Watchface: ActiFace [FR920XT, Vivoactive, epix]
Watchface link: https://apps.garmin.com/en-US/apps/7ef071c3-4a14-4eb3-aca9-e3a531262711
You can donate the ActiFace development via PayPal here: http://bit.ly/1RoLv4i
!!! IMPORTANT - PLEASE, RESTART YOUR WATCHES AFTER WATCHFACE UPDATE IF YOU HAVE SOME CONFIGURATION ISSUES !!!
Watch Face contains:
- Time and date
- activity history graph (past 7 days + today) in kCal and km/mi (or steps)
- maximum or sum or average kCals and km/mi (or steps)
- daily goal progress and step count
- custom fields
- status and notification icons
- inactivity indicator. Removing of inactivity levels is handled by the watch firmware, usually it takes about 3-4 minutes of walking.
- "goal reached" indicator in the week graph (small white triangle)
Supports 12/24 time format and km/mi.
Configuration
ActiFace can be configured via Garmin Connect Mobile or Garmin Express.
Here is how to do it: https://forums.garmin.com/showthread.php?332843-How-to-App-Settings
Possible settings:
- Color
- Date format (and second date format in case when the notification icon is shown on Fenix-like models)
- Inverted mode (white background)
- Graph description - values above the graph - week maximums, sums or averages
- White line - switch between daily steps and distance for the white line graph
- Color graph style - switch between curve graph and bar graph
- Custom fields types (differs between models):
* UTC (with TZ offset)
* UTC24 (with TZ offset, always 24H format)
* steps
* distance
* calories
* goal percentage
* heart rate
* altitude
* week goal percentage (counted all step goals and steps from the beginning of the week)
* week distance average (counted from the beginning of the week without today)
* week steps average (counted from the beginning of the week without today)
* week calories average (counted from the beginning of the week without today)
* sunrise/sunset times
* climbed floors
* climbed meters/feet
* descended meters/feet
* week intensity minutes percentage
- Enable/disable seconds
- Enable/disable inactivity indicator
- Battery indicator type (Fenix3 only)
- Color graph line
    Former Member over 9 years ago
    Distance Question
    How does the distance gets calculated? Reason being is that yesterday I went on a 50+ miles bike ride. The white line spiked up, but my steps count was low. SHouldn't it just count the steps towards the total distance?
    Thanks!
  • Hi,
    Greate watch face!
    I have issue with the activity history graph, today's distance and total distance. After I reset the watch, the face is start working perfectly, but after a couple of days it shows 0 for the 3 fields. I am using F3 with version 5.10 and actiface 2.0.5, but I am experiencing this issue since firmware 4.20. Is there anything I can do to avoid this issue.
    Hi, what 3 fields are 0? Can you also check your Menu > History > Steps, if you can see correct statistics?
  • Would it be possible to add another option for the graph (white line) to show activity time (duration) in addition to steps and distance?
    //Sjur
    Hi, I'm affraid watchfaces don't have this information available.
  • How does the distance gets calculated? Reason being is that yesterday I went on a 50+ miles bike ride. The white line spiked up, but my steps count was low. SHouldn't it just count the steps towards the total distance?
    Thanks!
    Hi, distance is not calculated, it is just retrieved from the watch's daily statistics and it also includes bike ride distances. Currently I don't have any possibility to to get it aggregated by activity types.
    Yes the statistics are correct. By 3 fields I meen "activity history graph, today's distance and total distance". The graph is configured to show the maximums.
    I am going to reset it again and will start to monitor all the data in the watch for the activity and will report back when it stop working again.
  • Feature request - Reading cycling data from Garmin connect uploaded via Garmin edge
    The watch face is great and has a lot of information. I've used the bike app on the Vivoactive, so the watch face app logs the distance, however it would be good if it could also track data from my Garmin edge 510 once uploaded to Garmin Connect. The Garmin edge synchronises with the Garmin Connect App, however no data is logged back to the vivoactive watch. Would this sort of integration be possible?
    thanks
    Glen
  • Hi Glen,
    Sorry, but Connect IQ watchfaces don't have this possibilities.
  • Seconds
    Request the ability to turn on display of seconds.
    Any possibility of having (on the vivoactive) one colour for the graph and a different colour for the circle around the steps? Would add a bit more colour to the face.
    Otherwise it's the best watch face going, thank you!
    James.
    Software release 6.5
    Hi,
    since software update version 6.5 the Actiface 2.0.6 is not working.
