- a readable time font
- sun events
- active statistics (heart rate / steps / stairs)
- YAHOO! weather & forecasts.
I have Venu 2, and am wondering if anyone else can see HR Line chart, if you set it for the bottom chart? It just shows a blank chart for me. If I choose e.g. Pressure line chart, it shows.
In Garmin Conenct Mobile (Android) you can select the apps that may send the messages to the watch.
yeah the fenix doesn't like the yellow I assign to it apparently, in the next version the color for the day will be customizable.
When do you think you’ll have an updated version for the Fenix 5X? I am experiencing the same color issue with my watch not showing a color for the daytime.
I reinstalled this e watch face and the yellow color for daytime worked fine for the default Brussels location. It stopped working when I got a GPS fix for my location (USA, West Coast).
There is a little yellow but it is very small. Could the watch face be miscalculating am vs pm? It looks like the yellow stops at 8am even though sunset today is 8pm.
Understand your weather app might be using a slightly different location for sunrise/sunset, such as the town center or nearest airport vs you, a bit away from that. Also, as you are just seeing minutes, the actual difference could actually be seconds with rounding and all. Also, the difference for the same location, based on where you are, etc, could be less than a min/day. I'd say, give it a couple days
going forward on timothy's reply the choice of color does not seem to be the issue.
could you provide me with a fit file of a short walk in your region (use download original in garmin connect, you can pm the file to me)? maybe i can spot something then.
