUI image data 2932K 22 \nDispatch continuations 64.0M 1 \nFoundation 40K 2 \nKernel Alloc Once 8K 1 \nMALLOC 1.1G 63 \nMALLOC guard page 192K 12 \nRosetta Arena 4096K 2 \nRosetta Generic 1792K 445 \nRosetta IndirectBranch 1024K 1 \nRosetta JIT 128.0M 1 \nRosetta Return Stack 600K 60 \nRosetta Thread Context 600K 60 \nSTACK GUARD 12K 3 \nStack 22.8M 33 \nStack Guard 56.1M 27 \nVM_ALLOCATE 4804K 14 \nVM_ALLOCATE (reserved) 4K 1 reserved VM address space (unallocated)\n__CTF 824 1 \n__DATA 32.5M 539 \n__DATA_CONST 36.6M 341 \n__DATA_DIRTY 1523K 177 \n__FONT_DATA 2352 1 \n__INFO_FILTER 8 1 \n__LINKEDIT 144.3M 10 \n__OBJC_RO 71.1M 1 \n__OBJC_RW 2166K 3 \n__TEXT 650.6M 559 \ndyld private memory 260K 2 \nmapped file 7.2G 875 \nshared memory 816K 17 \nunshared pmap 14.6M 10 \n=========== ======= ======= \nTOTAL 9.5G 3415 \nTOTAL, minus reserved VM space 9.5G 3415 \n",
    "legacyInfo" : {
    "threadTriggered" : {
    "name" : "ant_main"
    "logWritingSignature" : "75a8bc31b7797c73a86dc45590344b4796589e47",
    "trialInfo" : {
    "rollouts" : [
    "rolloutId" : "632e3df958740028737bffc0",
    "factorPackIds" : {
    "SIRI_UNDERSTANDING_NL_OVERRIDES" : "65cf6c2ef4f548412aec5f91"
    "deploymentId" : 240000642
    "rolloutId" : "645c2d2f9e69a025b0a37e29",
    "factorPackIds" : {
    "deploymentId" : 240000003
    "experiments" : [
    "reportNotes" : [
    "PC register does not match crashing frame (0x0 vs 0x7FF8AA0CAA78)"
    Model: MacBookAir10,1, BootROM 10151.61.4, proc 8:4:4 processors, 8 GB, SMC
    Graphics: Apple M1, Apple M1, Built-In
    Display: Color LCD, 2560 x 1600 Retina, Main, MirrorOff, Online
    Memory Module: LPDDR4, Hynix
    AirPort: spairport_wireless_card_type_wifi (0x14E4, 0x4378), wl0: Aug 26 2023 17:55:53 version 18.20.439.0.7.8.163 FWID 01-f9b9247b
    AirPort:
    Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports
    Network Service: Wi-Fi, AirPort, en0
    USB Device: USB31Bus
    Thunderbolt Bus: MacBook Air, Apple Inc.
Comment
    User ID: 501
    Report Version: 12
    Notes:
    abort() called
    Thread 3:: TSK bkgd
    Thread 7:: GPS main
    Thread 8:: SNS main
    Thread 21:
    Thread 22:
    Thread 24:
    Thread 25:
    Thread 26:
    Thread 27:
    Thread 30:
    Binary Images:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
    VM Region Summary:
    VIRTUAL REGION
    CG image 3220K 40
    ColorSync 252K 33
    CoreGraphics 12K 2
    Foundation 40K 2
    MALLOC 1.1G 63
    STACK GUARD 12K 3
    Stack 22.8M 33
    __CTF 824 1
    __DATA 32.5M 539
    __FONT_DATA 2352 1
    __INFO_FILTER 8 1
    __OBJC_RO 71.1M 1
    __OBJC_RW 2166K 3
    __TEXT 650.6M 559
    TOTAL 9.5G 3415
    Full Report
    "uptime" : 400000,
    "version" : 2,
    "userID" : 501,
    "osVersion" : {
    "build" : "23C71",
    "pid" : 47810,
    "bug_type" : "309",
    "parentPid" : 1,
    "lowPowerMode" : 1,
    "wakeTime" : 15,
    "sip" : "enabled",
    "usedImages" : [
    "source" : "P",
    "arch" : "x86_64",
    "size" : 655360,
    "name" : "dyld"
    "source" : "P",
    "arch" : "x86_64",
    "size" : 65536,
    "source" : "P",
    "arch" : "arm64",
    "size" : 196608,
    "name" : "runtime"
    "source" : "P",
    "arch" : "arm64",
    "size" : 344064,
    "source" : "P",
    "arch" : "x86_64",
    "size" : 16564224,
    "source" : "P",
    "arch" : "x86_64",
    "size" : 21024764,
    "name" : "AppKit",
    "size" : 0,
    "source" : "A",
    "base" : 0,
    "source" : "P",
    "arch" : "x86_64",
    "size" : 241656,
    "source" : "P",
    "arch" : "x86_64",
    "size" : 4825085,
    "source" : "P",
    "arch" : "x86_64",
    "size" : 49152,
    "source" : "P",
    "arch" : "x86_64",
    "size" : 557056,
    "source" : "P",
    "arch" : "x86_64",
    "size" : 520192,
    "source" : "P",
    "arch" : "x86_64",
    "size" : 229362,
    "name" : "IOGPU",
    "source" : "P",
    "arch" : "x86_64",
    "size" : 290814,
    "source" : "P",
    "arch" : "x86_64",
    "size" : 798712,
    "name" : "IOKit"
    "sharedCache" : {
    "legacyInfo" : {
    "name" : "ant_main"
    "trialInfo" : {
    "rollouts" : [
    "factorPackIds" : {
    "factorPackIds" : {
    "experiments" : [
    "reportNotes" : [
    AirPort:
Children
No Data
