Watchface: ActiFace [FR920XT, Vivoactive, epix]
Watchface link: https://apps.garmin.com/en-US/apps/7ef071c3-4a14-4eb3-aca9-e3a531262711
You can donate the ActiFace development via PayPal here: http://bit.ly/1RoLv4i
!!! IMPORTANT - PLEASE, RESTART YOUR WATCHES AFTER WATCHFACE UPDATE IF YOU HAVE SOME CONFIGURATION ISSUES !!!
Watch Face contains:
- Time and date
- activity history graph (past 7 days + today) in kCal and km/mi (or steps)
- maximum or sum or average kCals and km/mi (or steps)
- daily goal progress and step count
- custom fields
- status and notification icons
- inactivity indicator. Removing of inactivity levels is handled by the watch firmware, usually it takes about 3-4 minutes of walking.
- "goal reached" indicator in the week graph (small white triangle)
Supports 12/24 time format and km/mi.
Configuration
ActiFace can be configured via Garmin Connect Mobile or Garmin Express.
Here is how to do it: https://forums.garmin.com/showthread.php?332843-How-to-App-Settings
Possible settings:
- Color
- Date format (and second date format in case when the notification icon is shown on Fenix-like models)
- Inverted mode (white background)
- Graph description - values above the graph - week maximums, sums or averages
- White line - switch between daily steps and distance for the white line graph
- Color graph style - switch between curve graph and bar graph
- Custom fields types (differs between models):
* UTC (with TZ offset)
* UTC24 (with TZ offset, always 24H format)
* steps
* distance
* calories
* goal percentage
* heart rate
* altitude
* week goal percentage (counted all step goals and steps from the beginning of the week)
* week distance average (counted from the beginning of the week without today)
* week steps average (counted from the beginning of the week without today)
* week calories average (counted from the beginning of the week without today)
* sunrise/sunset times
* climbed floors
* climbed meters/feet
* descended meters/feet
* week intensity minutes percentage
- Enable/disable seconds
- Enable/disable inactivity indicator
- Battery indicator type (Fenix3 only)
- Color graph line
  • After my activity today, going back to watch face it shows digital and not actiface. Only way to get back actiface is to power off and on. This is with the latest 6.63b.
  • Does it happen always after the activity?
    After pressing done, happened twice already. Also when going thru menus but it recovers.
    I first posted about this days ago on this thread. His behavior does not happen woth other faces I have since I want to isolate if it's a beta issue or not. Woth certainty the jan 5 build of actiface (with badges) didn't have this behavior.
  • cant change color on fenix3, cause its crushing! (soft 6.50) must delete all files and reinstall to start in default color. could someone help?
    same issue on epix (firmware v3.10).
    (Win 7 PC, Garmin express v4.1.10.0)
    After several months of not syncing I had zero issues with actiface, used the red face and it ran great. Great app.
    Looks like, though, the most recent update to actiface 3.2.2 (jan 21, 2016) has a bug using anything but the default color (cyan).
    When I attempt to change the face color and sync in Express, the actifiace watch face is active but graphically Im left with the default digital face.
    removing and re-installing actiface will bring back functionality in the default color, However, unable to switch to red or any other color.
    Please advise.
    Thanks
  • same issue on epix (firmware v3.10).
    Please advise.
    Thanks
    Hi, the issue is in your version of Garmin Express. It was pretty buggy version from Connect IQ perspective and I believe that it'll be ok when you update it to the latest.
  • Request : progress meter for steps on fr235
    This feature is on fenix3 but saw it doesn't show in fr235. If possible , pls add feature to fr235 :-)
  • Hi, the issue is in your version of Garmin Express. It was pretty buggy version from Connect IQ and I believe that it'll be ok when you update it to the latest.
    That did the trick. autoupdates for express were on, but I wasnt prompted to upgrade... D`oh!'; Manually downloaded and installed Garmin express 4.1.16.0. Able to swap colors again, etc.
    Thanks!
    about sunrise/sunset
    HI! sunrise/sunset didn't show up(it did showed the icon without time tho) for several days now. my watch is fr235, firmware 3.10, app version 3.3.2, language Traditional Chinese. Please help. Thank you very much.
  • HI! sunrise/sunset didn't show up(it did showed the icon without time tho) for several days now. my watch is fr235, firmware 3.10, app version 3.3.2, language Traditional Chinese. Please help. Thank you very much.
    Hi, when did you fixed GPS for the last time?
    I am not sure what you meant by "fix GPS", but I did 2-3 runs(GPS works fine) during those time while the sunrise/sunset didn't show up. Did you mean when I 'connected my fr 235 to Garmin Express' by USB? Because I just did that and the sunrise/sunset time came back! Then I am a bit confused now as I did connected my fr 235 to Garmin Mobile App by bluetooth. That doesn't count then? @@?
