WatchFace: Digic Watch
https://apps.garmin.com/en-US/apps/d021d6e7-22d3-49e3-a626-4f687f6d1ddd
Settings Features (https://forums.garmin.com/showthread.php?332843-How-to-App-Settings):
- Layout: activity, sunrise/sunset, data;
- Time in UTC setting, shows main time and date in UTC if turned on;
- Background color (black/white), label color, value color, time color;
- Row 1 fields: month, date, day;
- Row 2-4 fields: phone (bluetooth), battery, alarm, notifications (msg), distance (m, km, ft, mi), steps, steps goal, calories (kCal), latitude, longitude, altitude (m, km, ft, mi), training effect, sunrise, sunset, move bar, seconds, UTC time, local time, time till next sun event (sunrise/sunset), week number;
- Activity layout: distance, steps and calories, steps graph for last 7 days and today (left to right);
- Sunrise/sunset layout: sunrise and sunset time on the timeline based on latest position available. Use "Row 4: Middle Field" to change field below the bar;
- Data layout: 4 rows of fields;
IMPORTANT: latitude, longitude, altitude and training effect values are based on last activity, hence please turn GPS on until green status.
Feel free to join the discussion: https://forums.garmin.com/showthread.php?340009-WatchFace-Digic-Watch&p=784765
FB: https://www.facebook.com/yurkevich.vladimir
Thanks for using it! Please don't forget to leave review.
Changelog:
v.2.0.0:
- Added support of Forerunner® 230, Forerunner® 235, Forerunner® 630, Forerunner® 920XT, ForeAthlete® 235J, ForeAthlete® 920XTJ, epix™, vívoactive®, with either 3 or 4 rows fixed layout that fits the screen
v.1.1.22:
- ISO week number field added: https://en.wikipedia.org/wiki/ISO_week_date
v.1.1.21:
- Fixed issue with 12:00 AM hours.
v.1.1.20:
- Very bottom field in Sunrise/sunset layout is now using new "Row 4: Middle Field" to not interfere with already set up layouts, please use it;
v.1.1.19:
- Fields added: UTC time, local time, time till next sun event (sunrise/sunset);
- Very bottom field in Sunrise/sunset layout is now configurable and using "Row 4: Left Field";
- "Time in UTC" setting added, shows main time and date in UTC if turned on;
v.1.1.18:
- fēnix™ 3 HR support added
v.1.1.17:
- Settings issue fix
v.1.1.16:
- Max speed field removed because it doesn't have any data on watch faces.
- Fields added: move bar, seconds, time zone, altitude (km, ft, mi)
v.1.1.15:
- Distance kilometers and miles fix
- Settings fixes
v.1.1.3:
- IQ SDK v.1.2.3
- Data layout added (4 rows)
- New fields added: distance (kilometers), distance (feet), distance (miles), steps goal, latitude, longitude, altitude (meters), max speed (km/h), training effect, sunrise, sunset
v.1.1.1:
- Added background color (black/white) setting
v.1.1.0:
- Bluetooth renamed to Phone, hence Battery is back again to the middle by default
- Notifications setting removed
- Layouts added: activity history (default) and sunrise/sunset (BETA)
- Sunrise/sunset layout (BETA): shows sunrise and sunset time on the timeline based on latest position available, time till sunrise/sunset and current time on the timeline.
- Fields settings added. Row 1 fields: month, date, day. Row 2 fields: phone (bluetooth), battery, alarm, notifications (msg)
v.1.0.5:
- Mobile devices settings issue resolved
v.1.0.4:
- Settings added: label color, value color, time color, show/hide notifications
v.1.0.3:
- Language fixes
v.1.0.1:
- Small fonts refinements
- Attempt to fix missing characters on other languages
v.1.0.0:
- Main release
Discussion. Suggestions? Bugs?
    After the latest software update from garmin the "sunrise/sunset" is way off. And it displays "phone: off", even if the phone is connected and working.
    The update reseted the history on the watch itself.
    That's true. Thanks for help! Received couple negative reviews already from people not bothering to look at embedded Garmin apps that show no history after update too.
    So how about white background?
    It's in settings for a long time, please use. If there was something wrong, please try latest update. Works on my watch nicely.
    It seems like Garmin bug too. Didn't change any code there. To make sure "sunrise/sunset" works correctly, please get GPS signal once, e.g. run any GPS activity for couple mins. Thanks!
    is it possible to add an layout for ALARM? maybe you can replace on the 24 h bar the "NOW" marker with an alarm marker for the next alarm and the time till next sunset/sunrise with time to next ALARM.
    I would love to! Unfortunately Garmin doesn't provide alarm time, active alarms count only.
    Since some days, don't know exactly when it started, I have problems with adjusting the settings from Connect Mobile.
    When I want to adjust some settings, CGM shows the correct values from the watch. But when I change one value and save it to the watch, all the remaining values, which I didn't change at this moment, are reset to the standard values. Change of settings from the PC works flawless.
    The watch is on 6.72beta, the installed watchface is 1.1.15-upd, CGM is 3.3.
    I assume some of this issues could be because of using beta firmware. Even production firmware works with many bugs and nuances, not speaking about beta.
    very nice watch face I like it very much as good nicely done overview. Yesterday after firmware update (6.8) nice 7 column activity display turn into one column among the screen. Fenix 3
    Have no idea why. Please try latest update and re-selecting watch in watch list.
  • Hello Vladimir,
    the problem with the settings from Garmin Connect Mobile (Android) still exists: If I change the settings for the watch on the mobile, it resets all the other unchanged fields on the watch to the standard values. Interestingly the values in Garmin Connect Mobile are still my custom one.
    I'm using currently 6.80 and your newest 1.1.16 version of Digic.
    Interesting fact: The Settings Menu still shows 1.1.15 as version number :-)
    Noticed that settings from mobile devices come in weird manner - only fields that were manually updated are set disregarding already selected value. Can anybody confirm?
    Resolved.
  • Should be also on VivoActive
    Nice and good looking watchface on the fenix3. I'd love to see this also for the VivoActive (VA).
    Any plans to port this to a rectangular screen as well?
    Really love the flexible color settings! This is how I have set it up:
    best VS
  • Low battery and a lot of useful information is the key of this Watchface. I got one "problem" though. The bluetooth connection is allways displaying "Off" even though a connection is made and messages is displaying ok!
    Also,I would like to make an suggestion. I use the sunrise/Sunset . Could you make the slider "Now" with a color key? Like red when sun is up and blue while its down? Allso,I would like a counter telling me how much longer the day is today than yesterday...
  • Really love the flexible color settings! This is how I have set it up:
    best VS
    It's not a Digic watchface in your photo :D Wrong thread ;)
