Watchface: ActiFace [FR920XT, Vivoactive, epix]
Watchface link: https://apps.garmin.com/en-US/apps/7ef071c3-4a14-4eb3-aca9-e3a531262711
You can donate the ActiFace development via PayPal here: http://bit.ly/1RoLv4i
!!! IMPORTANT - PLEASE, RESTART YOUR WATCHES AFTER WATCHFACE UPDATE IF YOU HAVE SOME CONFIGURATION ISSUES !!!
Watch Face contains:
- Time and date
- activity history graph (past 7 days + today) in kCal and km/mi (or steps)
- maximum or sum or average kCals and km/mi (or steps)
- daily goal progress and step count
- custom fields
- status and notification icons
- inactivity indicator. Removing of inactivity levels is handled by the watch firmware, usually it takes about 3-4 minutes of walking.
- "goal reached" indicator in the week graph (small white triangle)
Supports 12/24 time format and km/mi.
Configuration
ActiFace can be configured via Garmin Connect Mobile or Garmin Express.
Here is how to do it: https://forums.garmin.com/showthread.php?332843-How-to-App-Settings
Possible settings:
- Color
- Date format (and second date format in case when the notification icon is shown on Fenix-like models)
- Inverted mode (white background)
- Graph description - values above the graph - week maximums, sums or averages
- White line - switch between daily steps and distance for the white line graph
- Color graph style - switch between curve graph and bar graph
- Custom fields types (differs between models):
* UTC (with TZ offset)
* UTC24 (with TZ offset, always 24H format)
* steps
* distance
* calories
* goal percentage
* heart rate
* altitude
* week goal percentage (counted all step goals and steps from the beginning of the week)
* week distance average (counted from the beginning of the week without today)
* week steps average (counted from the beginning of the week without today)
* week calories average (counted from the beginning of the week without today)
* sunrise/sunset times
* climbed floors
* climbed meters/feet
* descended meters/feet
* week intensity minutes percentage
- Enable/disable seconds
- Enable/disable inactivity indicator
- Battery indicator type (Fenix3 only)
- Color graph line
  • F3 6.72b & Actiface v3.4
    I recently updated my F3 to ver 6.72beta and while doing that ActiFace was updated to version 3.4. Now Actiface only displays 2 days of activity on the graph and in the totals. Is this a bug or something I've missed? I've power cycled the watch and also un-installed and re-installed ActiFace via GCM. But neither action helped. I am able to configure the graph colors and other users options via GCM with no problem, but nothing I do affects the 2 days of activity.
    ActiFace is the best watchface - bar none - for the Garmin high-end wearables. Please help!
  • Hi, you can check your activity tracker history i Menu > History > Steps. Do you see the whole week, or just these two days in the history?
  • F3 6.72b & ActiFace v3.4
    Step history only shows Today and Yesterday. However, none of my actual activities are missing and weekly/monthly totals look correct. Looks like a 6.72beta bug?
  • Yes, something wrong during update process.
  • Hi,
    Just updated for my fenix3 and sons fr235. Can't say if any changes for fenix3 but fr235 still doesn't show the progress bar unless its the one beside the move bar ? Should be same as the one in Fenix 3?
    Battery percentage is there.
  • Yes, it's the arc next to move bar. I didn't find better place for it because semi-round displays don't have round bottom part like Fenix3.
    need help/info
    Hye there,
    Im using forerunner 235, may i know why is the value for my white line/graph doesnt change as it shows 0.03km since the first time i installed and run with it. Today i tested 4.5km running, but still it shows 0.03km. what does it mean? Really looking forward to any info with regards to that feature.. still learning and trying to understand the features available.
    anyway, its a cool watch face.. keep it up!
  • Hye there,
    Hi,
    can you tell me what distance is in the Menu > History > Steps for today?
    Hi,
    well basically i turn off my step counter. But if i go to menu-history-total-weekly- (it shows 8.52km of running). so i have the impression that, the value of the white line for my graph should show 8.5km instead of 0.03km. am i right?
    here is the picture of my screen:-
  • I'm affraid that there is no step counter but activity tracker and you turned it off. And currently, it's the only way for watchfaces how to get activity data.
