Application - Drop Fenix
Now on the Fenix .. Drop Fenix. Measure your Heart Rate Recovery(HRR) for 1 and 2 minute time frames as well as 20 seconds increments.
Get it here .. https://apps.garmin.com/en-US/apps/f...2-7ec2f425cd6e
If your heart is important to you .. time to test it. Time for DROP FENIX.
**** FULL CHANGE LOG ****
[Version 1.03] February 17 / 2017
- Added support for Fenix 5S
[Initial Version 1.02] December 28 / 2016
- Measures heart rate recovery for 1 and 2 minute times including 20 second increments.
- Shows heart rate compared to starting heart rate value as you are measuring ( + / - )
- Summary screen with resulting 1/2 minute data displayed, including 20 second increments.
- Easy to understand layout and user interface.
- Status bar to help you wait for those 2 minutes.
- Support for OHR, though Ant+ HR straps recommended for best results.
- Data logging available upon exit if configured as below.
Thank you
VivoactiveHRGuy
    Former Member over 8 years ago
    Data configuraton details ..
    To do data logging with Drop Fenix you need to do the following .. - Connect your Fenix to your computer via your USB charging cable.
    - Navigate to the Garmin\Apps\Logs folder
    - Create a text file named the same as your Drop Fenix program file. See details below.
    - Exit .. and enjoy.
    - Your Drop Fenix data will now be logged upon exiting Drop Fenix to that file.
    Note .. the data is in the following format (CSV format):
    2016/12/28 2:22 PM,173,154,143,135,129,120
    The data is as follows ..
    Date Time, Starting Heart Rate Value, 20, 40, 60, 80, 100 and 120 seconds heart rate values.
    If there is no heart rate data captured .. it will show as zero, ie if the program exited early.
    You can use a program like Excel (or any of your choosing) to analyze or manipulate your data should you desire.
    Note .. DO NOT delete that file, as the Fenix will not recreate it, but will skip the data logging if it is not there. You should not have to recreate it if the Drop Fenix version changes as the program name should remain the same.
    Re the Drop Fenix file .. when you connect to your Fenix, it may look like this. The photo below is the Garmin\Apps folder. Note the NAME of the Drop Fenix prg file as you will need this for your data logging.
    Note ... this is a screen shot from the Vivoactive HR version of Drop as I do not own a Fenix so your folder contents may be a bit different. The concept is identical.
    You need to name the text file the same as the PRG file for DROP FENIX. The best way to tell which one it is, probably by the date / time of your DROP FENIX install.
    So for the above .. you would need to name your data logging text file as 6ASI1701.txt
    This text file goes into the GARMIN\APPS\LOGS folder
    The steps we go through for our data. :)
    Enjoy
    Former Member over 7 years ago
    New Drop Fenix version released today ..
    Just fixed a bug on the Drop Fenix application where it would crash when you started it. It was my fault and I do apologize. As I do not own a Fenix .. it is tough for me to know about these things.
    It was as a result I imagine a recent new Garmin firmware release. The error should be: ERROR: Too Many Arguments Error
    If you have the above error .. please upgrade to the latest version. If you still have issues .. please let me know via the Contact Developer link on the download page.
    Thanks
    VivoactiveHRGuy
    coming for fenix 5 as well?
    New application today .. Drop Fenix 5 for the FENIX 5 and FENIX 5x.
    Ask and you shall receive .. it is done.
    Note .. I changed Drop Fenix (as well as in Drop Fenix 5) to only export HR Recovery data to the text file once you hit the 2 minute mark.
    Note .. Drop Fenix 5 has been approved by Garmin and is now available for those that are using a FENIX 5 or FENIX 5x.
    VivoactiveHRGuy
  • Interesting, can you make the Fenix5 version also compatible with the Forerunner 935? F5 and FR935 are identical hardware and spec wise so that should just be a matter of checking the Forerunner935 box as supported in Eclipse :) Cheers!
  • Yes, the f5, q5, 935 and d2 Charlie are all the same CIQ wise, and is really nothing more than checking a new target. When the D2C was announced, auto-migration was used for it from the f5 in fact.
    Thanks guys .. I added support for the Forerunner 935 as a result of your posts.
    Jim, as I do not use any layouts at all .. and do all my applications based on the size of the screen (everything is hard coded pixel by pixel) .. my apps are segregated based on screen size.
  • In the store, the f5 and q5 are actually the same target. And the D2C is just like the f5x but for pilots. You don't have to change a thing!
    The screen size of the S60 is the same as the F5, but it's touch and the fonts are different, so you'd NOT want to include that one. :)
