Acknowledged
CIQQA-3853
CIQ SDK 8.4.x (Windows): run and install silently fail for Data Field projects (Edge 540)
Summary
On Windows, with Connect IQ SDK 8.4.1, Data Field projects build successfully but cannot be run in the CIQ Simulator or installed on an Edge 540. Both run and install commands fail silently (no error output), and the simulator opens only in idle shell mode with no device window.
Environment
  • OS: Windows (10/11)
  • SDK: Connect IQ SDK 8.4.1 (Windows)
  • Device: Edge 540
  • App type: Data Field
Project status
  • Project structure is valid (manifest.xml, source/*.mc)
  • manifest.xml:
    • type="datafield"
    • correct entry
    • product edge540
  • Entry class exists and matches manifest entry
  • current-sdk.cfg correctly points to SDK 8.4.1
  • connectiq.bat build succeeds with no warnings/errors
Steps to reproduce
  1. Create or open a valid Data Field project for Edge 540.
  2. Run connectiq.bat build → succeeds.
  3. Run any of the following:
    • connectiq.bat run
    • connectiq.bat run -d edge540 -t datafield -p .
    • connectiq.bat install -d edge540
  4. CIQ Simulator opens but remains idle (no device window).
    No CLI errors or output are produced.
Expected result
  • Simulator launches an Edge 540 device window running the data field, or
  • install reports successful installation to the device.
Actual result
  • Silent failure: no device window, no installation, no error output.
Notes
This appears to be a regression or tooling issue in SDK 8.4.x on Windows. The same project configuration is valid and builds correctly, but cannot be executed or installed.
Parents
  • It's not clear what and why you do the way you do.
    Does whatever you're trying in SDK 8.4.1 work in any previous version?
    Why do you try it from cli? Try one of the SDK samples and use VSCode. Once you succeed from there move to cli (if you really have a reason to do so, besides the AI telling you) Then start to modify the sample code and add your features.
Comment
Children
No Data
