Watchface: ActiFace [FR920XT, Vivoactive, epix]
Watchface link: https://apps.garmin.com/en-US/apps/7ef071c3-4a14-4eb3-aca9-e3a531262711
You can donate the ActiFace development via PayPal here: http://bit.ly/1RoLv4i
!!! IMPORTANT - PLEASE, RESTART YOUR WATCHES AFTER WATCHFACE UPDATE IF YOU HAVE SOME CONFIGURATION ISSUES !!!
Watch Face contains:
- Time and date
- activity history graph (past 7 days + today) in kCal and km/mi (or steps)
- maximum or sum or average kCals and km/mi (or steps)
- daily goal progress and step count
- custom fields
- status and notification icons
- inactivity indicator. Removing of inactivity levels is handled by the watch firmware, usually it takes about 3-4 minutes of walking.
- "goal reached" indicator in the week graph (small white triangle)
Supports 12/24 time format and km/mi.
Configuration
ActiFace can be configured via Garmin Connect Mobile or Garmin Express.
Here is how to do it: https://forums.garmin.com/showthread.php?332843-How-to-App-Settings
Possible settings:
- Color
- Date format (and second date format in case when the notification icon is shown on Fenix-like models)
- Inverted mode (white background)
- Graph description - values above the graph - week maximums, sums or averages
- White line - switch between daily steps and distance for the white line graph
- Color graph style - switch between curve graph and bar graph
- Custom fields types (differs between models):
* UTC (with TZ offset)
* UTC24 (with TZ offset, always 24H format)
* steps
* distance
* calories
* goal percentage
* heart rate
* altitude
* week goal percentage (counted all step goals and steps from the beginning of the week)
* week distance average (counted from the beginning of the week without today)
* week steps average (counted from the beginning of the week without today)
* week calories average (counted from the beginning of the week without today)
* sunrise/sunset times
* climbed floors
* climbed meters/feet
* descended meters/feet
* week intensity minutes percentage
- Enable/disable seconds
- Enable/disable inactivity indicator
- Battery indicator type (Fenix3 only)
- Color graph line
  • Hi,
    since software update version 6.5 the Actiface 2.0.6 is not working.
    Assuming you have a fenix3, what do you mean "is not working"?
    Works fine here through all beta versions and the current public 6.50
  • My Fenix also has fw 6.50 and ActiFace 2.0.6 works fine for me. Can you try uninstall it and install again? :) Thanks
    Former Member over 9 years ago
    Good morning Petr, in Actiface Steps app, is it possible to show the daily step count but exclude steps that were counted during running/cycling activities in those apps? Looking for a way to only show steps counted while doing daily activity tracker.
    EDIT: would also be good to have on the actiface one too if possible as an option
    Thanks
    Doesn't work after updating to firmware 6.5 for me either :-(
    I see a "9:" on a black screen -- that's it.
    Uninstalled and reinstalled but still behaves the same.
  • I see a "9:" on a black screen -- that's it.
    Can you provide more info? Which watch model do you have, firmware version, and if the issue started after update or..? Thanks
    Problem after upgrade to FW 6.5
    I have the Fenix 3.
    The problem definitely occurred after the upgrade this morning to firmware version 6.5. It was worked well before the update.
    I uninstalled it and went with another watchface for now (since displaying only the hour wasn't particularly useful :-D ), but I can reinstall and send you a picture if you like.
    I have the Fenix 3.
    I had the same problem today on my fenix 3. Only showed a 3 (for the hours) and the rest of the screen was blank. I checked for updates for Garmin Express, and was told that there was one. Once I updated Garmin Express, configured ActiFace, and re-synced the watch, the face functioned normally again.
    Hope that helps!
    -Dave
    Hope that helps!
    -Dave
    That worked! :-)
    Thanks for the suggestion. Should have checked for an update to Garmin Express, but wouldn't have thought that would cause a problem on the watch either.
    Unable to download App
    I'm new to the Garmin ConnectIQ store but trying to download this app and I keep getting a message to update to latest version of my 920XT but I am already at the latest version as confirmed by Garmin Connect and Garmin Express. Not sure if I am doing something wrong but I have the 920xt plugged into the computer and updated it fine with Garmin Express yet continue to get the error. Tried the same download on Garmin Connect on my iphone and got the same error.
    App won't install
    Found when i disconnected the Forerunner from the computer, a screen popped up to install 6.2. Lesson learned that apparently Garmin Connect only downloads the update to the watch and then you have to disconnect and run the update from the watch? I assume I missed something somewhere that would have told me that it how it behaves. Anyway, once installed on the watch, I assume that will fix the problem with the app not installing.
