Data Field: All In One Field
https://apps.garmin.com/fr-BE/apps/d5527704-3587-4700-b5ad-a1d185f94086
Here, the topic for my second application.
I'm listening to your opinions and your feedback.
    Former Member over 9 years ago
    Great app. Please make speed/pace configurable
  • Great app. Please make speed/pace configurable
    I'm agree. But I don't known if I display the both or if I switch speed by pace.
    I need your opinion.
    Data field are very very short in memory. All must be optimize: size of code, quantity of variable, quantity of displayed information,...
    We must do a choice:
    - reorganize the layout to add pace
    - create a simple settung with 2 modes: pace or speed
  • I can't get this to work on my epix. I just get an IQ icon with an exclamation mark. I have it set as a 1-field screen. What am I doing wrong? :confused:
  • I think it's an out of memory error.
    This field use 3 custom fonts, It's ok with 920xt and the simulator of each device, but maybe it's not for other hardware device.
    This field is a non-standard because, it's to big for a field. However, I use every time with 920xt and it's perfect to have a global visibility.
    How to use
    Hello, this is a grate field! And it appears on screen Epix while I chouse it in settings. But when I try to launch it the issue, mentioned abowe, always happends. Results are attached.
    it could be that the EPIX has a 1.2.x Connect IQ VM, while most other devices now have a 1.3.x or 2.1.x VM. When something with CIQ causes a "IQ!", on your watch, there's a file in \garmin\apps\logs called "ciq_log.txt" that might provide some details (for the developer)
    TXT from Epix
    Thank you so much for your quick response. There is TEXT right from my EPIX.
    It is so nice from your side to try to figure out what's going on.
    support more model
    the looks so great, but can support 235??
    Former Member over 8 years ago
    Dear Benjamin. Yesterday I had big pleasure to use your "all.in.one" field. It warks perfactly togather with two other big fields.
    Unfortunatelly today even after deinstalation of other fields using of yours has become impossible (IQ picture).
    Can you advice?
  • How I can set others fields? thanks
