Watchface: HeartBeatFace
HeartBeatFace support thread
URL: https://apps.garmin.com/en-US/apps/556c67b5-a295-48d8-9c05-72397c5dcf5e
!! PLEASE, NOTE THAT HR HISTORY IS EMPTY AFTER THE WATCH POWERCYCLE !!
You can donate the HeartBeatFace/ActiFace development via PayPal here: http://bit.ly/1RoLv4i
HeartBeatFace performs better on FR735XT and Vivoactive HR which have stronger hardware.
Now you don’t need HR widget anymore :)
Watch Face contains:
- Time and date
- HR graph for past 160 measurements (~4 hours)
- high and low HR
- daily goal progress and step count
- custom fields
- status and notification icons
- inactivity indicator. Removing of inactivity levels is handled by the watch firmware, usually it takes about 3-4 minutes of walking.
Supports 12/24 time format and km/mi.
Configuration
HeartBeatFace can be configured via Garmin Connect Mobile or Garmin Express.
Here is how to do it: https://forums.garmin.com/showthread.php?332843-How-to-App-Settings
Possible settings:
- Color
- Date format (and second date format in case when the notification icon is shown on Fenix-like models)
- Inverted mode (white background)
- Custom fields types (differs between models)
- UTC
- UTC24 (always 24H format)
- steps
- distance
- calories
- goal percentage
- heart rate
- altitude
- week goal percentage (counted all step goals and steps from the beginning of the week)
- week distance average (counted from the beginning of the week without today)
- week steps average (counted from the beginning of the week without today)
- week calories average (counted from the beginning of the week without today)
- sunrise/sunset times
- Enable/disable seconds
- Enable/disable inactivity indicator
- Battery indicator type (Fenix3 only)
  • Option to remove notifications?
    Hello Petr.
    This is a really good watch face, and I use it as my primary on my fenix3. Thank you for making it.
    I notice that when there are notifications, the date is shrunk.
    Is it possible to add a configuration setting to turn off the notifications icon?
    Matthew
  • Colors in HR bars
    This is a good watchface. I use it with my VAHR.
    Only thing what i would like to see is the colored HR bars, like it is in HR widget. Maybe it's not possible? I'm quite sure you would done it otherwise.
    Former Member over 8 years ago
    Heart Rate field doesn't seem to work
    Hi,
    I don't know if I'm using correctly your app, so I need some answers:
    -it seems to me that when push the UP or LOW button it takes many time to change the page from HBF to the other widgets
    -it seems that the HR value doesn't update correctly because when I see strange value (ex 82 bpm when I'm sure I'm around 60) and I switch to the garmin HR pages it shows the right value (in my exaple 57bpm); then, if I return to your HBF, now it shows the right 57 value... When it seems to me that the value is wrong I tryed to wait also over 30 seconds but the value doesn't change.
    please help me, manuel
    I'm experiencing the same issue, the Heart Rate field value doesn't seem to match any of the values in the actual heart rate widget.
    I was expecting it to show my current heart rate.
    Please explain
    Climbed Floors field
    Thanks for an awesome watch face!
    Yes! Please add a climbed floors of goal field. Then I don't have to swipe to that widget :cool:
    Luther
    Hi,
    is it possible to set possibility of some (better for all) fields to show clibed floors?
    Ahoj , je možné nastavit možnost nastavení polí i na hodnotu nastoupaných schodišť?
    Thank You radek
    Díky Radek
    Suggestion
    Just downloaded and looks great (viviactive hr). Suggestion: on heartbeat graphic, rather than monochrome my preference would have been to mimic the color setting on the heartbeat ranges (a specific color bar per range). I would think that the data is already available (at least on the Viviactive HR to directly pull (or push) to your app/watchface for HeartBeatFace. Thanks! Pete
    Awesome~I love this watch face~
    if the color of clock(hour:min) can be change will be better :)
    Additional field - moon phase
    Hi
    Lovely watchface. I just would appreciate one more field under custom fields. The sunrise/ sunset had a moon phase next to it during day time on the origional watch face of Fenix 3. Is it possible to add?
    Thank you
    PJ
    Sunrise / Sunset Isn't working
    The Sunrise / Sunset option isn't working. My watch received and update (Vivoactive HR) and since I can't get the setting to work.
    Any ideas?
    Heart Rate stopped work after update.
    Ahoj Petre,
    Your HeartBeatFace is really great, but since yesterday, after update of my Forerunner 735XT to version 8.20 (b340df3), the heart rate stopped work in the watch interface. It is always showing the hourglass. Similar issue is in Superb Face - instead of value of HR only "--" is displayed. The system build-in HR monitor is working fine.
    Do you know if there was a bug in Garmin update or the face has to be updated as well?
    Thanks,
    Tomas
  • HR stoped working since update 8.20 / Sun rise/set not work
    Since my Forerunner 735XT updated this week to version 8.20 (b340df3) the HR stoped working in the watch interface. It is always showing the hourglass.
    Another question: sun rise/set never worked for me. It would be a great info if working.
    Thanks a lot. Nice job! Great app!
