Data Field: Peter's (Race) Pacer
This is the support Thread for the Data Field Peter's (Race) Pacer.
Setup Guide with pictures: http://starttorun.info/peters-race-pacer/
Download
https://apps.garmin.com/en-US/apps/23ea0301-30c6-4c33-b4ef-63e2b5394e76
Summary
Peter's (Race) Pacer resolves 2 issues for me when I'm running a race:
  • Before the race starts I want to see the time of the day (How long till the race starts?)
  • I often pace marathons and it used to be doing mental math all the way, now this is no longer necessary as I can fully depend on the average pace/speed, because this data field allows to correct the distance at the kilometer / mile marker by simply pressing the LAP button
While the data field's primary intent is to race races, you can also use it to run laps around the track, just set the lap distance to 400 meters and press the lap button as you cross the line!...
Intro
In it's full glory this data field uses about 24kb which is too much to run on the older devices. To enable using the data field on older connect IQ devices I've stripped some functionality from these older watches in order to let them operate within the 16kb limit that Connect IQ 1.x allows. (Items marked with (*ciQ2) are only available on the high memory watches (high memory watches are FR735xt, fenix chronos & fenix5 variants))
The data field is fully functional as is, yet donations are encouraged on the watch by a small encouragement text.
Usage
Before starting the race an initial data screen is shown (* cIQ2), this screen shows you the following data
  • Time of the day
  • Current heart rate (+ zone indication)
  • Configured Settings Summary (Change these settings in Garmin Express or in the Garmin Connect Android App)
  • Battery Percentage Remaining
  • Gps Signal Strength Indication
After pressing the START button the race timer will start and a new data screen will be shown, this data screen will show you the following information:
  • top middle configurable field: current heart rate / average pace / average speed / perfect pace / perfect speed (*)
  • row 1 left configurable field: average pace / average speed / current heart rate / perfect pace / perfect speed
  • row 1 middle configurable field: speed, smooth speed (5s average), smooth speed (10s average), pace, smooth pace (5s average), smooth pace (10s average)
  • time ahead / behind
  • race timer
  • (adjusted) distance covered (see adjusting distance explanation below)
  • estimated time of arrival
After Activity in Garmin Connect (*cIQ2)
  • When you opt to record the ahead Time to the FIT track an extra graphic is shown in Garmin Connect
Perfect Pace / Perfect Speed
This field recalculates as you run and gives you the pace you need to run to arrive at the finish with 0 seconds behind / ahead (eg if you run a 10k race and want to arrive in 1 hour (avg pace=6:00min/km), currently you're at the 7k point in 41:30, which means you're 30 seconds ahead, the perfect pace will thus show the value 6:10 (min/km) as you can run the next 3k 10 seconds slower to still get in time at the finish line)
Distance Adjustment
When you press the LAP button the on screen distance is adjusted to the nearest LAP SIZE (eg 5.31k will be adjusted to 5k if the lap size is 1000 meters).
When you press the LAP button by mistake you have 30 seconds to undo the last correction (just press the LAP button again)
When you miss a mile/kilometer marker, don't worry DO NOT PRESS THE LAP button and wait for the next kilometer/mile marker and press the LAP button there.
Adjusting the distance has no influence on the recorded distance (In Garmin Connect when you come back home you will see the real recorded GPS distance, yet of course you will be able to determine based on the lap marker postions where the LAP markings really were)...
Recommendations
  • Train with the data field before you race with it so you're used to the layout!
  • Have a backup second datascreen layout, in case the field crashes you can switch to the native data screen layout
  • If you have a Connect IQ 1.x device consider the application option to enjoy all features of Peter's (Race) Pacer: https://apps.garmin.com/en-US/apps/ea97af1f-1e5d-4541-820c-9bd994080d4
Tested on real FR735XT, all other devices were tested in the simulator.
  • Do I need to programme a projected target time into the app so that it know what pace I need to run at to hit the time I want to achieve?
  • Yes you have to set your target in the settings of the app.
  • Hi! I'd like to use the Perfect Pace feature on a very long endurance event (estimated around 22 hrs). I know that this isn't probably the intended use case, but the course doesn't have distance markers so laps of 1 km would only throw off the recalculation (I'd still like to use manual laps).
    Would it be possible to set the internal lap distance to 1 meter to avoid the recalculation altogether?
    I imagine if the lap distance is set to 1 meter, than the rounding would also round to the nearest 1 meter (or possibly not at all since I'm not sure garmin even records non-whole meters).
    Is this possible, or will it result in an error? The main problem I want to avoid is that if the perfect pace is recalculated every lap, then setting the lap size to 1 meter would drain the battery pretty quick...
    Thanks in advance for any answers :D
    PS: Sorry for any errors in my English as it is not my 1st language.
  • that's indeed not the intended use case. the lap correction is part of the core of Peter's Race Pacer, I don't know how it will react on a 1 meter lap, it could work, but if it doesn't I'm not going to implement a fix for this. You're on your own for this experiment ;). Good luck with your race.
  • Hello!
    The data screen is incredible and Perfect Pace worked even with 1m lap size, even though it isn't supported per say.
    The only thing I experienced was higher battery drain (45 % drained in 11 hrs when it should've been around 20 % based off of the "full battery estimate"), but that could be caused by something else entirely.
    I'm posting this here for appreciation purposes (and so that anybody else trying to use the data screen in this manner can find it). A huge thanks to Peter for his amazing work Smiley
    PS: Sorry for any English errors, as it isn't my 1st language.
  • Don't worry, it's not my primary language either.
    Glad it worked out for your use case.
    The 45% for 11hours sounds quite OK to me, you may be able to finish a 24 hour race before the battery depletes, but just take a powerbank along to be sure (so you can charge on the go or during your rest break)
  • Hello, was wondering if this could be running alongside PacePro, or would they conflict each other?
  • It can work next to pace pro, but you probably better try them both out before your race and see what you like best, so that you'll know on which to primarily depend on during your race
  • Hi Peter,
    I've used your racer pacer forever on my Forerunner 245, but it finally died on me. I'd like to download it to my new Venu 4, which is not yet added. Can you do that?
    I'll gladly buy you a cup of coffee for your efforts again.
    Paul
