Watchface: ActiFace [FR920XT, Vivoactive, epix]
Watchface link: https://apps.garmin.com/en-US/apps/7ef071c3-4a14-4eb3-aca9-e3a531262711
You can donate the ActiFace development via PayPal here: http://bit.ly/1RoLv4i
!!! IMPORTANT - PLEASE, RESTART YOUR WATCHES AFTER WATCHFACE UPDATE IF YOU HAVE SOME CONFIGURATION ISSUES !!!
Watch Face contains:
- Time and date
- activity history graph (past 7 days + today) in kCal and km/mi (or steps)
- maximum or sum or average kCals and km/mi (or steps)
- daily goal progress and step count
- custom fields
- status and notification icons
- inactivity indicator. Removing of inactivity levels is handled by the watch firmware, usually it takes about 3-4 minutes of walking.
- "goal reached" indicator in the week graph (small white triangle)
Supports 12/24 time format and km/mi.
Configuration
ActiFace can be configured via Garmin Connect Mobile or Garmin Express.
Here is how to do it: https://forums.garmin.com/showthread.php?332843-How-to-App-Settings
Possible settings:
- Color
- Date format (and second date format in case when the notification icon is shown on Fenix-like models)
- Inverted mode (white background)
- Graph description - values above the graph - week maximums, sums or averages
- White line - switch between daily steps and distance for the white line graph
- Color graph style - switch between curve graph and bar graph
- Custom fields types (differs between models):
* UTC (with TZ offset)
* UTC24 (with TZ offset, always 24H format)
* steps
* distance
* calories
* goal percentage
* heart rate
* altitude
* week goal percentage (counted all step goals and steps from the beginning of the week)
* week distance average (counted from the beginning of the week without today)
* week steps average (counted from the beginning of the week without today)
* week calories average (counted from the beginning of the week without today)
* sunrise/sunset times
* climbed floors
* climbed meters/feet
* descended meters/feet
* week intensity minutes percentage
- Enable/disable seconds
- Enable/disable inactivity indicator
- Battery indicator type (Fenix3 only)
- Color graph line
    I'm affraid that there is no step counter but activity tracker and you turned it off. And currently, it's the only way for watchfaces how to get activity data.
    I see, so the value for the white line will only get its value from step counter. Hurmmm.. maybe this could give u the idea of giving it (white line graph) some flexibility to choose for the value to be based on step counter or total distance from running activity.
    Thank you so much for your assistance.
  • I see, so the value for the white line will only get its value from step counter. Hurmmm.. maybe this could give u the idea of giving it (white line graph) some flexibility to choose for the value to be based on step counter or total distance from running activity.
    Hi, as I said, it gets its value from the activity tracker, not step counter. The activity tracker accounts steps and activities together and provide total daily distance, step count, calories etc. But there is no possibility to account only some activity type.
    got it, i turn on the activity tracker.. now it does show something. thanks again mate. really appreciate it..
  • I updated to 6.8 and the graph on the display is just a line instead of each day having a peak. Also when i hit my step goal, no longer get the triangle for that day.
    It looks like your activity tracker history was somehow corrupted or deleted by firmware update process. I hope that today's and future statistics will be updating correctly.
  • Wrong chart after update.
    Same case for me, only one line not the past days history, I take that after the update the past data is gone ¿Should we wait until a complete 7 days series is stored? right now with two days still going wrong.
  • It looks like your activity tracker history was somehow corrupted or deleted by firmware update process. I hope that today's and future statistics will be updating correctly.
    Pretty sure the same happened to me going from 6.42β to 6.52β (both beta) but didn't going from 6.72β to 6.80 stable - so possibly something changed post 6.50 stable.
    All has been normal since then (line varies per day & the little peaks happen when the target is passed)
    Graph problem
    Hi there,
    I have upgraded to the latest firmware on Fenix3, now on 6.8 with display 3.20. The graph is now a continuous slope. There are no columns or white arrows, any ideas?
    Regards
    Stuart
  • There was a bug in the Fenix's firmware update. It affected all watchfaces and apps which uses activity tracker data. I already reported it to the Garmin.
    Issues
    Had to get rid of my post. Bluetooth and the notification bubbles came back today so all good on that. Activity graph seems to be taking a shape of weekly activity. Now, i only have a lag (white line) when going from setting menu back to actiface home screen. Love this watch face!
