WatchFace Black with arcs
https://apps.garmin.com/en-US/apps/bf8d8ef4-cd54-4d29-901f-457491ba3703
Black background, red minutes, 12/24H mode.
Displays :
- batterie percent and a progress bar in red on top
- steps, step goal and a progress bar in white on bottom
- bluetooth status
- sleep mode status
- distance
- calories
Doesn't displays seconds because with the low power mode I prefer not.
V 1.3
- Change arc drawing method : uses https://forums.garmin.com/showthread.php?231881-Arc-Function
- Change design (due to arc drawing) to improve performance : no more menus lags and less battery drain
V 1.4
- Back to old design due to bad graphic behavior in 24H mode after 20H
- Change (again) arc drawing method and merge some bitmaps to optimize more the performance
- 2 digits for hour in 12H mode
V 1.5
- 1 digit for hour in 12H mode (convention)
V 1.6
- Forgot to remove some debug informations ...
V 1.7
- Handles Miles/KM display
V 1.8
- Compiled with new 1.1.2 SDK
V 1.9
- The top arc now displays the move level : empty, ok, full, you have to move !
