Summary
On Windows, with Connect IQ SDK 8.4.1, Data Field projects build successfully but cannot be run in the CIQ Simulator or installed on an Edge 540. Both run and install commands fail silently (no error output), and the simulator opens only in idle shell mode with no device window.
Environment
OS: Windows (10/11)
SDK: Connect IQ SDK 8.4.1 (Windows)
Device: Edge 540
App type: Data Field
Project status
Project structure is valid (
manifest.xml,source/*.mc) -
manifest.xml:-
type="datafield" -
correct
entry -
product
edge540
Entry class exists and matches manifest entry
current-sdk.cfgcorrectly points to SDK 8.4.1 -
connectiq.bat buildsucceeds with no warnings/errors
Steps to reproduce
Create or open a valid Data Field project for Edge 540.
Run
connectiq.bat build→ succeeds. -
Run any of the following:
connectiq.bat run -
connectiq.bat run -d edge540 -t datafield -p . -
connectiq.bat install -d edge540
CIQ Simulator opens but remains idle (no device window).
No CLI errors or output are produced.
Expected result
Simulator launches an Edge 540 device window running the data field, or
installreports successful installation to the device.
Actual result
Silent failure: no device window, no installation, no error output.
Notes
This appears to be a regression or tooling issue in SDK 8.4.x on Windows. The same project configuration is valid and builds correctly, but cannot be executed or installed.
