EDGE All in One
IQ Store Link                                                        IQ Store Link
EDGE All in One is a single data field.
One for Edge 1030, 1040 and 1050, the other for Edge 530 and 830, 540, 840 and Explore2
It displays many values for cycling - around the most important values: speed, cadence, heart rate and power.
A detailed description can be found here:
EDGE 1030 + 1040 + 1050 (English and Deutsch and French):
mcinner.at/.../GuideAllinOne_E.pdf
mcinner.at/.../GuideAllinOne_D.pdf
http://mcinner.at/files/GuideAllinOne_F.pdf
EDGE 530, 830, 540, 840 and Explore2:
mcinner.at/.../GuideAllinOne58.pdf
This datafield is free of charge, but if you like it and use it, it would be nice to be invited to a beer: paypal.me/AndreasWirth
I have tested the datafield intensively with my devices Edge 1030 and 1030 PLUS, 1040 and 530.
Download and install EdgeAllinOne as single datafield following these steps on your device:
Activity profile - Data Screens - Add New - Custom Data - Choose single layout
In the ConnectIQ collection select EdgeAllinOne1.
After installing this datafield on your device, various settings can be made. This is best done with Garmin Express or Garmin Connect Mobile. Instructions for this can be found here:
support.garmin.com/.../
To use the power section, a power meter must be connected to the device and the values of the individual power zones must be stored in the settings.
For the heartrate graphs the heartrate zones are taken from your profile. It is therefore necessary that the zones are set in your device!
For the display of wind bearing and wind force, as well as the outdoor temperature, the data of a nearby weather station must be available via Garmin Connect Mobile. The app must therefore be loaded on the phone (but it can work in the background).
If you have questions or requests please write here and tell for which device!
  • Hello. During my bike ride today, I noticed that automatic FTP and zone detection from the device are not working on the Edge 850. I am using the latest version 4.12.
  • I'm sorry to hear that.
    I don't have an 850—I have a 1050—and it works for me. I use the same code in all my data fields to retrieve FTP and zones.
    I suggest you test it again:
    First, set the values for FTP and power zones to very low (or very high) in the data field settings. Then go for a ride and see what happens.
    (I’m assuming the values on your device are set correctly and that your 850 is running software version 31.30.)
    It’s difficult to verify the device values read by the data field because you can’t see the values.
    Please let me know how it goes.
  • ok, I'll try it tomorrow. As far as I remember, it used the zones and FTP settings that are present as default settings. Around 70w it was a blue zone and above 180w it was red. As a check, I used the Garmin data screen where it showed the correct zone if I switched it quickly. The Edge850 is on 31.30 software and my FTP is 236w. Finally, I apologize for my English, I'm using a translation….
  • I just have checked my code and it woul be interesting what activity.sport (a IQ value) is set on your device. To find it out I can send you a very small program to sideload on your device. Please send me an email: [email protected]
  • Hello ! My friends and I really like this data field, but it crashes on both the Edge 530 and Edge 540 devices, where the field displays a "Q" icon after failure. We have identified that the crash occurs when heart rate data is lost, though it sometimes happens even when a heart rate sensor is successfully connected. Once this crash takes place, the entire data field often becomes permanently unusable.We would like to confirm whether this data field requires non-zero values to function properly, or if there are other root causes leading to this issue. We hope this bug can be fixed.
  • Hi, mcinner1! My friends and I really like this data field, but it crashes on both the Edge 530 and Edge 540 devices, where the field displays a "Q" icon after failure. We have identified that the crash occurs when heart rate data is lost, though it sometimes happens even when a heart rate sensor is successfully connected. Once this crash takes place, the entire data field often becomes permanently unusable.We would like to confirm whether this data field requires non-zero values to function properly, or if there are other root causes leading to this issue. We hope this bug can be fixed.
  • Unfortunately I‘ve got no crash reports from the automatik Crash Report system (ERA).
    So, please email me all files you can find in device/Garmin/Apps/Logs
    [email protected]
    EDIT:
    I just run the datafield on my Edge 530 with the latest version of AllinOne582 (4.2 - published today).
    I cannot reproduce the crash - with or without HR sensor connected.
    Please send log files!
  • In the log folder are reports of crashed apps with detailed data like appname, reason of crash, version, and for my datafields I can look up which line of code the crash causes.
    A sample of a crash record in a log file:
    Error: Stack Overflow Error
    Details: 'Failed invoking <symbol>'
    Time: 2026-05-19T15:09:15Z
    Part-Number: 006-B4440-00
    Firmware-Version: '31.23'
    Language-Code: eng
    ConnectIQ-API-Version: 6.0.0
    ConnectIQ-Version: 6.0.0
    Store-Id: a9b44628-2385-4358-96c7-ba4bb26f920f
    Store-Version: 32
    Filename: G3T90153
    Appname: myEdge45Andi
    Stack:
    - pc: 0x30000134
    Native: false
    - pc: 0x1000120c
    - pc: 0x30000213
    Native: false
    - pc: 0x100022cc
