gimporter/gexporter - import FIT/GPX courses from your Android phone
This is the support thread of "gimporter" and the android companion app "gexporter".
Imagine you are on the go and want to upload a course to your Garmin device to follow the track. As of now, this involves uploading the gpx file to the Garmin web site, somehow create a course from it and then select "Export to device" in the mobile app.
Here comes gimporter. Download your FIT and GPX courses with the "gimporter" ConnectIQ app from the "Download" folder of your Android device.
Notes:
  • Keep the Android app open, while downloading!
  • Oregon and Rino devices download the unmodified GPX track. No point reduction or speed recalculation is done yet
  • On some devices (like the Edge 1030) you have to disable WiFi while using the app
ConnectIQ App: https://apps.garmin.com/en-US/apps/de11adc4-fdbb-40b5-86ac-7f93b47ea5bb
ConnectIQ Widget: https://apps.garmin.com/en-US/apps/fac50ef3-77b2-466c-9f4f-4dcb2feb49a3
Android App: https://play.google.com/store/apps/details?id=org.surfsite.gexporter
Source code: https://github.com/gimportexportdevs
  • Thanks, looking forward to the new version!
    Android app version 7
  • Ah yes, the gpx I used had no speed to forcing wasn't necessary.
    Too bad about the start/end shifting, amazingly I have yet to find an easy solution for that. One that works is to cut and then paste with mygpsfiles.
    How about editing the GPX track in Locus Map? With the new gexporter feature, that it can receive shared files, it should be quick and easy.
  • Android app version 7
    That was fast, got it and working, thanks !
  • Should be fixed with V5.1
    Tnx it works fine now.
  • Hi I've just updated to V5 on my E1000. The courses certainly load quicker. Good work. The course point limit on the E1000 appears to be somewhere in the region of 35922
    I don't know if it was intentional, but course names are now truncated to 15 Characters, where the E1000 can have considerably more, 49 in fact. Although the number of characters displayed varies depending on the screen being viewed.
    20 on the course list screen
    29 on the selected course menu screen
    26 on the selected course settings screen
    49 on the course name editor
    Fixed with V5.2 (needs Android app version 5.1)
    Hi Thanks for restoring the long file names.
    A couple of things to report on the E1000 with V5.2
    1. The start button no longer loads the track list, but the menu button works fine.
    2. The text on the track list seems to be misaligned vertically compared to the buttons. Hopefully it's noticeable in the screen capture below
    https://drive.google.com/file/d/0BxFGncAUrXvRX1JTR3NEWHY5blE/view?usp=drivesdk
    Thanks HD
  • Hi Thanks for restoring the long file names.
    But you can touch it now to start :-)
    Thanks HD
    This is nothing I can fix. It's the standard Garmin ConnectIQ Menu, which is to blame.
    You can file a bug at https://forums.garmin.com/forumdisplay.php?623-Connect-IQ-Bug-Reports for this.
  • Hi Thanks for the feedback.
    Yep the menu icon is fine for loading the tracklist. When I saw the Press Start/Menu prompt I thought either would work so I pressed the start button, which worked on the previous version. When that didn't work I tried the menu icon which worked fine. I guess this is something you've implemented to support different devices.
    I'll raise a bug request for the menu issue and let you know of the outcome.
    Keep up the good work. HD
    I don't see the strange menu behavior on my edge 1000. Does the filename begin with some invisible/unprintable characters?
  • Widget was just approved in the connectiq store. Might take some hours to appear.
