Watchface: ActiFace [FR920XT, Vivoactive, epix]
Watchface link: https://apps.garmin.com/en-US/apps/7ef071c3-4a14-4eb3-aca9-e3a531262711
You can donate the ActiFace development via PayPal here: http://bit.ly/1RoLv4i
!!! IMPORTANT - PLEASE, RESTART YOUR WATCHES AFTER WATCHFACE UPDATE IF YOU HAVE SOME CONFIGURATION ISSUES !!!
Watch Face contains:
- Time and date
- activity history graph (past 7 days + today) in kCal and km/mi (or steps)
- maximum or sum or average kCals and km/mi (or steps)
- daily goal progress and step count
- custom fields
- status and notification icons
- inactivity indicator. Removing of inactivity levels is handled by the watch firmware, usually it takes about 3-4 minutes of walking.
- "goal reached" indicator in the week graph (small white triangle)
Supports 12/24 time format and km/mi.
Configuration
ActiFace can be configured via Garmin Connect Mobile or Garmin Express.
Here is how to do it: https://forums.garmin.com/showthread.php?332843-How-to-App-Settings
Possible settings:
- Color
- Date format (and second date format in case when the notification icon is shown on Fenix-like models)
- Inverted mode (white background)
- Graph description - values above the graph - week maximums, sums or averages
- White line - switch between daily steps and distance for the white line graph
- Color graph style - switch between curve graph and bar graph
- Custom fields types (differs between models):
* UTC (with TZ offset)
* UTC24 (with TZ offset, always 24H format)
* steps
* distance
* calories
* goal percentage
* heart rate
* altitude
* week goal percentage (counted all step goals and steps from the beginning of the week)
* week distance average (counted from the beginning of the week without today)
* week steps average (counted from the beginning of the week without today)
* week calories average (counted from the beginning of the week without today)
* sunrise/sunset times
* climbed floors
* climbed meters/feet
* descended meters/feet
* week intensity minutes percentage
- Enable/disable seconds
- Enable/disable inactivity indicator
- Battery indicator type (Fenix3 only)
- Color graph line
  • It would be nice to move Time Numbers to the right.
    The numbers on the dial closes the sleeve.
    It is better to swap them.
    Every time I have to reach for the sleeve to see the time.
    It depends. If you wear the watch in the right hand, then is OK.
    Well, but face is configurable - so it'll be great to add this option in configuration (left-right hand) + move digits to the right\left
  • With notifications off, the notification icon still shows up when paired with my phone. Anyway to get the notifications to stop showing when they are off on the watch? This is on the fenix 3
    battery percentage...
    Im a new user to the Fenix 3 and I love this watch face.
    Question;
    I see that the battery percentage shows from time to time...
    Is there a way to have this show all the time instead of the battery bar?
    Great work!
    Cheers, Cory
    Hi, I'll check it. Can you tell which phone do you have and which firmware on your F3? Can you also check if you have cleared your notification stack on the phone (i.e. pull down bar on iPhone). ActiFace just shows what the Garmin Connect Mobile is sending and it disappears if you're ot of the BT range.
  • Im a new user to the Fenix 3 and I love this watch face.
    Question;
    Great work!
    Cheers, Cory
    Hi, thank you. The battery percentage is shown when you turn wrist against your face. Currently, there is no possibility to make the percentage visible all time in ActiFace.
  • Hi, I'll check it. Can you tell which phone do you have and which firmware on your F3? Can you also check if you have cleared your notification stack on the phone (i.e. pull down bar on iPhone). ActiFace just shows what the Garmin Connect Mobile is sending and it disappears if you're ot of the BT range.
    I have a samsung s6 and software is 5.1. It does clear if I clear my notifications, just wasn't expecting to see it since I have my notifications turned off.
  • Great job on the app! This is my favorite watch face.
    A change I would like would be to have the steps goal displayed in numbers. It would be nice to be able to choose "daily steps goal" as an option when setting the graph description as either maximums, averages or totals.
    F3 issue with graph
    Hi,
    Greate watch face!
    I have issue with the activity history graph, today's distance and total distance. After I reset the watch, the face is start working perfectly, but after a couple of days it shows 0 for the 3 fields. I am using F3 with version 5.10 and actiface 2.0.5, but I am experiencing this issue since firmware 4.20. Is there anything I can do to avoid this issue.
    Best watchface - more options for graph
    Would it be possible to add another option for the graph (white line) to show activity time (duration) in addition to steps and distance?
    //Sjur
