Watchface: ActiFace [FR920XT, Vivoactive, epix]
Watchface link: https://apps.garmin.com/en-US/apps/7ef071c3-4a14-4eb3-aca9-e3a531262711
You can donate the ActiFace development via PayPal here: http://bit.ly/1RoLv4i
!!! IMPORTANT - PLEASE, RESTART YOUR WATCHES AFTER WATCHFACE UPDATE IF YOU HAVE SOME CONFIGURATION ISSUES !!!
Watch Face contains:
- Time and date
- activity history graph (past 7 days + today) in kCal and km/mi (or steps)
- maximum or sum or average kCals and km/mi (or steps)
- daily goal progress and step count
- custom fields
- status and notification icons
- inactivity indicator. Removing of inactivity levels is handled by the watch firmware, usually it takes about 3-4 minutes of walking.
- "goal reached" indicator in the week graph (small white triangle)
Supports 12/24 time format and km/mi.
Configuration
ActiFace can be configured via Garmin Connect Mobile or Garmin Express.
Here is how to do it: https://forums.garmin.com/showthread.php?332843-How-to-App-Settings
Possible settings:
- Color
- Date format (and second date format in case when the notification icon is shown on Fenix-like models)
- Inverted mode (white background)
- Graph description - values above the graph - week maximums, sums or averages
- White line - switch between daily steps and distance for the white line graph
- Color graph style - switch between curve graph and bar graph
- Custom fields types (differs between models):
* UTC (with TZ offset)
* UTC24 (with TZ offset, always 24H format)
* steps
* distance
* calories
* goal percentage
* heart rate
* altitude
* week goal percentage (counted all step goals and steps from the beginning of the week)
* week distance average (counted from the beginning of the week without today)
* week steps average (counted from the beginning of the week without today)
* week calories average (counted from the beginning of the week without today)
* sunrise/sunset times
* climbed floors
* climbed meters/feet
* descended meters/feet
* week intensity minutes percentage
- Enable/disable seconds
- Enable/disable inactivity indicator
- Battery indicator type (Fenix3 only)
- Color graph line
    Activty history graph not updating
    Great watch face. Only issue I'm having is the activity history graph is not updating since I first installed. Am I doing something wrong? Is there a setting I need to change?
    Thanks.
  • Great watch face. Only issue I'm having is the activity history graph is not updating since I first installed. Am I doing something wrong? Is there a setting I need to change?
    Thanks.
    Hi,
    first, the activity tracking must be enabled (Settings/Activity tracking), but I suppose you have it enabled.
    I registered few cases when activity tracker has stuck, but ActiFace cannot do anything with it, it only reads history records. There're 2 points which can help. 1. reset of the activity tracker Menu>History>Options>Reset totals.. or 2. watches factory reset.
    P.
    Activity graph
    Hi, does the activity graph still update/work if I'm only using the watch as a step counter? I don't have any activities saved in my history folder. Not sure how to do this. Thanks.
  • Yes, it works just with a step counter. You don't need to have any activity (I mean sport activity).
  • The Connect IQ 1.2 will be available in late September and you are right, it'll require the new firmware version, as well as new version of Garmin Connect Mobile and Garmin Express.
    Hi, it's already mid OCT and I haven't seen any FW update so far for the watches - except for GPS and minor improvements.
    When will it be released?
    Any new clues?
    best regards
    Vivosmartie
  • The Connect IQ 1.2 is already available as beta version, so developers now has some period of time to improve theirs apps for the final release. There are already beta firmwares for devices supporting CIQ 1.2 and I can bet that final release is around the corner.
    It's nice Face for Fenix 3
    Thanks for Great work!
    I think, It's better to use visual explanation of your Face like this
    in this case it is easy to understand and users don't identify and find symbols. :-)
    I hope this visual explanation will speed up your Face popularity!
  • Great idea, I'll prepare something like that for 2.0 release. In the beginning I was trying to make this watchface as intuitive as the screen size allow. But during time it evolved to much more complex watchface than I expected, so you are right - graphical explanation is necessary now. thanks
    TRouble
    When I downloaded this watch face it worked well. After some time I changed to another face and when I tried to come back it didnt function anymore. What shall I do?
  • What device? Have you tried to remove it in Garmin Express and then add it again?
