Acknowledged
CIQ Simulator crashes on Mac regularly
After keeping it running for a while and launching an app repeatedly over several hours, the simulator will inevitably crash.
I believe this has been happening ever since I started using a Mac (Apple silicon) for CIQ SDK almost 2 years ago.
That means with all the current Mac OS and CIQ SDK versions since that time.
No such problems with the same CIQ SDK version running on Windows.
Thread 28 Crashed:
0 ??? 0x7ff89446e9a8 ???
1 libsystem_kernel.dylib 0x7ff80510122a __pthread_kill + 10
2 libsystem_pthread.dylib 0x7ff805138f7b pthread_kill + 263
3 libsystem_c.dylib 0x7ff805082ca5 abort + 123
4 simulator 0x10231387d 0x102287000 + 575613
5 simulator 0x1023956ac 0x102287000 + 1107628
6 simulator 0x102b8d40c 0x102287000 + 9462796
7 simulator 0x102b8ce9f 0x102287000 + 9461407
8 libsystem_pthread.dylib 0x7ff805139259 _pthread_start + 125
9 libsystem_pthread.dylib 0x7ff805134c7b thread_start + 15
Thread 28 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x0000000000000000 rcx: 0x0000000000000000 rdx: 0x0000000000000000
rdi: 0x00007fa97becd6f0 rsi: 0x0000000000000003 rbp: 0x0000000000000000 rsp: 0x0000000000000000
r8: 0x0000000309c9e000 r9: 0x0000000000000000 r10: 0x0000000000000000 r11: 0x00007fa97bdca4c0
r12: 0x00000000000129a3 r13: 0x0000000309c9e000 r14: 0x0000000000000006 r15: 0x0000000000000016
rip: <unavailable> rfl: 0x0000000000000283
tmp0: 0xffffffffffffffff tmp1: 0x00007ff89446e97c tmp2: 0x00007ff805101220
  • Crashing in 7.3.0.
    Particularly after Trigger App Settings
    Translated Report (Full Report Below)
    Process: simulator [1209]
    Path: /Users/USER/Library/Application Support/Garmin/*/ConnectIQ.app/Contents/MacOS/simulator
    Identifier: com.garmin.connectiq.simulator
    Version: 7.3.0 (7.3.0)
    Code Type: ARM-64 (Native)
    Parent Process: launchd [1]
    User ID: 501
    Date/Time: 2024-09-16 19:48:57.0401 +0100
    OS Version: macOS 14.6.1 (23G93)
    Report Version: 12
    Anonymous UUID: 13FD0138-F514-B8AF-454C-338C54C9E332
    Time Awake Since Boot: 360 seconds
    System Integrity Protection: enabled
    Crashed Thread: 27
    Exception Type: EXC_BAD_ACCESS (SIGSEGV)
    Exception Codes: KERN_INVALID_ADDRESS at 0x00000009202404c8
    Exception Codes: 0x0000000000000001, 0x00000009202404c8
    Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11
    Terminating Process: exc handler [1209]
    VM Region Info: 0x9202404c8 is not in any region. Bytes after previous region: 28358378697 Bytes before following region: 28451797816
    REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
    unused __TEXT 285d94000-285d98000 [ 16K] r--/r-- SM=COW unused unknown system shared lib __TEXT
    ---> GAP OF 0xd3a268000 BYTES
    commpage (reserved) fc0000000-1000000000 [ 1.0G] ---/--- SM=NUL reserved VM address space (unallocated)
    Thread 0:: Dispatch queue: com.apple.main-thread
    0 libsystem_kernel.dylib 0x18ae80df4 mach_msg2_trap + 8
    1 libsystem_kernel.dylib 0x18ae935e4 mach_msg2_internal + 80
    2 libsystem_kernel.dylib 0x18ae899c4 mach_msg_overwrite + 476
    3 libsystem_kernel.dylib 0x18ae81178 mach_msg + 24
    4 CoreFoundation 0x18afa1680 __CFRunLoopServiceMachPort + 160
    5 CoreFoundation 0x18af9ff44 __CFRunLoopRun + 1208
    6 CoreFoundation 0x18af9f434 CFRunLoopRunSpecific + 608
    7 HIToolbox 0x19574919c RunCurrentEventLoopInMode + 292
    8 HIToolbox 0x195748fd8 ReceiveNextEventCommon + 648
    9 HIToolbox 0x195748d30 _BlockUntilNextEventMatchingListInModeWithFilter + 76
    10 AppKit 0x18e7fecc8 _DPSNextEvent + 660
    11 AppKit 0x18eff54d0 -[NSApplication(NSEventRouting) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 700
    12 AppKit 0x18e7f1ffc -[NSApplication run] + 476
    13 simulator 0x10573fb8c 0x104cdc000 + 10894220
    14 simulator 0x105650548 0x104cdc000 + 9913672
    15 simulator 0x1055cb338 0x104cdc000 + 9368376
    16 simulator 0x1055a0034 0x104cdc000 + 9191476
    17 simulator 0x105700e24 0x104cdc000 + 10636836
    18 simulator 0x1055fb2a8 0x104cdc000 + 9564840
    19 simulator 0x104d1af00 0x104cdc000 + 257792
    20 dyld 0x18ab37154 start + 2476
    Thread 1:
    0 libsystem_pthread.dylib 0x18aebcd20 start_wqthread + 0
    Thread 2:
    Thread 3:
    Thread 4:: com.apple.NSEventThread
    7 AppKit 0x18e929280 _NSEventThread + 144
    8 libsystem_pthread.dylib 0x18aec1f94 _pthread_start + 136
    9 libsystem_pthread.dylib 0x18aebcd34 thread_start + 8
    Thread 5:: TSK bkgd
    0 libsystem_kernel.dylib 0x18ae845ec __psynch_cvwait + 8
    1 libsystem_pthread.dylib 0x18aec255c _pthread_cond_wait + 1228
    2 simulator 0x10547fda4 0x104cdc000 + 8011172
    3 simulator 0x10547f084 0x104cdc000 + 8007812
    4 libsystem_pthread.dylib 0x18aec1f94 _pthread_start + 136
    5 libsystem_pthread.dylib 0x18aebcd34 thread_start + 8
    Thread 6:: NFM_Region_0
    1 libsystem_pthread.dylib 0x18aec2588 _pthread_cond_wait + 1272
    2 simulator 0x10547eb7c 0x104cdc000 + 8006524
    3 simulator 0x10547fda4 0x104cdc000 + 8011172
    4 simulator 0x1054eba98 0x104cdc000 + 8452760
    5 simulator 0x10547f0b8 0x104cdc000 + 8007864
    6 libsystem_pthread.dylib 0x18aec1f94 _pthread_start + 136
    7 libsystem_pthread.dylib 0x18aebcd34 thread_start + 8
    Thread 7:: IOPAppMain
    3 simulator 0x105209930 0x104cdc000 + 5429552
    4 simulator 0x10547f0a0 0x104cdc000 + 8007840
    5 libsystem_pthread.dylib 0x18aec1f94 _pthread_start + 136
    6 libsystem_pthread.dylib 0x18aebcd34 thread_start + 8
    Thread 8:: ant_main
    4 simulator 0x1051dad14 0x104cdc000 + 5238036
    5 simulator 0x10547f0a0 0x104cdc000 + 8007840
    Thread 9:: GPS main
    Thread 10:: SNS main
    Thread 11:: fit activity
    3 simulator 0x105247930 0x104cdc000 + 5683504
    Thread 12:: ftm main
    4 simulator 0x105256b74 0x104cdc000 + 5745524
    Thread 13:: TVM main
    4 simulator 0x105424f20 0x104cdc000 + 7638816
    Thread 14:: TVM defrag
    Thread 15:: parse main
    3 simulator 0x104cfb6d8 0x104cdc000 + 128728
    Thread 16:: GPX archive trk
    3 simulator 0x1054fea40 0x104cdc000 + 8530496
    Thread 17:: URM Main
    3 simulator 0x10522c18c 0x104cdc000 + 5570956
    Thread 18:: mma sql bkg
    Thread 19:: TLG main
    4 simulator 0x1054fe804 0x104cdc000 + 8529924
    Thread 20:: libcurl Async H
    3 simulator 0x105224778 0x104cdc000 + 5539704
    4 simulator 0x10547f0b8 0x104cdc000 + 8007864
    Thread 21:: Download Manage
    3 simulator 0x105227304 0x104cdc000 + 5550852
    Thread 22:: Shell main
    0 libsystem_kernel.dylib 0x18ae896d4 __accept + 8
    1 simulator 0x1054f7358 0x104cdc000 + 8500056
    2 simulator 0x1054f4614 0x104cdc000 + 8488468
    3 simulator 0x10547f0a0 0x104cdc000 + 8007840
    Thread 23:
    2 libc++.1.dylib 0x18ade7b14 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 28
    3 simulator 0x104d9cfe0 0x104cdc000 + 790496
    4 simulator 0x104d9cec0 0x104cdc000 + 790208
    5 simulator 0x104d9cd6c 0x104cdc000 + 789868
    Thread 24:
    1 simulator 0x104df9c94 0x104cdc000 + 1170580
    2 simulator 0x104dcf108 0x104cdc000 + 995592
    3 simulator 0x105661928 0x104cdc000 + 9984296
    4 simulator 0x10566148c 0x104cdc000 + 9983116
    Thread 25:: Shell handler
    2 simulator 0x10547e92c 0x104cdc000 + 8005932
    3 simulator 0x104df9170 0x104cdc000 + 1167728
    4 simulator 0x1054f7090 0x104cdc000 + 8499344
    5 simulator 0x1054f66fc 0x104cdc000 + 8496892
    6 simulator 0x1054f4f4c 0x104cdc000 + 8490828
    7 simulator 0x10547f0a0 0x104cdc000 + 8007840
    Thread 26:
    0 libsystem_kernel.dylib 0x18ae85380 __recvfrom + 8
    1 simulator 0x1054f7744 0x104cdc000 + 8501060
    2 simulator 0x1054f67bc 0x104cdc000 + 8497084
    3 simulator 0x104df6b14 0x104cdc000 + 1157908
    4 simulator 0x104dfdca4 0x104cdc000 + 1186980
    5 simulator 0x105661928 0x104cdc000 + 9984296
    6 simulator 0x10566148c 0x104cdc000 + 9983116
    7 libsystem_pthread.dylib 0x18aec1f94 _pthread_start + 136
    8 libsystem_pthread.dylib 0x18aebcd34 thread_start + 8
    Thread 27 Crashed:
    0 simulator 0x10544c604 0x104cdc000 + 7800324
    1 simulator 0x10546b2c0 0x104cdc000 + 7926464
    2 simulator 0x10546f818 0x104cdc000 + 7944216
    3 simulator 0x10547027c 0x104cdc000 + 7946876
    4 simulator 0x105470c08 0x104cdc000 + 7949320
    5 simulator 0x1054101a0 0x104cdc000 + 7553440
    6 simulator 0x105460054 0x104cdc000 + 7880788
    7 simulator 0x104e51df0 0x104cdc000 + 1531376
    8 simulator 0x104e519f0 0x104cdc000 + 1530352
    9 simulator 0x104e159f0 0x104cdc000 + 1284592
    10 simulator 0x104e53624 0x104cdc000 + 1537572
    11 simulator 0x104e13ebc 0x104cdc000 + 1277628
    12 simulator 0x104dfdca4 0x104cdc000 + 1186980
    13 simulator 0x105661928 0x104cdc000 + 9984296
    14 simulator 0x10566148c 0x104cdc000 + 9983116
    15 libsystem_pthread.dylib 0x18aec1f94 _pthread_start + 136
    16 libsystem_pthread.dylib 0x18aebcd34 thread_start + 8
    Thread 28:
    Thread 29:
    Thread 30:
    Thread 31:
    Thread 27 crashed with ARM Thread State (64-bit):
    x0: 0x0000000000000000 x1: 0x000000016c0fa888 x2: 0x0000000000000000 x3: 0x0000000152710990
    x4: 0x0000000152710a00 x5: 0x0000000000000011 x6: 0x0000000000000000 x7: 0x0000000000000000
    x8: 0x00000001202404d0 x9: 0x0000000000000000 x10: 0x00000009202404c8 x11: 0x00000009202404c8
    x12: 0x00000001202404a8 x13: 0x00000000000000b4 x14: 0x0000000000000000 x15: 0x00000000800080bf
    x16: 0x000000018aef1ed0 x17: 0x00000001fd412f38 x18: 0x0000000000000000 x19: 0x0000000120230000
    x20: 0x0000000000000000 x21: 0x0000000000000000 x22: 0x000000000000000b x23: 0x0000000000000001
    x24: 0x00000001202404b0 x25: 0x0000000000000000 x26: 0x0000000000000000 x27: 0x000000000000007f
    x28: 0x0000000105d1a1d8 fp: 0x000000016c0fa930 lr: 0x000000010544c5dc
    sp: 0x000000016c0fa880 pc: 0x000000010544c604 cpsr: 0x20001000
    far: 0x00000009202404c8 esr: 0x92000006 (Data Abort) byte read Translation fault
    Binary Images:
    0x106328000 - 0x106333fff libobjc-trampolines.dylib (*) <7d6ca1cb-c5e6-38b6-9618-2c580486fc6b> /usr/lib/libobjc-trampolines.dylib
    0x104cdc000 - 0x105cb3fff com.garmin.connectiq.simulator (7.3.0) <c3f78836-7950-350c-871c-1257c0a406d7> /Users/USER/Library/Application Support/Garmin/*/ConnectIQ.app/Contents/MacOS/simulator
    0x18ae80000 - 0x18aebaffb libsystem_kernel.dylib (*) <71ff45b8-f14e-3666-9e96-6cf58315b91d> /usr/lib/system/libsystem_kernel.dylib
    0x18af23000 - 0x18b3fbfff com.apple.CoreFoundation (6.9) <55720ee0-d8c3-33a1-9854-8e61a6f44895> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x195716000 - 0x1959d9fff com.apple.HIToolbox (2.1.1) <4166f6cb-b599-306c-8568-823bd29a74c3> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x18e7c5000 - 0x18fb03fff com.apple.AppKit (6.9) <7acbeef9-a453-3e4d-98ac-f9441d86e183> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x18ab31000 - 0x18abba507 dyld (*) <f635824e-318b-3f0c-842c-c369737f2b68> /usr/lib/dyld
    0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ???
    0x18aebb000 - 0x18aec7fff libsystem_pthread.dylib (*) <e03e8478-6f5c-3d21-a79a-58408f514000> /usr/lib/system/libsystem_pthread.dylib
    0x18add7000 - 0x18ae63ff7 libc++.1.dylib (*) <aaa5636d-6f3f-3fa7-9f4a-cf966f0308fe> /usr/lib/libc++.1.dylib
    0x18aeee000 - 0x18aef5fe7 libsystem_platform.dylib (*) <b4bf9f89-31d7-3742-8ce7-ab3554f9f525> /usr/lib/system/libsystem_platform.dylib
    External Modification Summary:
    Calls made by other processes targeting this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
    Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
    Calls made by all processes on this machine:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
    VM Region Summary:
    ReadOnly portion of Libraries: Total=1.0G resident=0K(0%) swapped_out_or_unallocated=1.0G(100%)
    Writable regions: Total=1.2G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.2G(100%)
    VIRTUAL REGION
    REGION TYPE SIZE COUNT (non-coalesced)
    Accelerate framework 128K 1
    Activity Tracing 256K 1
    CG image 1616K 25
    CG raster data 848K 2
    ColorSync 624K 30
    CoreAnimation 1520K 52
    CoreGraphics 32K 2
    CoreUI image data 1392K 10
    Dispatch continuations 64.0M 1
    Foundation 16K 1
    Kernel Alloc Once 32K 1
    MALLOC 1.1G 77
    MALLOC guard page 192K 12
    STACK GUARD 56.5M 32
    Stack 24.5M 35
    VM_ALLOCATE 176K 11
    __AUTH 1157K 254
    __AUTH_CONST 22.5M 431
    __CTF 824 1
    __DATA 9717K 415
    __DATA_CONST 22.3M 435
    __DATA_DIRTY 1212K 135
    __FONT_DATA 4K 1
    __LINKEDIT 526.8M 3
    __OBJC_RO 71.9M 1
    __OBJC_RW 2200K 1
    __TEXT 528.7M 452
    dyld private memory 272K 2
    mapped file 280.0M 35
    shared memory 864K 14
    TOTAL 2.7G 2473
    Full Report
    {"app_name":"simulator","timestamp":"2024-09-16 19:48:58.00 +0100","app_version":"7.3.0","slice_uuid":"c3f78836-7950-350c-871c-1257c0a406d7","build_version":"7.3.0","platform":1,"bundleID":"com.garmin.connectiq.simulator","share_with_app_devs":1,"is_first_party":0,"bug_type":"309","os_version":"macOS 14.6.1 (23G93)","roots_installed":0,"name":"simulator","incident_id":"4AFB388C-AF0E-454A-82B2-2465C29F72F4"}
    "uptime" : 360,
    "procRole" : "Foreground",
    "version" : 2,
    "userID" : 501,
    "deployVersion" : 210,
    "modelCode" : "Mac15,13",
    "coalitionID" : 1225,
    "osVersion" : {
    "train" : "macOS 14.6.1",
    "build" : "23G93",
    "releaseType" : "User"
    "captureTime" : "2024-09-16 19:48:57.0401 +0100",
    "codeSigningMonitor" : 1,
    "incident" : "4AFB388C-AF0E-454A-82B2-2465C29F72F4",
    "pid" : 1209,
    "translated" : false,
    "cpuType" : "ARM-64",
    "roots_installed" : 0,
    "bug_type" : "309",
    "procLaunch" : "2024-09-16 19:48:35.6570 +0100",
    "procStartAbsTime" : 8255118742,
    "procExitAbsTime" : 8768183669,
    "procName" : "simulator",
    "procPath" : "\/Users\/USER\/Library\/Application Support\/Garmin\/*\/ConnectIQ.app\/Contents\/MacOS\/simulator",
    "bundleInfo" : {"CFBundleShortVersionString":"7.3.0","CFBundleVersion":"7.3.0","CFBundleIdentifier":"com.garmin.connectiq.simulator"},
    "storeInfo" : {"deviceIdentifierForVendor":"31C9A7B6-D4D5-56E7-83A8-AD1752EE33BC","thirdParty":true},
    "parentProc" : "launchd",
    "parentPid" : 1,
    "coalitionName" : "com.garmin.connectiq.simulator",
    "crashReporterKey" : "13FD0138-F514-B8AF-454C-338C54C9E332",
    "codeSigningID" : "com.garmin.connectiq.simulator",
    "codeSigningTeamID" : "72ES32VZUA",
    "codeSigningFlags" : 570503953,
    "codeSigningValidationCategory" : 6,
    "codeSigningTrustLevel" : 4294967295,
    "instructionByteStream" : {"beforePC":"9AMAqgiDAJHpAxWqqgYAUcpOKotKEQCR\/wIAcQsBippIAYiaFgFAuQ==","atPC":"dQFAuegAgFIIZwA5H6cBKRdjADnhT0C5VAEANOADE6ojov+XXv\/\/Fw=="},
    "sip" : "enabled",
    "vmRegionInfo" : "0x9202404c8 is not in any region. Bytes after previous region: 28358378697 Bytes before following region: 28451797816\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n unused __TEXT 285d94000-285d98000 [ 16K] r--\/r-- SM=COW unused unknown system shared lib __TEXT\n---> GAP OF 0xd3a268000 BYTES\n commpage (reserved) fc0000000-1000000000 [ 1.0G] ---\/--- SM=NUL reserved VM address space (unallocated)",
    "exception" : {"codes":"0x0000000000000001, 0x00000009202404c8","rawCodes":[1,39193937096],"type":"EXC_BAD_ACCESS","signal":"SIGSEGV","subtype":"KERN_INVALID_ADDRESS at 0x00000009202404c8"},
    "termination" : {"flags":0,"code":11,"namespace":"SIGNAL","indicator":"Segmentation fault: 11","byProc":"exc handler","byPid":1209},
    "vmregioninfo" : "0x9202404c8 is not in any region. Bytes after previous region: 28358378697 Bytes before following region: 28451797816\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n unused __TEXT 285d94000-285d98000 [ 16K] r--\/r-- SM=COW unused unknown system shared lib __TEXT\n---> GAP OF 0xd3a268000 BYTES\n commpage (reserved) fc0000000-1000000000 [ 1.0G] ---\/--- SM=NUL reserved VM address space (unallocated)",
    "extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
    "faultingThread" : 27,
    "threads" : [{"id":13825,"threadState":{"x":[{"value":268451845},{"value":21592279046},{"value":8589934592},{"value":23102629085184},{"value":0},{"value":23102629085184},{"value":2},{"value":4294967295},{"value":18446744073709550527},{"value":5379},{"value":0},{"value":1},{"value":5379},{"value":1151594},{"value":0},{"value":87960930222080},{"value":18446744073709551569},{"value":8543856360},{"value":0},{"value":4294967295},{"value":2},{"value":23102629085184},{"value":0},{"value":23102629085184},{"value":6091316504},{"value":8589934592},{"value":21592279046},{"value":21592279046},{"value":4412409862}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6625506788},"cpsr":{"value":4096},"fp":{"value":6091316352},"sp":{"value":6091316272},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6625431028},"far":{"value":0}},"queue":"com.apple.main-thread","frames":[{"imageOffset":3572,"symbol":"mach_msg2_trap","symbolLocation":8,"imageIndex":2},{"imageOffset":79332,"symbol":"mach_msg2_internal","symbolLocation":80,"imageIndex":2},{"imageOffset":39364,"symbol":"mach_msg_overwrite","symbolLocation":476,"imageIndex":2},{"imageOffset":4472,"symbol":"mach_msg","symbolLocation":24,"imageIndex":2},{"imageOffset":517760,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":160,"imageIndex":3},{"imageOffset":511812,"symbol":"__CFRunLoopRun","symbolLocation":1208,"imageIndex":3},{"imageOffset":508980,"symbol":"CFRunLoopRunSpecific","symbolLocation":608,"imageIndex":3},{"imageOffset":209308,"symbol":"RunCurrentEventLoopInMode","symbolLocation":292,"imageIndex":4},{"imageOffset":208856,"symbol":"ReceiveNextEventCommon","symbolLocation":648,"imageIndex":4},{"imageOffset":208176,"symbol":"_BlockUntilNextEventMatchingListInModeWithFilter","symbolLocation":76,"imageIndex":4},{"imageOffset":236744,"symbol":"_DPSNextEvent","symbolLocation":660,"imageIndex":5},{"imageOffset":8586448,"symbol":"-[NSApplication(NSEventRouting) _nextEventMatchingEventMask:untilDate:inMode:dequeue:]","symbolLocation":700,"imageIndex":5},{"imageOffset":184316,"symbol":"-[NSApplication run]","symbolLocation":476,"imageIndex":5},{"imageOffset":10894220,"imageIndex":1},{"imageOffset":9913672,"imageIndex":1},{"imageOffset":9368376,"imageIndex":1},{"imageOffset":9191476,"imageIndex":1},{"imageOffset":10636836,"imageIndex":1},{"imageOffset":9564840,"imageIndex":1},{"imageOffset":257792,"imageIndex":1},{"imageOffset":24916,"symbol":"start","symbolLocation":2476,"imageIndex":6}]},{"id":13850,"frames":[{"imageOffset":7456,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":8}],"threadState":{"x":[{"value":6091878400},{"value":4611},{"value":6091341824},{"value":0},{"value":409604},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6091878400},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6625676576},"far":{"value":0}}},{"id":13851,"frames":[{"imageOffset":7456,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":8}],"threadState":{"x":[{"value":6092451840},{"value":8451},{"value":6091915264},{"value":0},{"value":409604},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6092451840},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6625676576},"far":{"value":0}}},{"id":13873,"frames":[{"imageOffset":7456,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":8}],"threadState":{"x":[{"value":6093025280},{"value":17667},{"value":6092488704},{"value":0},{"value":409604},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6093025280},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6625676576},"far":{"value":0}}},{"id":13892,"name":"com.apple.NSEventThread","threadState":{"x":[{"value":268451845},{"value":21592279046},{"value":8589934592},{"value":160558762426368},{"value":0},{"value":160558762426368},{"value":2},{"value":4294967295},{"value":18446744073709550527},{"value":37383},{"value":0},{"value":1},{"value":37383},{"value":739684},{"value":0},{"value":0},{"value":18446744073709551569},{"value":8543856360},{"value":0},{"value":4294967295},{"value":2},{"value":160558762426368},{"value":0},{"value":160558762426368},{"value":6093594728},{"value":8589934592},{"value":21592279046},{"value":21592279046},{"value":4412409862}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6625506788},"cpsr":{"value":4096},"fp":{"value":6093594576},"sp":{"value":6093594496},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6625431028},"far":{"value":0}},"frames":[{"imageOffset":3572,"symbol":"mach_msg2_trap","symbolLocation":8,"imageIndex":2},{"imageOffset":79332,"symbol":"mach_msg2_internal","symbolLocation":80,"imageIndex":2},{"imageOffset":39364,"symbol":"mach_msg_overwrite","symbolLocation":476,"imageIndex":2},{"imageOffset":4472,"symbol":"mach_msg","symbolLocation":24,"imageIndex":2},{"imageOffset":517760,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":160,"imageIndex":3},{"imageOffset":511812,"symbol":"__CFRunLoopRun","symbolLocation":1208,"imageIndex":3},{"imageOffset":508980,"symbol":"CFRunLoopRunSpecific","symbolLocation":608,"imageIndex":3},{"imageOffset":1458816,"symbol":"_NSEventThread","symbolLocation":144,"imageIndex":5},{"imageOffset":28564,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":8},{"imageOffset":7476,"symbol":"thread_start","symbolLocation":8,"imageIndex":8}]},{"id":13893,"name":"TSK bkgd","threadState":{"x":[{"value":260},{"value":0},{"value":0},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6094171752},{"value":0},{"value":5410003920},{"value":2},{"value":0},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8543872160},{"value":0},{"value":5410003896},{"value":5410003960},{"value":6094172384},{"value":0},{"value":0},{"value":0},{"value":1},{"value":256},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6625699164},"cpsr":{"value":1610616832},"fp":{"value":6094171872},"sp":{"value":6094171728},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6625445356},"far":{"value":0}},"frames":[{"imageOffset":17900,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":2},{"imageOffset":30044,"symbol":"_pthread_cond_wait","symbolLocation":1228,"imageIndex":8},{"imageOffset":8011172,"imageIndex":1},{"imageOffset":8007812,"imageIndex":1},{"imageOffset":28564,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":8},{"imageOffset":7476,"symbol":"thread_start","symbolLocation":8,"imageIndex":8}]},{"id":13894,"name":"NFM_Region_0","threadState":{"x":[{"value":260},{"value":0},{"value":30208},{"value":0},{"value":0},{"value":65704},{"value":296},{"value":890976000},{"value":30209},{"value":0},{"value":5698481104},{"value":13194139536386},{"value":3072},{"value":0},{"value":3072},{"value":13194139536384},{"value":305},{"value":8543872160},{"value":0},{"value":5698481080},{"value":5698481144},{"value":1},{"value":890976000},{"value":296},{"value":30208},{"value":30209},{"value":30464},{"value":65535},{"value":64289}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6625699208},"cpsr":{"value":2684358656},"fp":{"value":6094744960},"sp":{"value":6094744816},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6625445356},"far":{"value":0}},"frames":[{"imageOffset":17900,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":2},{"imageOffset":30088,"symbol":"_pthread_cond_wait","symbolLocation":1272,"imageIndex":8},{"imageOffset":8006524,"imageIndex":1},{"imageOffset":8011172,"imageIndex":1},{"imageOffset":8452760,"imageIndex":1},{"imageOffset":8007864,"imageIndex":1},{"imageOffset":28564,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":8},{"imageOffset":7476,"symbol":"thread_start","symbolLocation":8,"imageIndex":8}]},{"id":13895,"name":"IOPAppMain","threadState":{"x":[{"value":260},{"value":0},{"value":0},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6095318552},{"value":0},{"value":5698462688},{"value":2},{"value":0},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8543872160},{"value":0},{"value":5698462664},{"value":5698462728},{"value":6095319264},{"value":0},{"value":0},{"value":0},{"value":1},{"value":256},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6625699164},"cpsr":{"value":1610616832},"fp":{"value":6095318672},"sp":{"value":6095318528},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6625445356},"far":{"value":0}},"frames":[{"imageOffset":17900,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":2},{"imageOffset":30044,"symbol":"_pthread_cond_wait","symbolLocation":1228,"imageIndex":8},{"imageOffset":8011172,"imageIndex":1},{"imageOffset":5429552,"imageIndex":1},{"imageOffset":8007840,"imageIndex":1},{"imageOffset":28564,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":8},{"imageOffset":7476,"symbol":"thread_start","symbolLocation":8,"imageIndex":8}]},{"id":13896,"name":"ant_main","threadState":{"x":[{"value":260},{"value":0},{"value":1024},{"value":0},{"value":0},{"value":65704},{"value":2},{"value":999650000},{"value":2561},{"value":0},{"value":5698475568},{"value":2},{"value":0},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8543872160},{"value":0},{"value":5698475544},{"value":5698475608},{"value":1},{"value":999650000},{"value":2},{"value":1024},{"value":2561},{"value":2816},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6625699208},"cpsr":{"value":2684358656},"fp":{"value":6095892080},"sp":{"value":6095891936},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6625445356},"far":{"value":0}},"frames":[{"imageOffset":17900,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":2},{"imageOffset":30088,"symbol":"_pthread_cond_wait","symbolLocation":1272,"imageIndex":8},{"imageOffset":8006524,"imageIndex":1},{"imageOffset":8011172,"imageIndex":1},{"imageOffset":5238036,"imageIndex":1},{"imageOffset":8007840,"imageIndex":1},{"imageOffset":28564,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":8},{"imageOffset":7476,"symbol":"thread_start","symbolLocation":8,"imageIndex":8}]},{"id":13897,"name":"GPS main","threadState":{"x":[{"value":260},{"value":0},{"value":0},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6096465512},{"value":0},{"value":5698476480},{"value":2},{"value":0},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8543872160},{"value":0},{"value":5698476456},{"value":5698476520},{"value":6096466144},{"value":0},{"value":0},{"value":0},{"value":1},{"value":256},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6625699164},"cpsr":{"value":1610616832},"fp":{"value":6096465632},"sp":{"value":6096465488},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6625445356},"far":{"value":0}},"frames":[{"imageOffset":17900,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":2},{"imageOffset":30044,"symbol":"_pthread_cond_wait","symbolLocation":1228,"imageIndex":8},{"imageOffset":8011172,"imageIndex":1},{"imageOffset":8007812,"imageIndex":1},{"imageOffset":28564,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":8},{"imageOffset":7476,"symbol":"thread_start","symbolLocation":8,"imageIndex":8}]},{"id":13898,"name":"SNS main","threadState":{"x":[{"value":260},{"value":0},{"value":0},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6097038952},{"value":0},{"value":5698486752},{"value":2},{"value":0},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8543872160},{"value":0},{"value":5698486728},{"value":5698486792},{"value":6097039584},{"value":0},{"value":0},{"value":0},{"value":1},{"value":256},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6625699164},"cpsr":{"value":1610616832},"fp":{"value":6097039072},"sp":{"value":6097038928},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6625445356},"far":{"value":0}},"frames":[{"imageOffset":17900,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":2},{"imageOffset":30044,"symbol":"_pthread_cond_wait","symbolLocation":1228,"imageIndex":8},{"imageOffset":8011172,"imageIndex":1},{"imageOffset":8007812,"imageIndex":1},{"imageOffset":28564,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":8},{"imageOffset":7476,"symbol":"thread_start","symbolLocation":8,"imageIndex":8}]},{"id":13899,"name":"fit activity","threadState":{"x":[{"value":260},{"value":0},{"value":256},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6097610728},{"value":0},{"value":5698475968},{"value":2},{"value":0},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8543872160},{"value":0},{"value":5698475944},{"value":5698476008},{"value":6097613024},{"value":0},{"value":0},{"value":256},{"value":257},{"value":512},{"value":4394312584},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6625699164},"cpsr":{"value":1610616832},"fp":{"value":6097610848},"sp":{"value":6097610704},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6625445356},"far":{"value":0}},"frames":[{"imageOffset":17900,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":2},{"imageOffset":30044,"symbol":"_pthread_cond_wait","symbolLocation":1228,"imageIndex":8},{"imageOffset":8011172,"imageIndex":1},{"imageOffset":5683504,"imageIndex":1},{"imageOffset":8007840,"imageIndex":1},{"imageOffset":28564,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":8},{"imageOffset":7476,"symbol":"thread_start","symbolLocation":8,"imageIndex":8}]},{"id":13900,"name":"ftm main","threadState":{"x":[{"value":260},{"value":0},{"value":256},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":998942000},{"value":4609},{"value":0},{"value":5698487152},{"value":1099511628034},{"value":256},{"value":0},{"value":256},{"value":1099511628032},{"value":305},{"value":8543872160},{"value":0},{"value":5698487128},{"value":5698487192},{"value":1},{"value":998942000},{"value":0},{"value":256},{"value":4609},{"value":4864},{"value":4393287680,"symbolLocation":32408,"symbol":"guard variable for wxAnyValueTypeImpl<std::__1::function<void ()>>::sm_instance"},{"value":1}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6625699208},"cpsr":{"value":2684358656},"fp":{"value":6098184608},"sp":{"value":6098184464},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6625445356},"far":{"value":0}},"frames":[{"imageOffset":17900,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":2},{"imageOffset":30088,"symbol":"_pthread_cond_wait","symbolLocation":1272,"imageIndex":8},{"imageOffset":8006524,"imageIndex":1},{"imageOffset":8011172,"imageIndex":1},{"imageOffset":5745524,"imageIndex":1},{"imageOffset":8007840,"imageIndex":1},{"imageOffset":28564,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":8},{"imageOffset":7476,"symbol":"thread_start","symbolLocation":8,"imageIndex":8}]},{"id":13901,"name":"TVM main","threadState":{"x":[{"value":260},{"value":0},{"value":4608},{"value":0},{"value":0},{"value":65704},{"value":283},{"value":928982000},{"value":4609},{"value":0},{"value":5698487552},{"value":3298534884098},{"value":768},{"value":0},{"value":768},{"value":3298534884096},{"value":305},{"value":8543872160},{"value":0},{"value":5698487528},{"value":5698487592},{"value":1},{"value":928982000},{"value":283},{"value":4608},{"value":4609},{"value":4864},{"value":4393750528},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6625699208},"cpsr":{"value":2684358656},"fp":{"value":6098759184},"sp":{"value":6098759040},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6625445356},"far":{"value":0}},"frames":[{"imageOffset":17900,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":2},{"imageOffset":30088,"symbol":"_pthread_cond_wait","symbolLocation":1272,"imageIndex":8},{"imageOffset":8006524,"imageIndex":1},{"imageOffset":8011172,"imageIndex":1},{"imageOffset":7638816,"imageIndex":1},{"imageOffset":8007840,"imageIndex":1},{"imageOffset":28564,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":8},{"imageOffset":7476,"symbol":"thread_start","symbolLocation":8,"imageIndex":8}]},{"id":13902,"name":"TVM defrag","threadState":{"x":[{"value":260},{"value":0},{"value":0},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6099332712},{"value":0},{"value":5698488336},{"value":2},{"value":0},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8543872160},{"value":0},{"value":5698488312},{"value":5698488376},{"value":6099333344},{"value":0},{"value":0},{"value":0},{"value":1},{"value":256},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6625699164},"cpsr":{"value":1610616832},"fp":{"value":6099332832},"sp":{"value":6099332688},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6625445356},"far":{"value":0}},"frames":[{"imageOffset":17900,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":2},{"imageOffset":30044,"symbol":"_pthread_cond_wait","symbolLocation":1228,"imageIndex":8},{"imageOffset":8011172,"imageIndex":1},{"imageOffset":8007812,"imageIndex":1},{"imageOffset":28564,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":8},{"imageOffset":7476,"symbol":"thread_start","symbolLocation":8,"imageIndex":8}]},{"id":13907,"name":"parse main","threadState":{"x":[{"value":260},{"value":0},{"value":0},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6099905048},{"value":0},{"value":5699180864},{"value":2},{"value":0},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8543872160},{"value":0},{"value":5699180840},{"value":5699180904},{"value":6099906784},{"value":0},{"value":0},{"value":0},{"value":1},{"value":256},{"value":922337203685477580},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6625699164},"cpsr":{"value":1610616832},"fp":{"value":6099905168},"sp":{"value":6099905024},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6625445356},"far":{"value":0}},"frames":[{"imageOffset":17900,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":2},{"imageOffset":30044,"symbol":"_pthread_cond_wait","symbolLocation":1228,"imageIndex":8},{"imageOffset":8011172,"imageIndex":1},{"imageOffset":128728,"imageIndex":1},{"imageOffset":8007840,"imageIndex":1},{"imageOffset":28564,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":8},{"imageOffset":7476,"symbol":"thread_start","symbolLocation":8,"imageIndex":8}]},{"id":13908,"name":"GPX archive trk","threadState":{"x":[{"value":260},{"value":0},{"value":256},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6100479368},{"value":0},{"value":5699181264},{"value":2},{"value":0},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8543872160},{"value":0},{"value":5699181240},{"value":5699181304},{"value":6100480224},{"value":0},{"value":0},{"value":256},{"value":257},{"value":512},{"value":5400},{"value":3518437209}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6625699164},"cpsr":{"value":1610616832},"fp":{"value":6100479488},"sp":{"value":6100479344},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6625445356},"far":{"value":0}},"frames":[{"imageOffset":17900,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":2},{"imageOffset":30044,"symbol":"_pthread_cond_wait","symbolLocation":1228,"imageIndex":8},{"imageOffset":8011172,"imageIndex":1},{"imageOffset":8530496,"imageIndex":1},{"imageOffset":8007840,"imageIndex":1},{"imageOffset":28564,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":8},{"imageOffset":7476,"symbol":"thread_start","symbolLocation":8,"imageIndex":8}]},{"id":13909,"name":"URM Main","threadState":{"x":[{"value":260},{"value":0},{"value":256},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6101053000},{"value":0},{"value":5699182208},{"value":2},{"value":0},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8543872160},{"value":0},{"value":5699182184},{"value":5699182248},{"value":6101053664},{"value":0},{"value":0},{"value":256},{"value":257},{"value":512},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6625699164},"cpsr":{"value":1610616832},"fp":{"value":6101053120},"sp":{"value":6101052976},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6625445356},"far":{"value":0}},"frames":[{"imageOffset":17900,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":2},{"imageOffset":30044,"symbol":"_pthread_cond_wait","symbolLocation":1228,"imageIndex":8},{"imageOffset":8011172,"imageIndex":1},{"imageOffset":5570956,"imageIndex":1},{"imageOffset":8007840,"imageIndex":1},{"imageOffset":28564,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":8},{"imageOffset":7476,"symbol":"thread_start","symbolLocation":8,"imageIndex":8}]},{"id":13910,"name":"mma sql bkg","threadState":{"x":[{"value":260},{"value":0},{"value":0},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6101626472},{"value":0},{"value":5699182608},{"value":2},{"value":0},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8543872160},{"value":0},{"value":5699182584},{"value":5699182648},{"value":6101627104},{"value":0},{"value":0},{"value":0},{"value":1},{"value":256},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6625699164},"cpsr":{"value":1610616832},"fp":{"value":6101626592},"sp":{"value":6101626448},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6625445356},"far":{"value":0}},"frames":[{"imageOffset":17900,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":2},{"imageOffset":30044,"symbol":"_pthread_cond_wait","symbolLocation":1228,"imageIndex":8},{"imageOffset":8011172,"imageIndex":1},{"imageOffset":8007812,"imageIndex":1},{"imageOffset":28564,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":8},{"imageOffset":7476,"symbol":"thread_start","symbolLocation":8,"imageIndex":8}]},{"id":13942,"name":"TLG main","threadState":{"x":[{"value":260},{"value":0},{"value":256},{"value":0},{"value":0},{"value":65704},{"value":15080},{"value":999919000},{"value":257},{"value":0},{"value":5678073296},{"value":2},{"value":0},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8543872160},{"value":0},{"value":5678073272},{"value":5678073336},{"value":1},{"value":999919000},{"value":15080},{"value":256},{"value":257},{"value":512},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6625699208},"cpsr":{"value":2684358656},"fp":{"value":6102773360},"sp":{"value":6102773216},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6625445356},"far":{"value":0}},"frames":[{"imageOffset":17900,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":2},{"imageOffset":30088,"symbol":"_pthread_cond_wait","symbolLocation":1272,"imageIndex":8},{"imageOffset":8006524,"imageIndex":1},{"imageOffset":8011172,"imageIndex":1},{"imageOffset":8529924,"imageIndex":1},{"imageOffset":8007864,"imageIndex":1},{"imageOffset":28564,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":8},{"imageOffset":7476,"symbol":"thread_start","symbolLocation":8,"imageIndex":8}]},{"id":13943,"name":"libcurl Async H","threadState":{"x":[{"value":260},{"value":0},{"value":0},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6103346664},{"value":0},{"value":5678074656},{"value":2},{"value":0},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8543872160},{"value":0},{"value":5678074632},{"value":5678074696},{"value":6103347424},{"value":0},{"value":0},{"value":0},{"value":1},{"value":256},{"value":6103346960},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6625699164},"cpsr":{"value":1610616832},"fp":{"value":6103346784},"sp":{"value":6103346640},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6625445356},"far":{"value":0}},"frames":[{"imageOffset":17900,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":2},{"imageOffset":30044,"symbol":"_pthread_cond_wait","symbolLocation":1228,"imageIndex":8},{"imageOffset":8011172,"imageIndex":1},{"imageOffset":5539704,"imageIndex":1},{"imageOffset":8007864,"imageIndex":1},{"imageOffset":28564,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":8},{"imageOffset":7476,"symbol":"thread_start","symbolLocation":8,"imageIndex":8}]},{"id":13944,"name":"Download Manage","threadState":{"x":[{"value":260},{"value":0},{"value":0},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6103919992},{"value":0},{"value":5678075056},{"value":2},{"value":0},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8543872160},{"value":0},{"value":5678075032},{"value":5678075096},{"value":6103920864},{"value":0},{"value":0},{"value":0},{"value":1},{"value":256},{"value":4389497901},{"value":4394279752}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6625699164},"cpsr":{"value":1610616832},"fp":{"value":6103920112},"sp":{"value":6103919968},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6625445356},"far":{"value":0}},"frames":[{"imageOffset":17900,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":2},{"imageOffset":30044,"symbol":"_pthread_cond_wait","symbolLocation":1228,"imageIndex":8},{"imageOffset":8011172,"imageIndex":1},{"imageOffset":5550852,"imageIndex":1},{"imageOffset":8007864,"imageIndex":1},{"imageOffset":28564,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":8},{"imageOffset":7476,"symbol":"thread_start","symbolLocation":8,"imageIndex":8}]},{"id":13945,"name":"Shell main","threadState":{"x":[{"value":4},{"value":0},{"value":0},{"value":5},{"value":447414800},{"value":6},{"value":2},{"value":0},{"value":4384061484},{"value":4384061324},{"value":447414800},{"value":447349248},{"value":447349248},{"value":447414800},{"value":2147483647},{"value":32775},{"value":30},{"value":0},{"value":0},{"value":5678069328},{"value":4393291776,"symbolLocation":664,"symbol":"guard variable for RequestConsolidator::getInstance()::sSelf"},{"value":4394463232},{"value":4394466700},{"value":4394463232},{"value":2048},{"value":4394463232},{"value":4394466696},{"value":16},{"value":4}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4384060248},"cpsr":{"value":1610616832},"fp":{"value":6104493840},"sp":{"value":6104493776},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6625466068},"far":{"value":0}},"frames":[{"imageOffset":38612,"symbol":"__accept","symbolLocation":8,"imageIndex":2},{"imageOffset":8500056,"imageIndex":1},{"imageOffset":8488468,"imageIndex":1},{"imageOffset":8007840,"imageIndex":1},{"imageOffset":28564,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":8},{"imageOffset":7476,"symbol":"thread_start","symbolLocation":8,"imageIndex":8}]},{"id":13953,"frames":[{"imageOffset":17900,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":2},{"imageOffset":30044,"symbol":"_pthread_cond_wait","symbolLocation":1228,"imageIndex":8},{"imageOffset":68372,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":28,"imageIndex":9},{"imageOffset":790496,"imageIndex":1},{"imageOffset":790208,"imageIndex":1},{"imageOffset":789868,"imageIndex":1},{"imageOffset":28564,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":8},{"imageOffset":7476,"symbol":"thread_start","symbolLocation":8,"imageIndex":8}],"threadState":{"x":[{"value":260},{"value":0},{"value":256},{"value":0},{"value":0},{"value":160},{"value":0},{"value":0},{"value":6105640504},{"value":0},{"value":5729565096},{"value":2},{"value":0},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8543872160},{"value":0},{"value":5729565072},{"value":5729565136},{"value":6105641184},{"value":0},{"value":0},{"value":256},{"value":257},{"value":512},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6625699164},"cpsr":{"value":1610616832},"fp":{"value":6105640624},"sp":{"value":6105640480},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6625445356},"far":{"value":0}}},{"id":13954,"frames":[{"imageOffset":38612,"symbol":"__accept","symbolLocation":8,"imageIndex":2},{"imageOffset":1170580,"imageIndex":1},{"imageOffset":995592,"imageIndex":1},{"imageOffset":9984296,"imageIndex":1},{"imageOffset":9983116,"imageIndex":1},{"imageOffset":28564,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":8},{"imageOffset":7476,"symbol":"thread_start","symbolLocation":8,"imageIndex":8}],"threadState":{"x":[{"value":4},{"value":0},{"value":0},{"value":6106213744},{"value":1},{"value":4294967248},{"value":1},{"value":6},{"value":1},{"value":2290410330336985131},{"value":1922},{"value":3506438593},{"value":1073741824},{"value":5697978496},{"value":30782},{"value":1},{"value":30},{"value":0},{"value":0},{"value":5409408576},{"value":5698475248},{"value":4393753968},{"value":4376555940},{"value":4390426224,"symbolLocation":895296,"symbol":"GFX::PathInterface::RoundedRectangleSize"},{"value":4394090496},{"value":6106214400},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4376730772},"cpsr":{"value":1610616832},"fp":{"value":6106213792},"sp":{"value":6106213760},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6625466068},"far":{"value":0}}},{"id":14010,"name":"Shell handler","threadState":{"x":[{"value":260},{"value":0},{"value":0},{"value":0},{"value":0},{"value":65704},{"value":0},{"value":0},{"value":6106787208},{"value":0},{"value":4393729496},{"value":2},{"value":0},{"value":0},{"value":0},{"value":0},{"value":305},{"value":8543872160},{"value":0},{"value":4393729472},{"value":4393729568},{"value":6106788064},{"value":0},{"value":0},{"value":0},{"value":1},{"value":256},{"value":4393303552},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":6625699164},"cpsr":{"value":1610616832},"fp":{"value":6106787328},"sp":{"value":6106787184},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6625445356},"far":{"value":0}},"frames":[{"imageOffset":17900,"symbol":"__psynch_cvwait","symbolLocation":8,"imageIndex":2},{"imageOffset":30044,"symbol":"_pthread_cond_wait","symbolLocation":1228,"imageIndex":8},{"imageOffset":8005932,"imageIndex":1},{"imageOffset":1167728,"imageIndex":1},{"imageOffset":8499344,"imageIndex":1},{"imageOffset":8496892,"imageIndex":1},{"imageOffset":8490828,"imageIndex":1},{"imageOffset":8007840,"imageIndex":1},{"imageOffset":28564,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":8},{"imageOffset":7476,"symbol":"thread_start","symbolLocation":8,"imageIndex":8}]},{"id":14011,"frames":[{"imageOffset":21376,"symbol":"__recvfrom","symbolLocation":8,"imageIndex":2},{"imageOffset":8501060,"imageIndex":1},{"imageOffset":8497084,"imageIndex":1},{"imageOffset":1157908,"imageIndex":1},{"imageOffset":1186980,"imageIndex":1},{"imageOffset":9984296,"imageIndex":1},{"imageOffset":9983116,"imageIndex":1},{"imageOffset":28564,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":8},{"imageOffset":7476,"symbol":"thread_start","symbolLocation":8,"imageIndex":8}],"threadState":{"x":[{"value":4},{"value":0},{"value":12},{"value":0},{"value":0},{"value":0},{"value":2},{"value":0},{"value":4384061200},{"value":59155},{"value":1548097},{"value":981056},{"value":5677006640},{"value":2},{"value":5676990464},{"value":525392},{"value":29},{"value":8543872256},{"value":0},{"value":12},{"value":5695886432},{"value":5695886384},{"value":12},{"value":5677076080},{"value":48},{"value":9223372036854775792},{"value":4394076872},{"value":4394091312},{"value":4392291456}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4384061252},"cpsr":{"value":1610616832},"fp":{"value":6105066640},"sp":{"value":6105066608},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6625448832},"far":{"value":0}}},{"triggered":true,"id":14028,"threadState":{"x":[{"value":0},{"value":6107932808},{"value":0},{"value":5678107024},{"value":5678107136},{"value":17},{"value":0},{"value":0},{"value":4834198736},{"value":0},{"value":39193937096},{"value":39193937096},{"value":4834198696},{"value":180},{"value":0},{"value":2147516607},{"value":6625894096,"symbolLocation":0,"symbol":"_platform_memset"},{"value":8543874872},{"value":0},{"value":4834131968},{"value":0},{"value":0},{"value":11},{"value":1},{"value":4834198704},{"value":0},{"value":0},{"value":127},{"value":4392591832}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4383360476},"cpsr":{"value":536875008},"fp":{"value":6107932976},"sp":{"value":6107932800},"esr":{"value":2449473542,"description":"(Data Abort) byte read Translation fault"},"pc":{"value":4383360516,"matchesCrashFrame":1},"far":{"value":39193937096}},"frames":[{"imageOffset":7800324,"imageIndex":1},{"imageOffset":7926464,"imageIndex":1},{"imageOffset":7944216,"imageIndex":1},{"imageOffset":7946876,"imageIndex":1},{"imageOffset":7949320,"imageIndex":1},{"imageOffset":7553440,"imageIndex":1},{"imageOffset":7880788,"imageIndex":1},{"imageOffset":1531376,"imageIndex":1},{"imageOffset":1530352,"imageIndex":1},{"imageOffset":1284592,"imageIndex":1},{"imageOffset":1537572,"imageIndex":1},{"imageOffset":1277628,"imageIndex":1},{"imageOffset":1186980,"imageIndex":1},{"imageOffset":9984296,"imageIndex":1},{"imageOffset":9983116,"imageIndex":1},{"imageOffset":28564,"symbol":"_pthread_start","symbolLocation":136,"imageIndex":8},{"imageOffset":7476,"symbol":"thread_start","symbolLocation":8,"imageIndex":8}]},{"id":14033,"frames":[{"imageOffset":7456,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":8}],"threadState":{"x":[{"value":6110228480},{"value":72451},{"value":6109691904},{"value":0},{"value":409604},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6110228480},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6625676576},"far":{"value":0}}},{"id":14161,"frames":[{"imageOffset":7456,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":8}],"threadState":{"x":[{"value":6107361280},{"value":79167},{"value":6106824704},{"value":0},{"value":409604},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6107361280},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6625676576},"far":{"value":0}}},{"id":14162,"frames":[{"imageOffset":7456,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":8}],"threadState":{"x":[{"value":6109081600},{"value":78387},{"value":6108545024},{"value":0},{"value":409604},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6109081600},"esr":{"value":1442840704,"description":" Address size fault"},"pc":{"value":6625676576},"far":{"value":0}}},{"id":14163,"frames":[{"imageOffset":7456,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":8}],"threadState":{"x":[{"value":6109655040},{"value":0},{"value":6109118464},{"value":0},{"value":278532},{"value":18446744073709551615},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0}],"flavor":"ARM_THREAD_STATE64","lr":{"value":0},"cpsr":{"value":4096},"fp":{"value":0},"sp":{"value":6109655040},"esr":{"value":0,"description":" Address size fault"},"pc":{"value":6625676576},"far":{"value":0}}}],
    "usedImages" : [
    "source" : "P",
    "arch" : "arm64e",
    "base" : 4398940160,
    "size" : 49152,
    "uuid" : "7d6ca1cb-c5e6-38b6-9618-2c580486fc6b",
    "path" : "\/usr\/lib\/libobjc-trampolines.dylib",
    "name" : "libobjc-trampolines.dylib"
    "source" : "P",
    "arch" : "arm64",
    "base" : 4375560192,
    "CFBundleShortVersionString" : "7.3.0",
    "CFBundleIdentifier" : "com.garmin.connectiq.simulator",
    "size" : 16613376,
    "uuid" : "c3f78836-7950-350c-871c-1257c0a406d7",
    "path" : "\/Users\/USER\/Library\/Application Support\/Garmin\/*\/ConnectIQ.app\/Contents\/MacOS\/simulator",
    "name" : "simulator",
    "CFBundleVersion" : "7.3.0"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6625427456,
    "size" : 241660,
    "uuid" : "71ff45b8-f14e-3666-9e96-6cf58315b91d",
    "path" : "\/usr\/lib\/system\/libsystem_kernel.dylib",
    "name" : "libsystem_kernel.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6626095104,
    "CFBundleShortVersionString" : "6.9",
    "CFBundleIdentifier" : "com.apple.CoreFoundation",
    "size" : 5083136,
    "uuid" : "55720ee0-d8c3-33a1-9854-8e61a6f44895",
    "path" : "\/System\/Library\/Frameworks\/CoreFoundation.framework\/Versions\/A\/CoreFoundation",
    "name" : "CoreFoundation",
    "CFBundleVersion" : "2602"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6802202624,
    "CFBundleShortVersionString" : "2.1.1",
    "CFBundleIdentifier" : "com.apple.HIToolbox",
    "size" : 2899968,
    "uuid" : "4166f6cb-b599-306c-8568-823bd29a74c3",
    "path" : "\/System\/Library\/Frameworks\/Carbon.framework\/Versions\/A\/Frameworks\/HIToolbox.framework\/Versions\/A\/HIToolbox",
    "name" : "HIToolbox"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6685478912,
    "CFBundleIdentifier" : "com.apple.AppKit",
    "size" : 20180992,
    "uuid" : "7acbeef9-a453-3e4d-98ac-f9441d86e183",
    "path" : "\/System\/Library\/Frameworks\/AppKit.framework\/Versions\/C\/AppKit",
    "name" : "AppKit",
    "CFBundleVersion" : "2487.70.105"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6621958144,
    "size" : 562440,
    "uuid" : "f635824e-318b-3f0c-842c-c369737f2b68",
    "path" : "\/usr\/lib\/dyld",
    "name" : "dyld"
    "size" : 0,
    "source" : "A",
    "base" : 0,
    "uuid" : "00000000-0000-0000-0000-000000000000"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6625669120,
    "size" : 53248,
    "uuid" : "e03e8478-6f5c-3d21-a79a-58408f514000",
    "path" : "\/usr\/lib\/system\/libsystem_pthread.dylib",
    "name" : "libsystem_pthread.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6624735232,
    "size" : 577528,
    "uuid" : "aaa5636d-6f3f-3fa7-9f4a-cf966f0308fe",
    "path" : "\/usr\/lib\/libc++.1.dylib",
    "name" : "libc++.1.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 6625878016,
    "size" : 32744,
    "uuid" : "b4bf9f89-31d7-3742-8ce7-ab3554f9f525",
    "path" : "\/usr\/lib\/system\/libsystem_platform.dylib",
    "name" : "libsystem_platform.dylib"
    "sharedCache" : {
    "base" : 6621200384,
    "size" : 4214358016,
    "uuid" : "bb3df3d3-38bd-304c-9233-e43de95f1903"
    "vmSummary" : "ReadOnly portion of Libraries: Total=1.0G resident=0K(0%) swapped_out_or_unallocated=1.0G(100%)\nWritable regions: Total=1.2G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.2G(100%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced) \n=========== ======= ======= \nAccelerate framework 128K 1 \nActivity Tracing 256K 1 \nCG image 1616K 25 \nCG raster data 848K 2 \nColorSync 624K 30 \nCoreAnimation 1520K 52 \nCoreGraphics 32K 2 \nCoreUI image data 1392K 10 \nDispatch continuations 64.0M 1 \nFoundation 16K 1 \nKernel Alloc Once 32K 1 \nMALLOC 1.1G 77 \nMALLOC guard page 192K 12 \nSTACK GUARD 56.5M 32 \nStack 24.5M 35 \nVM_ALLOCATE 176K 11 \n__AUTH 1157K 254 \n__AUTH_CONST 22.5M 431 \n__CTF 824 1 \n__DATA 9717K 415 \n__DATA_CONST 22.3M 435 \n__DATA_DIRTY 1212K 135 \n__FONT_DATA 4K 1 \n__LINKEDIT 526.8M 3 \n__OBJC_RO 71.9M 1 \n__OBJC_RW 2200K 1 \n__TEXT 528.7M 452 \ndyld private memory 272K 2 \nmapped file 280.0M 35 \nshared memory 864K 14 \n=========== ======= ======= \nTOTAL 2.7G 2473 \n",
    "legacyInfo" : {
    "threadTriggered" : {
    "logWritingSignature" : "33b0ed9dcb456fba10743069cd23f419a1b856e9",
    "trialInfo" : {
    "rollouts" : [
    "rolloutId" : "60186475825c62000ccf5450",
    "factorPackIds" : {
    "deploymentId" : 240000074
    "rolloutId" : "654439cdafbf5b61207873a9",
    "factorPackIds" : {
    "deploymentId" : 240000004
    "experiments" : [
    "treatmentId" : "c47ab4cc-c9c3-4b5d-a87c-e2433ce02597",
    "experimentId" : "6639bc6ba73d460582162323",
    "deploymentId" : 400000006
    "treatmentId" : "45f4e2a5-551b-4bc2-a2dc-19c244dda8f8",
    "experimentId" : "6643969b3099cf28e049862f",
    "deploymentId" : 400000007
    Model: Mac15,13, BootROM 10151.140.19, proc 8:4:4 processors, 16 GB, SMC
    Graphics: Apple M3, Apple M3, Built-In
    Display: Color LCD, spdisplays_2880x1864Retina, Main, MirrorOff, Online
    Memory Module: LPDDR5, Hynix
    AirPort: spairport_wireless_card_type_wifi (0x14E4, 0x4388), wl0: Apr 4 2024 20:57:11 version 23.30.58.0.41.51.138 FWID 01-baea9d27
    AirPort:
    Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports
    Network Service: Wi-Fi, AirPort, en0
    USB Device: USB31Bus
    Thunderbolt Bus: MacBook Air, Apple Inc.
  • The SDK 6.4.2 claims to have been made solely for the purpose of fixing crashes seen in macOS Sonoma.
    Unfortunately I do not see any improvement. It just keeps crashing, can't survive even a few hours.
    It is really sad, because the miserable quality of the simulator makes Mac pretty much useless for any serious Connect IQ development.
    I gave up and switched back to Windows.
    The crashing is not the only problem, although definitely the most troublesome.
    Another problem is that the entry fields for different parameters in the menus don't work properly.
    For example, try to enter Battery Percentage's decimal digit (e.g. 95.5) - it just won't let you. Same thing with walking and running step length in User Profile. But entering decimal point in Set Position menu works without issues.
    Another example in User Profile, when I try to enter Height and Weight, the next time I open it I see Height 243.0 cm and Weight 443.0 kg.
    There are minor issues too which are not critical, but contribute to the overall impression of very poor quality - for instance in View Memory window, the default Size column width is wrong, so you can't see it upon opening, you have to adjust it every time in order to see it.
    Below is my latest crash report.
    Process: simulator [47810]
    Version: 6.4.2 (6.4.2)
    Code Type: X86-64 (Translated)
    User ID: 501
    Date/Time: 2024-03-20 17:22:55.6293 +0700
    OS Version: macOS 14.2.1 (23C71)
    Report Version: 12
    Anonymous UUID: 277CCC3B-2E88-EAA7-7D3F-B4E208A73F60
    Sleep/Wake UUID: AB63B6C3-867E-4F06-B276-6629ACF1A424
    Time Awake Since Boot: 400000 seconds
    Time Since Wake: 15 seconds
    Notes:
    PC register does not match crashing frame (0x0 vs 0x7FF8AA0CAA78)
    Crashed Thread: 6 ant_main
    Exception Type: EXC_CRASH (SIGABRT)
    Exception Codes: 0x0000000000000000, 0x0000000000000000
    Termination Reason: Namespace SIGNAL, Code 6 Abort trap: 6
    Terminating Process: simulator [47810]
    Application Specific Information:
    abort() called
    Error Formulating Crash Report:
    0 AppKit 0x7ff81d1957b9 _DPSNextEvent + 880
    1 AppKit 0x7ff81da8df64 -[NSApplication(NSEventRouting) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1304
    2 AppKit 0x7ff81d186d32 -[NSApplication run] + 603
    3 simulator 0x102eb92fa 0x102445000 + 10961658
    4 simulator 0x102db8e0d 0x102445000 + 9911821
    5 simulator 0x102d2a97e 0x102445000 + 9329022
    6 simulator 0x102cfd293 0x102445000 + 9142931
    7 simulator 0x102e758da 0x102445000 + 10684634
    8 simulator 0x102d5fad8 0x102445000 + 9546456
    9 simulator 0x102486f12 0x102445000 + 270098
    10 dyld 0x203aba386 start + 1942
    Thread 1:: com.apple.rosetta.exceptionserver
    0 runtime 0x7ff7ffe98294 0x7ff7ffe94000 + 17044
    Thread 2:: com.apple.NSEventThread
    0 ??? 0x7ff8aa0caa78 ???
    1 libsystem_kernel.dylib 0x7ff819b0ba2e mach_msg2_trap + 10
    2 libsystem_kernel.dylib 0x7ff819b19e3a mach_msg2_internal + 84
    3 libsystem_kernel.dylib 0x7ff819b12b62 mach_msg_overwrite + 653
    4 libsystem_kernel.dylib 0x7ff819b0bd1f mach_msg + 19
    5 CoreFoundation 0x7ff819c27909 __CFRunLoopServiceMachPort + 143
    6 CoreFoundation 0x7ff819c2637c __CFRunLoopRun + 1371
    7 CoreFoundation 0x7ff819c25859 CFRunLoopRunSpecific + 557
    8 AppKit 0x7ff81d2f2fac _NSEventThread + 122
    9 libsystem_pthread.dylib 0x7ff819b4b202 _pthread_start + 99
    10 libsystem_pthread.dylib 0x7ff819b46bab thread_start + 15
    Thread 3:: TSK bkgd
    1 libsystem_kernel.dylib 0x7ff819b0e5ce __psynch_cvwait + 10
    2 libsystem_pthread.dylib 0x7ff819b4b76b _pthread_cond_wait + 1211
    3 simulator 0x102bd17ba 0x102445000 + 7915450
    4 simulator 0x102bd0a72 0x102445000 + 7912050
    5 libsystem_pthread.dylib 0x7ff819b4b202 _pthread_start + 99
    6 libsystem_pthread.dylib 0x7ff819b46bab thread_start + 15
    Thread 4:: NFM_Region_0
    4 simulator 0x102c45e93 0x102445000 + 8392339
    5 simulator 0x102bd0aa6 0x102445000 + 7912102
    6 libsystem_pthread.dylib 0x7ff819b4b202 _pthread_start + 99
    7 libsystem_pthread.dylib 0x7ff819b46bab thread_start + 15
    Thread 5:: IOPAppMain
    4 simulator 0x102943115 0x102445000 + 5234965
    5 simulator 0x102bd0a90 0x102445000 + 7912080
    Thread 6 Crashed:: ant_main
    1 libsystem_kernel.dylib 0x7ff819b127a2 __pthread_kill + 10
    2 libsystem_pthread.dylib 0x7ff819b4af30 pthread_kill + 262
    3 libsystem_c.dylib 0x7ff819a69a49 abort + 126
    4 simulator 0x1024e3168 0x102445000 + 647528
    5 simulator 0x1030c2b59 0x102445000 + 13097817
    6 simulator 0x1024e2e60 0x102445000 + 646752
    7 simulator 0x102bd4bb2 0x102445000 + 7928754
    8 simulator 0x102bd43b9 0x102445000 + 7926713
    9 simulator 0x102bd97d8 0x102445000 + 7948248
    10 simulator 0x102900447 0x102445000 + 4961351
    11 simulator 0x1029182be 0x102445000 + 5059262
    12 simulator 0x102bd0a90 0x102445000 + 7912080
    13 libsystem_pthread.dylib 0x7ff819b4b202 _pthread_start + 99
    14 libsystem_pthread.dylib 0x7ff819b46bab thread_start + 15
    Thread 7:: GPS main
    Thread 8:: SNS main
    Thread 9:: fit activity
    4 simulator 0x102982562 0x102445000 + 5494114
    Thread 10:: ftm main
    0 simulator 0x102928d10 0x102445000 + 5127440
    1 simulator 0x102c9c8d2 0x102445000 + 8747218
    2 simulator 0x102997497 0x102445000 + 5579927
    3 simulator 0x102991caa 0x102445000 + 5557418
    4 simulator 0x102bd0a90 0x102445000 + 7912080
    Thread 11:: TVM main
    4 simulator 0x102b798d5 0x102445000 + 7555285
    Thread 12:: TVM defrag
    Thread 13:: parse main
    4 simulator 0x10246726b 0x102445000 + 139883
    Thread 14:: GPX archive trk
    4 simulator 0x102c56df5 0x102445000 + 8461813
    Thread 15:: URM Main
    4 simulator 0x102965925 0x102445000 + 5376293
    Thread 16:: mma sql bkg
    Thread 17:: TLG main
    2 libsystem_pthread.dylib 0x7ff819b4b79c _pthread_cond_wait + 1260
    3 simulator 0x102bd0550 0x102445000 + 7910736
    4 simulator 0x102bd17ba 0x102445000 + 7915450
    5 simulator 0x102c56c1e 0x102445000 + 8461342
    6 simulator 0x102bd0aa6 0x102445000 + 7912102
    7 libsystem_pthread.dylib 0x7ff819b4b202 _pthread_start + 99
    8 libsystem_pthread.dylib 0x7ff819b46bab thread_start + 15
    Thread 18:: libcurl Async H
    4 simulator 0x10295f3b5 0x102445000 + 5350325
    Thread 19:: Download Manage
    4 simulator 0x102961905 0x102445000 + 5359877
    Thread 20:: Shell main
    1 libsystem_kernel.dylib 0x7ff819b12832 __accept + 10
    2 simulator 0x102c51af2 0x102445000 + 8440562
    3 simulator 0x102c4e8f7 0x102445000 + 8427767
    Thread 21:
    3 libc++.1.dylib 0x7ff819a833c2 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18
    4 simulator 0x102510182 0x102445000 + 831874
    5 simulator 0x10251007f 0x102445000 + 831615
    6 simulator 0x10250ff22 0x102445000 + 831266
    Thread 22:
    2 simulator 0x1025732bc 0x102445000 + 1237692
    3 simulator 0x10254728c 0x102445000 + 1057420
    4 simulator 0x102dcbdbc 0x102445000 + 9989564
    5 simulator 0x102dcb84f 0x102445000 + 9988175
    Thread 23:: Shell handler
    3 simulator 0x102bd02ec 0x102445000 + 7910124
    4 simulator 0x102572824 0x102445000 + 1234980
    5 simulator 0x102c5186a 0x102445000 + 8439914
    6 simulator 0x102c50dc3 0x102445000 + 8437187
    7 simulator 0x102c4f257 0x102445000 + 8430167
    8 simulator 0x102bd0a90 0x102445000 + 7912080
    Thread 24:
    1 libsystem_kernel.dylib 0x7ff819b0f13a __recvfrom + 10
    2 simulator 0x102c51ed1 0x102445000 + 8441553
    3 simulator 0x102c50e62 0x102445000 + 8437346
    4 simulator 0x10256feaa 0x102445000 + 1224362
    5 simulator 0x1025777ff 0x102445000 + 1255423
    6 simulator 0x102dcbdbc 0x102445000 + 9989564
    7 simulator 0x102dcb84f 0x102445000 + 9988175
    8 libsystem_pthread.dylib 0x7ff819b4b202 _pthread_start + 99
    9 libsystem_pthread.dylib 0x7ff819b46bab thread_start + 15
    Thread 25:
    3 simulator 0x102dc967d 0x102445000 + 9979517
    4 simulator 0x10258daf6 0x102445000 + 1346294
    5 simulator 0x10258d680 0x102445000 + 1345152
    6 simulator 0x1025777ff 0x102445000 + 1255423
    7 simulator 0x102dcbdbc 0x102445000 + 9989564
    8 simulator 0x102dcb84f 0x102445000 + 9988175
    Thread 26:
    0 runtime 0x7ff7ffeb694c 0x7ff7ffe94000 + 141644
    Thread 27:
    Thread 28:: Dispatch queue: com.Metal.DeviceDispatchQueue
    0 IOGPU 0x7ff919d9782d IOGPUResourceSetPurgeable + 9
    1 IOGPU 0x7ff919d919c2 -[IOGPUMetalResource setPurgeableState:] + 212
    2 IOGPU 0x7ff919d925a3 -[IOGPUMetalResourcePool updateResourcePurgeability] + 159
    3 IOGPU 0x7ff919d8affb -[IOGPUMetalDevice updateResourcePoolPurgeability] + 71
    4 IOGPU 0x7ff919d8a0be -[IOGPUMetalDevice periodicUpdateResourcePoolPurgeability] + 68
    5 libdispatch.dylib 0x7ff8199a359a _dispatch_client_callout + 8
    6 libdispatch.dylib 0x7ff8199a60c7 _dispatch_continuation_pop + 523
    7 libdispatch.dylib 0x7ff8199b66f8 _dispatch_source_invoke + 2076
    8 libdispatch.dylib 0x7ff8199a94bb _dispatch_lane_serial_drain + 387
    9 libdispatch.dylib 0x7ff8199aa100 _dispatch_lane_invoke + 377
    10 libdispatch.dylib 0x7ff8199b3aee _dispatch_root_queue_drain_deferred_wlh + 271
    11 libdispatch.dylib 0x7ff8199b33fd _dispatch_workloop_worker_thread + 451
    12 libsystem_pthread.dylib 0x7ff819b47c47 _pthread_wqthread + 327
    13 libsystem_pthread.dylib 0x7ff819b46b97 start_wqthread + 15
    Thread 29:: Dispatch queue: com.Metal.DeviceDispatch
    0 IOKit 0x7ff81d035477 __IONotificationPortSetDispatchQueue_block_invoke + 4
    1 libdispatch.dylib 0x7ff8199a359a _dispatch_client_callout + 8
    2 libdispatch.dylib 0x7ff8199a60c7 _dispatch_continuation_pop + 523
    3 libdispatch.dylib 0x7ff8199b66f8 _dispatch_source_invoke + 2076
    4 libdispatch.dylib 0x7ff8199a94bb _dispatch_lane_serial_drain + 387
    5 libdispatch.dylib 0x7ff8199aa100 _dispatch_lane_invoke + 377
    6 libdispatch.dylib 0x7ff8199b3aee _dispatch_root_queue_drain_deferred_wlh + 271
    7 libdispatch.dylib 0x7ff8199b33fd _dispatch_workloop_worker_thread + 451
    8 libsystem_pthread.dylib 0x7ff819b47c47 _pthread_wqthread + 327
    9 libsystem_pthread.dylib 0x7ff819b46b97 start_wqthread + 15
    Thread 30:
    Thread 6 crashed with X86 Thread State (64-bit):
    rax: 0x0000000000000000 rbx: 0x0000000000000000 rcx: 0x0000000000000000 rdx: 0x0000000000000000
    rdi: 0x000000010357a828 rsi: 0x000000030a4af000 rbp: 0x0000000000000000 rsp: 0x0000000000000000
    r8: 0x000000030a4ae588 r9: 0x0000000000000000 r10: 0x0000000000000000 r11: 0x0000000000000043
    r12: 0x000000000000ad03 r13: 0x0000000000000000 r14: 0x000000030a4af000 r15: 0x0000000000000016
    rip: <unavailable> rfl: 0x0000000000000287
    tmp0: 0xffffffffffffffff tmp1: 0x00007ff8aa0caa4c tmp2: 0x00007ff819b12798
    Binary Images:
    0x203ab4000 - 0x203b53fff dyld (*) <ab17bf63-259b-3b48-8d70-863166a2191c> /usr/lib/dyld
    0x10d586000 - 0x10d595fff libobjc-trampolines.dylib (*) <c35523ac-5fc8-3185-b4fb-28be5af3f218> /usr/lib/libobjc-trampolines.dylib
    0x7ff7ffe94000 - 0x7ff7ffec3fff runtime (*) <c4c97159-5c72-3e75-ba2d-d6ca98ea626f> /usr/libexec/rosetta/runtime
    0x10cd8d000 - 0x10cde0fff libRosettaRuntime (*) <7af8ba1e-5c4d-393d-99cd-92566f60c450> /Library/Apple/*/libRosettaRuntime
    0x102445000 - 0x103410fff com.garmin.connectiq.simulator (6.4.2) <8b447e7e-4cdb-3243-926d-9048585fcb2c> /Users/USER/Library/Application Support/Garmin/*/ConnectIQ.app/Contents/MacOS/simulator
    0x7ff81d157000 - 0x7ff81e563ffb com.apple.AppKit (6.9) <20292f0b-3eb2-3566-91e2-ea657457d71d> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x7ff819b0a000 - 0x7ff819b44ff7 libsystem_kernel.dylib (*) <9927a0a9-dfa8-3ffa-88d8-62055f37a137> /usr/lib/system/libsystem_kernel.dylib
    0x7ff819bab000 - 0x7ff81a044ffc com.apple.CoreFoundation (6.9) <fd59424c-be72-3201-b98c-0421b284ffbb> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x7ff819b45000 - 0x7ff819b50fff libsystem_pthread.dylib (*) <a9ba8a53-d774-3fe9-8bde-64187bff7ea9> /usr/lib/system/libsystem_pthread.dylib
    0x7ff8199ea000 - 0x7ff819a71fff libsystem_c.dylib (*) <29a0020e-3766-39df-80fe-9aa731847daa> /usr/lib/system/libsystem_c.dylib
    0x7ff819a72000 - 0x7ff819af0fff libc++.1.dylib (*) <c4311955-de8c-341a-bf4e-46f9a9b26d7a> /usr/lib/libc++.1.dylib
    0x7ff919d80000 - 0x7ff919db7ff1 com.apple.IOGPU (93.10.1) <34e8d18c-7efd-3f68-a802-4f73a4382deb> /System/Library/PrivateFrameworks/IOGPU.framework/Versions/A/IOGPU
    0x7ff8199a0000 - 0x7ff8199e6ffd libdispatch.dylib (*) <895cad19-704c-3ff8-b148-23689a163b12> /usr/lib/system/libdispatch.dylib
    0x7ff81d030000 - 0x7ff81d0f2ff7 com.apple.framework.IOKit (2.0.2) <d556ec12-074c-30d8-958e-7b88c4b1178c> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
    VM Region Summary:
    ReadOnly portion of Libraries: Total=794.9M resident=0K(0%) swapped_out_or_unallocated=794.9M(100%)
    Writable regions: Total=1.4G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.4G(100%)
    VIRTUAL REGION
    Accelerate framework 256K 2
    CG image 3220K 40
    CG raster data 2232K 2
    ColorSync 252K 33
    CoreAnimation 4804K 50
    CoreGraphics 12K 2
    CoreUI image data 2932K 22
    Foundation 40K 2
    Kernel Alloc Once 8K 1
    MALLOC 1.1G 63
    Rosetta Arena 4096K 2
    Rosetta Generic 1792K 445
    Rosetta IndirectBranch 1024K 1
    Rosetta JIT 128.0M 1
    Rosetta Return Stack 600K 60
    Rosetta Thread Context 600K 60
    STACK GUARD 12K 3
    Stack 22.8M 33
    Stack Guard 56.1M 27
    VM_ALLOCATE 4804K 14
    VM_ALLOCATE (reserved) 4K 1 reserved VM address space (unallocated)
    __CTF 824 1
    __DATA 32.5M 539
    __DATA_CONST 36.6M 341
    __DATA_DIRTY 1523K 177
    __FONT_DATA 2352 1
    __INFO_FILTER 8 1
    __LINKEDIT 144.3M 10
    __OBJC_RO 71.1M 1
    __OBJC_RW 2166K 3
    __TEXT 650.6M 559
    dyld private memory 260K 2
    mapped file 7.2G 875
    shared memory 816K 17
    unshared pmap 14.6M 10
    TOTAL 9.5G 3415
    TOTAL, minus reserved VM space 9.5G 3415
    Full Report
    {"app_name":"simulator","timestamp":"2024-03-20 17:22:59.00 +0700","app_version":"6.4.2","slice_uuid":"8b447e7e-4cdb-3243-926d-9048585fcb2c","build_version":"6.4.2","platform":1,"bundleID":"com.garmin.connectiq.simulator","share_with_app_devs":1,"is_first_party":0,"bug_type":"309","os_version":"macOS 14.2.1 (23C71)","roots_installed":0,"name":"simulator","incident_id":"2087872B-B054-4E13-A11B-C2DBCF820703"}
    "uptime" : 400000,
    "procRole" : "Background",
    "version" : 2,
    "userID" : 501,
    "modelCode" : "MacBookAir10,1",
    "coalitionID" : 12834,
    "osVersion" : {
    "train" : "macOS 14.2.1",
    "build" : "23C71",
    "captureTime" : "2024-03-20 17:22:55.6293 +0700",
    "incident" : "2087872B-B054-4E13-A11B-C2DBCF820703",
    "pid" : 47810,
    "translated" : true,
    "cpuType" : "X86-64",
    "bug_type" : "309",
    "procLaunch" : "2024-03-20 11:50:58.0600 +0700",
    "procStartAbsTime" : 9188334550025,
    "procExitAbsTime" : 9616875107620,
    "bundleInfo" : {"CFBundleShortVersionString":"6.4.2","CFBundleVersion":"6.4.2","CFBundleIdentifier":"com.garmin.connectiq.simulator"},
    "storeInfo" : {"deviceIdentifierForVendor":"8328F350-2F45-5923-BD5F-2C5ABB306647","thirdParty":true},
    "parentPid" : 1,
    "crashReporterKey" : "277CCC3B-2E88-EAA7-7D3F-B4E208A73F60",
    "lowPowerMode" : 1,
    "wakeTime" : 15,
    "sleepWakeUUID" : "AB63B6C3-867E-4F06-B276-6629ACF1A424",
    "sip" : "enabled",
    "exception" : {"codes":"0x0000000000000000, 0x0000000000000000","rawCodes":[0,0],"type":"EXC_CRASH","signal":"SIGABRT"},
    "termination" : {"flags":0,"code":6,"namespace":"SIGNAL","indicator":"Abort trap: 6","byProc":"simulator","byPid":47810},
    "asi" : {"libsystem_c.dylib":["abort() called"]},
    "faultingThread" : 6,
    "threads" : [{"id":2963658,"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":13052673568},"r12":{"value":0},"rosetta":{"tmp2":{"value":140706060075144},"tmp1":{"value":140703616817081},"tmp0":{"value":140703616817081}},"rbx":{"value":0},"r8":{"value":2963658},"r15":{"value":140704689010312,"symbolLocation":0,"symbol":"_NSConcreteStackBlock"},"r10":{"value":0},"rdx":{"value":140704658355969,"symbolLocation":1,"symbol":"__CFOASafe"},"rdi":{"value":140648009254592},"r9":{"value":18446744069414584320},"r13":{"value":18446744073709551615},"rflags":{"value":514},"rax":{"value":1},"rsp":{"value":13052672592},"r11":{"value":701696},"rcx":{"value":281474976733568},"r14":{"value":140704631175752},"rsi":{"value":140704658355992,"symbolLocation":0,"symbol":"__CFRuntimeClassTables"}},"queue":"com.apple.main-thread","frames":[{"imageOffset":255929,"symbol":"_DPSNextEvent","symbolLocation":880,"imageIndex":5},{"imageOffset":9662308,"symbol":"-[NSApplication(NSEventRouting) _nextEventMatchingEventMask:untilDate:inMode:dequeue:]","symbolLocation":1304,"imageIndex":5},{"imageOffset":195890,"symbol":"-[NSApplication run]","symbolLocation":603,"imageIndex":5},{"imageOffset":10961658,"imageIndex":4},{"imageOffset":9911821,"imageIndex":4},{"imageOffset":9329022,"imageIndex":4},{"imageOffset":9142931,"imageIndex":4},{"imageOffset":10684634,"imageIndex":4},{"imageOffset":9546456,"imageIndex":4},{"imageOffset":270098,"imageIndex":4},{"imageOffset":25478,"symbol":"start","symbolLocation":1942,"imageIndex":0}]},{"id":2963667,"name":"com.apple.rosetta.exceptionserver","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":9908489551872},"r12":{"value":0},"rosetta":{"tmp2":{"value":0},"tmp1":{"value":0},"tmp0":{"value":0}},"rbx":{"value":0},"r8":{"value":2307},"r15":{"value":0},"r10":{"value":4510958404},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":4510958436},"r13":{"value":0},"rflags":{"value":515},"rax":{"value":268451845},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":17314086914},"r14":{"value":0},"rsi":{"value":2616}},"frames":[{"imageOffset":17044,"imageIndex":2}]},{"id":2963777,"name":"com.apple.NSEventThread","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":162757785681920},"r12":{"value":4294967295},"rosetta":{"tmp2":{"value":140703559687738},"tmp1":{"value":140705981573992},"tmp0":{"value":18446744073709551615}},"rbx":{"value":162757785681920},"r8":{"value":0},"r15":{"value":162757785681920},"r10":{"value":162757785681920},"rdx":{"value":8589934592},"rdi":{"value":4294967295},"r9":{"value":162757785681920},"r13":{"value":21592279046},"rflags":{"value":643},"rax":{"value":268451845},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":21592279046},"r14":{"value":2},"rsi":{"value":2}},"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":6702,"symbol":"mach_msg2_trap","symbolLocation":10,"imageIndex":7},{"imageOffset":65082,"symbol":"mach_msg2_internal","symbolLocation":84,"imageIndex":7},{"imageOffset":35682,"symbol":"mach_msg_overwrite","symbolLocation":653,"imageIndex":7},{"imageOffset":7455,"symbol":"mach_msg","symbolLocation":19,"imageIndex":7},{"imageOffset":510217,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":143,"imageIndex":8},{"imageOffset":504700,"symbol":"__CFRunLoopRun","symbolLocation":1371,"imageIndex":8},{"imageOffset":501849,"symbol":"CFRunLoopRunSpecific","symbolLocation":557,"imageIndex":8},{"imageOffset":1687468,"symbol":"_NSEventThread","symbolLocation":122,"imageIndex":5},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}]},{"id":2963778,"name":"TSK bkgd","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703559640516},"tmp1":{"value":140705981573708},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703559897549,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13055975424},"rsi":{"value":0}},"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":17870,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":7},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":9},{"imageOffset":7915450,"imageIndex":4},{"imageOffset":7912050,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}]},{"id":2963779,"name":"NFM_Region_0","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703559640516},"tmp1":{"value":140705981573708},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703559897549,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":12288},"r10":{"value":0},"rdx":{"value":12288},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":52780853113088},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":768},"rcx":{"value":0},"r14":{"value":13056512000},"rsi":{"value":0}},"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":17870,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":7},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":9},{"imageOffset":7915450,"imageIndex":4},{"imageOffset":8392339,"imageIndex":4},{"imageOffset":7912102,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}]},{"id":2963780,"name":"IOPAppMain","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703559640516},"tmp1":{"value":140705981573708},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703559897549,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13057048576},"rsi":{"value":0}},"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":17870,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":7},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":9},{"imageOffset":7915450,"imageIndex":4},{"imageOffset":5234965,"imageIndex":4},{"imageOffset":7912080,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}]},{"triggered":true,"id":2963781,"name":"ant_main","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":0},"r12":{"value":44291},"rosetta":{"tmp2":{"value":140703559657368},"tmp1":{"value":140705981573708},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":13057582472},"r15":{"value":22},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":4351043624},"r9":{"value":0},"r13":{"value":0},"rflags":{"value":647},"rax":{"value":0},"rsp":{"value":0},"r11":{"value":67},"rcx":{"value":0},"r14":{"value":13057585152},"rsi":{"value":13057585152}},"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":34722,"symbol":"__pthread_kill","symbolLocation":10,"imageIndex":7},{"imageOffset":24368,"symbol":"pthread_kill","symbolLocation":262,"imageIndex":9},{"imageOffset":522825,"symbol":"abort","symbolLocation":126,"imageIndex":10},{"imageOffset":647528,"imageIndex":4},{"imageOffset":13097817,"imageIndex":4},{"imageOffset":646752,"imageIndex":4},{"imageOffset":7928754,"imageIndex":4},{"imageOffset":7926713,"imageIndex":4},{"imageOffset":7948248,"imageIndex":4},{"imageOffset":4961351,"imageIndex":4},{"imageOffset":5059262,"imageIndex":4},{"imageOffset":7912080,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}]},{"id":2963782,"name":"GPS main","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703559640516},"tmp1":{"value":140705981573708},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703559897549,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13058121728},"rsi":{"value":0}},"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":17870,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":7},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":9},{"imageOffset":7915450,"imageIndex":4},{"imageOffset":7912050,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}]},{"id":2963783,"name":"SNS main","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703559640516},"tmp1":{"value":140705981573708},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703559897549,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13058658304},"rsi":{"value":0}},"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":17870,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":7},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":9},{"imageOffset":7915450,"imageIndex":4},{"imageOffset":7912050,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}]},{"id":2963784,"name":"fit activity","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703559640516},"tmp1":{"value":140705981573708},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703559897549,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":256},"r10":{"value":0},"rdx":{"value":256},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":1103806595584},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13059194880},"rsi":{"value":0}},"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":17870,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":7},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":9},{"imageOffset":7915450,"imageIndex":4},{"imageOffset":5494114,"imageIndex":4},{"imageOffset":7912080,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}]},{"id":2963785,"name":"ftm main","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":13059729568},"r12":{"value":255},"rosetta":{"tmp2":{"value":4361048740},"tmp1":{"value":4377748320},"tmp0":{"value":4338126096}},"rbx":{"value":8},"r8":{"value":18},"r15":{"value":17837311},"r10":{"value":0},"rdx":{"value":1},"rdi":{"value":30},"r9":{"value":4294967295},"r13":{"value":0},"rflags":{"value":518},"rax":{"value":4337942002},"rsp":{"value":13059729544},"r11":{"value":0},"rcx":{"value":4337942080},"r14":{"value":144},"rsi":{"value":0}},"frames":[{"imageOffset":5127440,"imageIndex":4},{"imageOffset":8747218,"imageIndex":4},{"imageOffset":5579927,"imageIndex":4},{"imageOffset":5557418,"imageIndex":4},{"imageOffset":7912080,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}]},{"id":2963786,"name":"TVM main","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703559640516},"tmp1":{"value":140705981573708},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703559897549,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":4352},"r10":{"value":0},"rdx":{"value":4352},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":18695992644096},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13060268032},"rsi":{"value":0}},"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":17870,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":7},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":9},{"imageOffset":7915450,"imageIndex":4},{"imageOffset":7555285,"imageIndex":4},{"imageOffset":7912080,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}]},{"id":2963787,"name":"TVM defrag","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703559640516},"tmp1":{"value":140705981573708},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703559897549,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13060804608},"rsi":{"value":0}},"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":17870,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":7},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":9},{"imageOffset":7915450,"imageIndex":4},{"imageOffset":7912050,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}]},{"id":2963797,"name":"parse main","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703559640516},"tmp1":{"value":140705981573708},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703559897549,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13061341184},"rsi":{"value":0}},"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":17870,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":7},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":9},{"imageOffset":7915450,"imageIndex":4},{"imageOffset":139883,"imageIndex":4},{"imageOffset":7912080,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}]},{"id":2963798,"name":"GPX archive trk","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703559640516},"tmp1":{"value":140705981573708},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703559897549,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":256},"r10":{"value":0},"rdx":{"value":256},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":1103806595584},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13061877760},"rsi":{"value":0}},"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":17870,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":7},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":9},{"imageOffset":7915450,"imageIndex":4},{"imageOffset":8461813,"imageIndex":4},{"imageOffset":7912080,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}]},{"id":2963799,"name":"URM Main","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703559640516},"tmp1":{"value":140705981573708},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703559897549,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":256},"r10":{"value":0},"rdx":{"value":256},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":1103806595584},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13062414336},"rsi":{"value":0}},"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":17870,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":7},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":9},{"imageOffset":7915450,"imageIndex":4},{"imageOffset":5376293,"imageIndex":4},{"imageOffset":7912080,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}]},{"id":2963800,"name":"mma sql bkg","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703559640516},"tmp1":{"value":140705981573708},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703559897549,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13062950912},"rsi":{"value":0}},"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":17870,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":7},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":9},{"imageOffset":7915450,"imageIndex":4},{"imageOffset":7912050,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}]},{"id":2963802,"name":"TLG main","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":999974000},"rosetta":{"tmp2":{"value":140703559640516},"tmp1":{"value":140705981573708},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":13064023688},"r15":{"value":256},"r10":{"value":0},"rdx":{"value":256},"rdi":{"value":999974000},"r9":{"value":65704},"r13":{"value":1103806595584},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":512},"rsi":{"value":43740}},"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":17870,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":7},{"imageOffset":26524,"symbol":"_pthread_cond_wait","symbolLocation":1260,"imageIndex":9},{"imageOffset":7910736,"imageIndex":4},{"imageOffset":7915450,"imageIndex":4},{"imageOffset":8461342,"imageIndex":4},{"imageOffset":7912102,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}]},{"id":2963803,"name":"libcurl Async H","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703559640516},"tmp1":{"value":140705981573708},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703559897549,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13064560640},"rsi":{"value":0}},"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":17870,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":7},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":9},{"imageOffset":7915450,"imageIndex":4},{"imageOffset":5350325,"imageIndex":4},{"imageOffset":7912102,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}]},{"id":2963804,"name":"Download Manage","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703559640516},"tmp1":{"value":140705981573708},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703559897549,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13065097216},"rsi":{"value":0}},"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":17870,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":7},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":9},{"imageOffset":7915450,"imageIndex":4},{"imageOffset":5359877,"imageIndex":4},{"imageOffset":7912102,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}]},{"id":2963805,"name":"Shell main","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":4286709759},"r12":{"value":140648007806520},"rosetta":{"tmp2":{"value":140703559657512},"tmp1":{"value":140705981573708},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":0},"r15":{"value":140647462915408},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":4351622168},"r9":{"value":4286709759},"r13":{"value":4351621792},"rflags":{"value":646},"rax":{"value":4},"rsp":{"value":3566},"r11":{"value":4286578688},"rcx":{"value":0},"r14":{"value":4351621920},"rsi":{"value":140647462917408}},"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":34866,"symbol":"__accept","symbolLocation":10,"imageIndex":7},{"imageOffset":8440562,"imageIndex":4},{"imageOffset":8427767,"imageIndex":4},{"imageOffset":7912080,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}]},{"id":2963811,"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":17870,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":7},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":9},{"imageOffset":70594,"symbol":"std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&)","symbolLocation":18,"imageIndex":11},{"imageOffset":831874,"imageIndex":4},{"imageOffset":831615,"imageIndex":4},{"imageOffset":831266,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":160},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703559640516},"tmp1":{"value":140705981573708},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703559897549,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":160},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13066706944},"rsi":{"value":0}}},{"id":2963813,"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":34866,"symbol":"__accept","symbolLocation":10,"imageIndex":7},{"imageOffset":1237692,"imageIndex":4},{"imageOffset":1057420,"imageIndex":4},{"imageOffset":9989564,"imageIndex":4},{"imageOffset":9988175,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":5742},"r12":{"value":4334056224},"rosetta":{"tmp2":{"value":140703559657512},"tmp1":{"value":140705981573708},"tmp0":{"value":18446744073709551615}},"rbx":{"value":13067242888},"r8":{"value":13067243024},"r15":{"value":4351065016},"r10":{"value":13067242888},"rdx":{"value":0},"rdi":{"value":140648007539632},"r9":{"value":5742},"r13":{"value":13067243520},"rflags":{"value":646},"rax":{"value":4},"rsp":{"value":1},"r11":{"value":4294967168},"rcx":{"value":0},"r14":{"value":140648007539632},"rsi":{"value":140648007539568}}},{"id":2964406,"name":"Shell handler","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703559640516},"tmp1":{"value":140705981573708},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703559897549,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":65704},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13053767680},"rsi":{"value":0}},"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":17870,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":7},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":9},{"imageOffset":7910124,"imageIndex":4},{"imageOffset":1234980,"imageIndex":4},{"imageOffset":8439914,"imageIndex":4},{"imageOffset":8437187,"imageIndex":4},{"imageOffset":8430167,"imageIndex":4},{"imageOffset":7912080,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}]},{"id":2964407,"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":20794,"symbol":"__recvfrom","symbolLocation":10,"imageIndex":7},{"imageOffset":8441553,"imageIndex":4},{"imageOffset":8437346,"imageIndex":4},{"imageOffset":1224362,"imageIndex":4},{"imageOffset":1255423,"imageIndex":4},{"imageOffset":9989564,"imageIndex":4},{"imageOffset":9988175,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":0},"r12":{"value":12},"rosetta":{"tmp2":{"value":140703559643440},"tmp1":{"value":140705981573708},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":13066169628},"r15":{"value":140647460833264},"r10":{"value":0},"rdx":{"value":12},"rdi":{"value":140647460833312},"r9":{"value":0},"r13":{"value":13066169601},"rflags":{"value":646},"rax":{"value":4},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":140647460833312},"rsi":{"value":140647460833264}}},{"id":2964434,"frames":[{"imageOffset":140705981573752,"imageIndex":6},{"imageOffset":17870,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":7},{"imageOffset":26475,"symbol":"_pthread_cond_wait","symbolLocation":1211,"imageIndex":9},{"imageOffset":9979517,"imageIndex":4},{"imageOffset":1346294,"imageIndex":4},{"imageOffset":1345152,"imageIndex":4},{"imageOffset":1255423,"imageIndex":4},{"imageOffset":9989564,"imageIndex":4},{"imageOffset":9988175,"imageIndex":4},{"imageOffset":25090,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":9},{"imageOffset":7083,"symbol":"thread_start","symbolLocation":15,"imageIndex":9}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":4256},"r12":{"value":999388000},"rosetta":{"tmp2":{"value":140703559640516},"tmp1":{"value":140705981573708},"tmp0":{"value":18446744073709551615}},"rbx":{"value":140648007865600},"r8":{"value":140703559897549,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":1530112},"r10":{"value":140648007865600},"rdx":{"value":1530112},"rdi":{"value":999388000},"r9":{"value":4256},"r13":{"value":6578382365483008},"rflags":{"value":659},"rax":{"value":0},"rsp":{"value":2199023256064},"r11":{"value":512},"rcx":{"value":0},"r14":{"value":13067780096},"rsi":{"value":2}}},{"id":3062583,"frames":[{"imageOffset":141644,"imageIndex":2}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":18446744073709551615},"r12":{"value":0},"rosetta":{"tmp2":{"value":0},"tmp1":{"value":0},"tmp0":{"value":0}},"rbx":{"value":0},"r8":{"value":0},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":13053792256},"rdi":{"value":0},"r9":{"value":0},"r13":{"value":0},"rflags":{"value":531},"rax":{"value":13054328832},"rsp":{"value":409604},"r11":{"value":0},"rcx":{"value":73639},"r14":{"value":0},"rsi":{"value":0}}},{"id":3062792,"frames":[{"imageOffset":141644,"imageIndex":2}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":18446744073709551615},"r12":{"value":0},"rosetta":{"tmp2":{"value":0},"tmp1":{"value":0},"tmp0":{"value":0}},"rbx":{"value":0},"r8":{"value":0},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":13052694528},"rdi":{"value":0},"r9":{"value":0},"r13":{"value":0},"rflags":{"value":531},"rax":{"value":13053231104},"rsp":{"value":409604},"r11":{"value":0},"rcx":{"value":103035},"r14":{"value":0},"rsi":{"value":0}}},{"id":3063151,"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":13054883600},"r12":{"value":140646925953840},"rosetta":{"tmp2":{"value":140707857242562},"tmp1":{"value":20467},"tmp0":{"value":140646925953864}},"rbx":{"value":13054883620},"r8":{"value":481},"r15":{"value":0},"r10":{"value":140708996583000,"symbolLocation":0,"symbol":"OBJC_CLASS_$_IOGPUMetalPooledResource"},"rdx":{"value":13054883620},"rdi":{"value":140646925676880},"r9":{"value":0},"r13":{"value":140708956840376,"symbolLocation":0,"symbol":"OBJC_IVAR_$_IOGPUMetalPooledResource._priv"},"rflags":{"value":582},"rax":{"value":0},"rsp":{"value":13054883584},"r11":{"value":140707857242350,"symbolLocation":0,"symbol":"-[IOGPUMetalResource setPurgeableState:]"},"rcx":{"value":24},"r14":{"value":140646924656856},"rsi":{"value":3}},"queue":"com.Metal.DeviceDispatchQueue","frames":[{"imageOffset":96301,"symbol":"IOGPUResourceSetPurgeable","symbolLocation":9,"imageIndex":12},{"imageOffset":72130,"symbol":"-[IOGPUMetalResource setPurgeableState:]","symbolLocation":212,"imageIndex":12},{"imageOffset":75171,"symbol":"-[IOGPUMetalResourcePool updateResourcePurgeability]","symbolLocation":159,"imageIndex":12},{"imageOffset":45051,"symbol":"-[IOGPUMetalDevice updateResourcePoolPurgeability]","symbolLocation":71,"imageIndex":12},{"imageOffset":41150,"symbol":"-[IOGPUMetalDevice periodicUpdateResourcePoolPurgeability]","symbolLocation":68,"imageIndex":12},{"imageOffset":13722,"symbol":"_dispatch_client_callout","symbolLocation":8,"imageIndex":13},{"imageOffset":24775,"symbol":"_dispatch_continuation_pop","symbolLocation":523,"imageIndex":13},{"imageOffset":91896,"symbol":"_dispatch_source_invoke","symbolLocation":2076,"imageIndex":13},{"imageOffset":38075,"symbol":"_dispatch_lane_serial_drain","symbolLocation":387,"imageIndex":13},{"imageOffset":41216,"symbol":"_dispatch_lane_invoke","symbolLocation":377,"imageIndex":13},{"imageOffset":80622,"symbol":"_dispatch_root_queue_drain_deferred_wlh","symbolLocation":271,"imageIndex":13},{"imageOffset":78845,"symbol":"_dispatch_workloop_worker_thread","symbolLocation":451,"imageIndex":13},{"imageOffset":11335,"symbol":"_pthread_wqthread","symbolLocation":327,"imageIndex":9},{"imageOffset":7063,"symbol":"start_wqthread","symbolLocation":15,"imageIndex":9}]},{"id":3072015,"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":13068335072},"r12":{"value":0},"rosetta":{"tmp2":{"value":140705984557128},"tmp1":{"value":140703558153626},"tmp0":{"value":140706057774492}},"rbx":{"value":0},"r8":{"value":0},"r15":{"value":0},"r10":{"value":2},"rdx":{"value":0},"rdi":{"value":140646924587696},"r9":{"value":140646924592944},"r13":{"value":272},"rflags":{"value":582},"rax":{"value":2303},"rsp":{"value":13068335072},"r11":{"value":27021597764222976},"rcx":{"value":18446744071427850239},"r14":{"value":4571811264},"rsi":{"value":140703615374451,"symbolLocation":0,"symbol":"__IONotificationPortSetDispatchQueue_block_invoke"}},"queue":"com.Metal.DeviceDispatch","frames":[{"imageOffset":21623,"symbol":"__IONotificationPortSetDispatchQueue_block_invoke","symbolLocation":4,"imageIndex":14},{"imageOffset":13722,"symbol":"_dispatch_client_callout","symbolLocation":8,"imageIndex":13},{"imageOffset":24775,"symbol":"_dispatch_continuation_pop","symbolLocation":523,"imageIndex":13},{"imageOffset":91896,"symbol":"_dispatch_source_invoke","symbolLocation":2076,"imageIndex":13},{"imageOffset":38075,"symbol":"_dispatch_lane_serial_drain","symbolLocation":387,"imageIndex":13},{"imageOffset":41216,"symbol":"_dispatch_lane_invoke","symbolLocation":377,"imageIndex":13},{"imageOffset":80622,"symbol":"_dispatch_root_queue_drain_deferred_wlh","symbolLocation":271,"imageIndex":13},{"imageOffset":78845,"symbol":"_dispatch_workloop_worker_thread","symbolLocation":451,"imageIndex":13},{"imageOffset":11335,"symbol":"_pthread_wqthread","symbolLocation":327,"imageIndex":9},{"imageOffset":7063,"symbol":"start_wqthread","symbolLocation":15,"imageIndex":9}]},{"id":3072468,"frames":[{"imageOffset":141644,"imageIndex":2}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":18446744073709551615},"r12":{"value":0},"rosetta":{"tmp2":{"value":0},"tmp1":{"value":0},"tmp0":{"value":0}},"rbx":{"value":0},"r8":{"value":0},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":13069406208},"rdi":{"value":0},"r9":{"value":0},"r13":{"value":0},"rflags":{"value":531},"rax":{"value":13069942784},"rsp":{"value":409604},"r11":{"value":0},"rcx":{"value":94087},"r14":{"value":0},"rsi":{"value":0}}}],
    "usedImages" : [
    "source" : "P",
    "arch" : "x86_64",
    "base" : 8651489280,
    "size" : 655360,
    "uuid" : "ab17bf63-259b-3b48-8d70-863166a2191c",
    "name" : "dyld"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 4518862848,
    "size" : 65536,
    "uuid" : "c35523ac-5fc8-3185-b4fb-28be5af3f218",
    "source" : "P",
    "arch" : "arm64",
    "base" : 140703127126016,
    "size" : 196608,
    "uuid" : "c4c97159-5c72-3e75-ba2d-d6ca98ea626f",
    "path" : "\/usr\/libexec\/rosetta\/runtime",
    "name" : "runtime"
    "source" : "P",
    "arch" : "arm64",
    "base" : 4510502912,
    "size" : 344064,
    "uuid" : "7af8ba1e-5c4d-393d-99cd-92566f60c450",
    "path" : "\/Library\/Apple\/*\/libRosettaRuntime",
    "name" : "libRosettaRuntime"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 4332998656,
    "CFBundleShortVersionString" : "6.4.2",
    "size" : 16564224,
    "uuid" : "8b447e7e-4cdb-3243-926d-9048585fcb2c",
    "CFBundleVersion" : "6.4.2"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703616561152,
    "size" : 21024764,
    "uuid" : "20292f0b-3eb2-3566-91e2-ea657457d71d",
    "name" : "AppKit",
    "CFBundleVersion" : "2487.30.108"
    "size" : 0,
    "source" : "A",
    "base" : 0,
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703559622656,
    "size" : 241656,
    "uuid" : "9927a0a9-dfa8-3ffa-88d8-62055f37a137",
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703560282112,
    "size" : 4825085,
    "uuid" : "fd59424c-be72-3201-b98c-0421b284ffbb",
    "CFBundleVersion" : "2202"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703559864320,
    "size" : 49152,
    "uuid" : "a9ba8a53-d774-3fe9-8bde-64187bff7ea9",
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703558443008,
    "size" : 557056,
    "uuid" : "29a0020e-3766-39df-80fe-9aa731847daa",
    "path" : "\/usr\/lib\/system\/libsystem_c.dylib",
    "name" : "libsystem_c.dylib"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703559000064,
    "size" : 520192,
    "uuid" : "c4311955-de8c-341a-bf4e-46f9a9b26d7a",
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140707857170432,
    "CFBundleShortVersionString" : "93.10.1",
    "CFBundleIdentifier" : "com.apple.IOGPU",
    "size" : 229362,
    "uuid" : "34e8d18c-7efd-3f68-a802-4f73a4382deb",
    "path" : "\/System\/Library\/PrivateFrameworks\/IOGPU.framework\/Versions\/A\/IOGPU",
    "name" : "IOGPU",
    "CFBundleVersion" : "93.10.1"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703558139904,
    "size" : 290814,
    "uuid" : "895cad19-704c-3ff8-b148-23689a163b12",
    "path" : "\/usr\/lib\/system\/libdispatch.dylib",
    "name" : "libdispatch.dylib"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703615352832,
    "CFBundleShortVersionString" : "2.0.2",
    "CFBundleIdentifier" : "com.apple.framework.IOKit",
    "size" : 798712,
    "uuid" : "d556ec12-074c-30d8-958e-7b88c4b1178c",
    "path" : "\/System\/Library\/Frameworks\/IOKit.framework\/Versions\/A\/IOKit",
    "name" : "IOKit"
    "sharedCache" : {
    "base" : 140703555452928,
    "size" : 21474836480,
    "uuid" : "aa32606f-3f8a-36dc-89ab-9c1bd7bf3104"
    "vmSummary" : "ReadOnly portion of Libraries: Total=794.9M resident=0K(0%) swapped_out_or_unallocated=794.9M(100%)\nWritable regions: Total=1.4G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.4G(100%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced) \n=========== ======= ======= \nAccelerate framework 256K 2 \nActivity Tracing 256K 1 \nCG image 3220K 40 \nCG raster data 2232K 2 \nColorSync 252K 33 \nCoreAnimation 4804K 50 \nCoreGraphics 12K 2 \nCoreUI image data 2932K 22 \nDispatch continuations 64.0M 1 \nFoundation 40K 2 \nKernel Alloc Once 8K 1 \nMALLOC 1.1G 63 \nMALLOC guard page 192K 12 \nRosetta Arena 4096K 2 \nRosetta Generic 1792K 445 \nRosetta IndirectBranch 1024K 1 \nRosetta JIT 128.0M 1 \nRosetta Return Stack 600K 60 \nRosetta Thread Context 600K 60 \nSTACK GUARD 12K 3 \nStack 22.8M 33 \nStack Guard 56.1M 27 \nVM_ALLOCATE 4804K 14 \nVM_ALLOCATE (reserved) 4K 1 reserved VM address space (unallocated)\n__CTF 824 1 \n__DATA 32.5M 539 \n__DATA_CONST 36.6M 341 \n__DATA_DIRTY 1523K 177 \n__FONT_DATA 2352 1 \n__INFO_FILTER 8 1 \n__LINKEDIT 144.3M 10 \n__OBJC_RO 71.1M 1 \n__OBJC_RW 2166K 3 \n__TEXT 650.6M 559 \ndyld private memory 260K 2 \nmapped file 7.2G 875 \nshared memory 816K 17 \nunshared pmap 14.6M 10 \n=========== ======= ======= \nTOTAL 9.5G 3415 \nTOTAL, minus reserved VM space 9.5G 3415 \n",
    "legacyInfo" : {
    "name" : "ant_main"
    "logWritingSignature" : "75a8bc31b7797c73a86dc45590344b4796589e47",
    "trialInfo" : {
    "rollouts" : [
    "rolloutId" : "632e3df958740028737bffc0",
    "factorPackIds" : {
    "SIRI_UNDERSTANDING_NL_OVERRIDES" : "65cf6c2ef4f548412aec5f91"
    "deploymentId" : 240000642
    "rolloutId" : "645c2d2f9e69a025b0a37e29",
    "factorPackIds" : {
    "deploymentId" : 240000003
    "experiments" : [
    "reportNotes" : [
    "PC register does not match crashing frame (0x0 vs 0x7FF8AA0CAA78)"
    Model: MacBookAir10,1, BootROM 10151.61.4, proc 8:4:4 processors, 8 GB, SMC
    Graphics: Apple M1, Apple M1, Built-In
    Display: Color LCD, 2560 x 1600 Retina, Main, MirrorOff, Online
    Memory Module: LPDDR4, Hynix
    AirPort: spairport_wireless_card_type_wifi (0x14E4, 0x4378), wl0: Aug 26 2023 17:55:53 version 18.20.439.0.7.8.163 FWID 01-f9b9247b
    AirPort:
  •   I'm getting this error from time to time when it crashes.
